speed over a serial interface
telemasico
Is there any command on a router to probe,that the speed over the interface is the same that our service provider are selling ?
smif101
Level 4
Level 4
I am pretty positive that you can't, your best bet is to use a test set (like a firebird) to determine the serial links speed. What type of circuit do you have?
Thanks...for you pretty positive.. We counted on interfaces Frame-Relay type that can be from 128 Kbps to 1984 Kbps and on each one of them discovering 2 PVC at least (DLCI)
