Problem with HSRP/ARP on MSFC/SUP modes
Mark3000
I have 2 cisco 7609 equipped with MSFC-2 modules.
I have configure HSRP between the two modules (trunked using etherchannel)
my problem is that HSRP IP addresse sometimes hangs up, when doing show arp
I can see that HSRP add is not resolved, in general a shut/no shut on the interface
solves the problem.
But as these nodes are critical, I am looking for any solution or explanation
to this behaviour.
Thanks in advance
BR
Configurations:
MSFC-2 number 1
interface Vlan1100
description int-1
ip address 10.20.30.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
ntp disable
standby use-bia
standby ip 10.20.30.3
standby priority 110
standby preempt
standby authentication VLAN1100
standby name VLAN1100
standby track vlan1050
MSFC-2 number 2
interface Vlan1100
description int-2
ip address 10.20.30.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
ntp disable
standby use-bia
standby preempt
7 Replies 7
smif101
Level 4
Level 4
The first thing I would do here is change the priority of one of the devices to 120, you don't want them the same. Also the use of the standby use-bia command is not supported on the MSFC2, so I would get rid of that command too. Try that and see if things get better.
Well it was a mistake during the copy/past:
I have priority 110 on active interface and none (so 100) in standby interface.
Why do u think "use bia" may cause problems?
I made the change and still waiting if it occurs
BR
glen.grant
Check to make sure your link between the two 7206's is running clean . Also check trunking and etherchannel and make sure they look normal . When this happens can you see the standby router ok ? If do a show standby does the opposite router show as the backup ?
Links and etherchannel are OK. But the show standby commands show strange issue .. have an Init state with Unknown status !
Interface Grp Prio P State Active addr Standby addr Group addr
Vl1100 0 110 P Init unknown unknown 10.20.30.3
Can you ping directly across this link ? Have you checked to make sure that vlan 1100 is allowed on the trunk ? Maybe you could post you trunking and etherchannel info and we can see something from that .
- MSFC-2 does not support "use-bia": I think this apply for PFC2 not MSFC2 !
- Yes I can ping across my links, other VLANs transported over some trunk are ok.Bellow my configuration on Giga Ports and Etherchannel...
Any help ?
interface Port-channel12
no ip address
switchport
switchport trunk allowed vlan 200,300-305,1000,1100,1101,1401,2401
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/1
no ip address
udld port aggressive
switchport
no cdp enable
channel-group 12 mode on
interface GigabitEthernet1/2
no ip address
switchport
no cdp enable
interface GigabitEthernet2/1
no ip address
switchport
no cdp enable
interface GigabitEthernet2/2
no ip address
switchport
no cdp enable
hi guys,
i just wondered if this issue has been fixed by now as we experinenced a similar problem yesterday after SRM implementation on Catalyst 6509.
After reload of the standby routers the HSRP process on VLAN 7 was not working anymore.
Here is the output of the show standby brief after the change:
Router 1
InterfaceGrp Prio P State Active Standby
Vl4 1 20 P Active local 172.24.52.69
Vl7 1 10 P Standby 194.156.168.162 local
Router 2
Interface Grp Prio P State Active Standby
Vl4 1 10 P Standby 172.24.52.65 local
Vl7 1 20 P Active local unknown
As you can see the state of Vlan 4 is fine but on Router2 in VLAN 7 the standby router is unknown.
We have about 25 Vlans defined on these routers with between 1-3 HSRP processes on each VLAN.
Only VLAN 7 is having problems. The others are working fine.
Thank you
