Re: GRE tunnel issues
lespejel
Level 3
Level 3
hello @hector.grajales1
if your tunnel shows up on both sides, then you should be able to ping both tunnel interfaces, is this true?
also, if you are using PBR, and traffic is not matching your ACL, you might need to check the ACL format.
you can also CEF to verify the forwarding is actually being used:
show ip cef [tunnel end point IP]
this output must say it's directly attached.
there are several documents describing GRE, if you can share more details, I think we can help you.
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-software-releases-120-mainline/47205-cef-whichpath.html
https://www.cisco.com/c/en/us/support/docs/ip/generic-routing-encapsulation-gre/118361-technote-gre-00.html
CCIE 52804
Joseph W. Doherty
"if your tunnel shows up on both sides, then you should be able to ping both tunnel interfaces, is this true?"
Not always.
