Routing problems through Async interface
b-maldonado
I'm successfully connecting two routers through a DDR configuration, however I need to pass dynamicaly two routes for networks that are directly connected to the Router that is starting the DDR connection. Although I configure in the Async interface: async dynamic routing, it doesn't work. Has anybody know what can I do.
Berlitz
Harold Ritter
Try "async default routing" under the async interface.
According to some Cisco Doc I found, you should use "Async dynamic routing" command under the As interface. Unfortunately this does not work for multicast/broadcast based routing ptotocols. You can run BGP using this command, but not RIP or OSPF. The proper command as stated in the previous post is "async default routing." This will work for sure.
