Recommendation: MultiService dialup platform (not AS5300)
brianprice
Any recommendations for a dialup platform other than a 2511 or AS5300 that will allow me to use an ISDN dialin pool from the local telco while have the firewall feature set loaded. I want to be able to map the user's login ID to the service or device they need to access.
tepatel
You can use 2600 OR 3600 series routers or if you need more port density, you can use Access Servers like AS5350, AS5400 etc..
thank you.
Thanks....I can't seem to find good information on the AS5400...I'll login and look again for more information to see if there is semi-standard hardware configuration allowing me to configure multi-service management for dialin groups. I was hoping to find a product which allows all users to dial the same number while allowing me to control services completely from the MAC address or dialin username.
