RTM 1.4 SP9 problem with C4506 IOS 12.1(20)EW1
esalle
My RTM1.4 Server detects all C4506 IOS 12.1(20)EW1, but when I try to monitor my switch, I can't expand the icon representing the switch to reach any interface. It do the same with the following switch:
- 2950G48-EI 12.1(20)EA1
- 2950G48-EI 12.1(20)EA1a
- 3550G24-EI 12.1(20)EW1
- 3548XL 12.0(5)WC9 & 12.0(5)WC9a
Does anyone has a solution?
Alex
rmushtaq
Level 8
Level 8
Under Traffic Monitor screen?
Yes, under traffic Monitor screen.
eap
I am having this same situation. Does anyone have a solution.
Finally, I solved my problem by uninstall RTM1.4.
I did a fresh install of RTM1.4 and I installed SP9.
Then it detects all my 4506, 4503, 2950, and 3548XL
switchs very well.
It is this only solution I found.
I hope this will be helpfull for you.
Alex
