Quick hardware removal question! Help
eblizard
I currently have a production 3600 Cisco router that has a 8 port async WIC that is not being used which I would like to remove. Can you advice if the unused 8 port Async WIC can be removed without first bringing down the router?
dathaide
Thanks!
