Restrict incoming calls from E1-R2 for dialup access??
javiercastro
I´m trying to reserve some modem lines in a AS5300 to be occupied by specific phone numbers, Is it possible to do this using a E1-R2 connection to the PSTN? (I know that this can be done with ISDN using the dialer caller command in the interface dialer configuration; is it something similar for a E1-R2 connection to the PSTN?)
tepatel
YES.. You can reserve modems for different dialup numbers (DNIS) on AS5300 using "Modem Pooling".
For that AS5300 needs to have DNIS delivered from Telco over E1-R2 line. Here is the link which talks in detail about that
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080093c2c.shtml
That doc talks about T1/CAS but same is true for E1-R2 as well.
