Bookmark
Subscribe
605
Redundancy & load balance by using static route
acbennyma
I have build a lab at home and try to test Redundancy and load balance by using static route.
I am trying to ping some internet IP from PC1, I find that it can perform Redundancy when I shutdown one of series ports of 2620 but load balance fail.
It is possible to do it ?
The Physical connection is as Below. 2620 two serial ports are connect to two 1720 series port
LanA(PC1 192.168.0.1) -> 2620->1720A & 1720B -> Hub(LanB) ->NAT Router(192.168.169.254) -> Internet
2620#sh ru
version 12.1
service timestamps debug uptime
memory-size iomem 10
ip subnet-zero
no ip finger
interface Ethernet0/0
ip address 192.168.0.254 255.255.255.0
interface Serial0/0
ip address 172.0.0.1 255.255.255.252
no fair-queue
clockrate 128000
interface Ethernet0/1
no ip address
shutdown
interface Serial0/1
ip address 172.0.0.6 255.255.255.252
clockrate 128000
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/1
ip route 0.0.0.0 0.0.0.0 Serial0/0
line con 0
1720B#sh ru
version 12.2
hostname RouterB
memory-size iomem 20
ip subnet-zero
interface FastEthernet0
ip address 192.168.169.51 255.255.255.0
ip nat outside
speed auto
interface Serial0
ip address 172.0.0.2 255.255.255.252
ip nat inside
no fair-queue
ip nat inside source list 1 interface FastEthernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.169.254
ip route 192.168.0.0 255.255.255.0 192.168.169.50
ip route 192.168.0.0 255.255.255.0 172.0.0.1
no ip http server
access-list 1 permit 192.168.0.0 0.0.0.255
line con 0
1720A#sh ru
memory-size iomem 25
ip subnet-zero
ip address 192.168.169.50 255.255.255.0
ip nat outside
speed auto
interface Serial0
no ip address
shutdown
interface Serial1
ip address 172.0.0.5 255.255.255.252
ip nat inside
ip classless
ip route 192.168.0.0 255.255.255.0 172.0.0.6
ip route 192.168.0.0 255.255.255.0 192.168.169.51
no ip http server
line con 0
7 Replies 7
thisisshanky
Level 11
Level 11
By default your interfaces on the 2620 serial interface will be doing per-destination load balancing. For every destination address one of the serial links will be used. Try pinging a different address in the internet and see if LB works.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Kevin Dorrell
Level 10
Level 10
This is normally doing per-session balancing rather than per-packet load balancing. I think you can provoke per-packet load balancing, at a price, by disabling CEF and ip route cache.
Kevin Dorrell
Luxembourg
Yes, I try to use two ping, it can perform LB,
so is it possible to perform per-packet LB ?
I haven't enable CEF and ip route cache
ip route cache is enabled by default. You have to do no ip route cache on the relevant interfaces to disable it.
Kevin Dorrell
Luxembourg
Thx ! kevin,
This time, I have disable ip route cache in the 2620Router and use one ping to obtain the result.
It seems not work because I expect there will be input and output traiffc on both two serial interface,but now the result seems no output rate on two serial interfaces.
Does my concept is right ? traffic which leave from router to interface can be seen as output rate ?
2620#sh int | i bits/sec
5 minute input rate 11000 bits/sec, 1 packets/sec
5 minute output rate 11000 bits/sec, 1 packets/sec
5 minute input rate 6000 bits/sec, 0 packets/sec
5 minute input rate 5000 bits/sec, 0 packets/sec
The concept is right. I don't know why it does not seem to be working ... I'll have to do some reading. I don't know how it arbitrates between the two routes when route cache is disabled. I'll post back to you if I find anything.
Kevin Dorrell
Luxembourg
Thank you very much !
kevin.
