Setting up DSL connections on a 3640 w/ ATM
e.network
We are reselling the LEC's DSL service in our area. We connect to the LEC via a ATM T3 interface. I'm looking for a solution that will let me use PPPoE for authentication for my dynamic IP customers. I found scattered information on the cisco website, but I havent found anything that matches my scenario.
Does anybody have any examples that they could share with me? Right now I have 6 VC-Class statement, 1 BVI Statement, and seperate 6 sub-interfaces setup for each class of DSL service that we offer.
I'm unclear on how to make customers authenticate via PPPoE against my RADIUS server. I've never setup a IP pool on a 3640 before but I have a good idea on how to do it. I just dont understand how the router knows who to assign the IP's to after authentication via PPPoE against the radius server. Somebody please help.
Marc
ciscomoderator
Community Manager
Community Manager
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you, or there is no public information available at this time. If you don't get a suitable response to your post, you may wish to review our resources at the online http://www.cisco.com/go/solutions. You may also contact our product information line at 1-800-553-NETS or a Cisco Systems Engineer at your local Cisco office or reseller. To locate your local Cisco representative, visit http://www.cisco.com/warp/public/687/Directory.shtml
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
alanssie
Marc,
PPPoe would need a bridge enviroment, don't know currently
if this is configure in your router.
If one of the sub-interface is receiving snap packet with PPPoe header the IOS will see this and submit the incoming
PPP packet to a virtual-access, of course if the PPPoE
was establish previously.
PPPoe configuration require vpdn as well as a target
virtual-template.
This work almost the same way than l2tp except of course that
PPPoe use message like PADI, PADO, PADS,...
Once PPPoE has establish the session the PPP code takes
over, hence the ip address allocated to a remote PC would
be as if you were doing this via l2tp.
First you authenticated (local, or radius) then you discuss IPCP, if the pool as well as the virtual-template is configured
properly, when the PC start negotiating the address, it will send a confreg with 0.0.0.0. seeing this the PPP code will try
to get the ip address following configuration on the virtual-template (this could even be from a dhcp server)
Hope this helps
Alain
cwetzler
Marc,
I am trying to use more than one ip pool and also do not have static adressing ready yet...that's my question. Maybe we can help each other. Here's my working config (relevant) on a 3620 on an ATM T1. My customers use PPPoE as well. Would you mind emailing me your config to cwetzler@wetzweb.com? Thanks in advance.
Current configuration : 2944 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname xxxxxxx
logging rate-limit console 10 except errors
aaa new-model
username dslcust1@domain.net password 7 xxxxxxxxxxx
username dslcust2@domain.net password 7 xxxxxxxxxxx username dslcust2@domain.net password 7 xxxxxxxxxxx ip subnet-zero
no ip finger
no ip domain-lookup
ip domain-name domain.com
ip name-server xx.xx.xx.xx
vpdn enable
no vpdn logging
vpdn-group 1
accept-dialin
protocol l2tp
virtual-template 1
terminate-from hostname xxxxxxxx
local name xxxx
lcp renegotiation always
l2tp tunnel password 7 xxxxxxxx
call rsvp-sync
interface FastEthernet0/0
ip address xx.xx.xx.xx 255.255.255.192 secondary
ip address yy.yy.yy.yy 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clockrate 2000000
interface ATM1/0
no ip address
no ip mroute-cache
atm vc-per-vp 4096
no atm ilmi-keepalive
atm ilmi-pvc-discovery
no scrambling-payload
interface ATM1/0.1 point-to-point
ip address xx.xx.xx.xx 255.255.255.252
no ip mroute-cache
pvc x/xxx
encapsulation aal5snap
interface Virtual-Template1
mtu 1492
ip unnumbered FastEthernet0/0
peer default ip address pool dslpool1
ppp authentication chap
ip local pool dslpool1 xx.xx.xx.xx xx.xx.xx.xx
ip default-gateway zz.zz.zz.zz
ip classless
dial-peer cor custom
end
Marc,
Useally I configure pppoe as in the following url
http://www.cisco.com/warp/customer/794/827pppoe_2.html
If you question was to associate pool1 for l2tp and pool 2 for pppoe this should work just fine by configuring different virtual-template.
I am a bit confused by the config you posted, I see l2tp
as protocol in the vpdn config.
Could you please answer if you are trying to get specific
address to PPPoe users, or if you want to different pools
for l2tp and PPPoe
Alain
