Subinterface problem
dkblee
Level 7
Level 7
Hi!
I got a vlan that was configured on the physical interface previously, and now i'm trying to clear all the config from the physical interface, and move that .9 vlan to int fa0/0.1 and encap it with dot1q. The problem is that after doing this, the .9 vlan is not able to ping any other vlan. The hosts in that vlan can only ping themself. They are not able to ping even their gateway 10.71.9.254(which is the ip/gateway for that fa0/0.1 subinterface).
btw i'm using cisco 2912 router.
Any idea how can i troubleshoot this?
Thks!.
18 Replies 18
mahmoodmkl
Level 11
Level 11
HI
Can u give more clear view of the problem.As ur question is not that much clear.
Mahmood
The router port connect to a switch, Is the port switch configured as a trunk? Are both using 802.1q?
Are you shure about IP address of host and D.G. are in the same net/subnet?
Please post the configuration of both devices
Please rate if the post help you.
Albert Giorgi from spain
spremkumar
Level 11
Level 11
Can you throw more clarity on the router model in which you are exactly trying to do this config chnage ? also can you post out the current config as well as the show version output taken from the router ..
regds
Hi! The followings are the current config. I'm trying to remove the config in Int fa0/0 and reconfig it in int fa0/0.1 using dot1q and with ip 10.90.9.254 255.255.255.0. After clearing the config in int fa0/0 and reconfigure it in int fa0/0.1 as the rest of the subinterfaces, the .9 vlan can only ping within its own subnet and can't even ping 10.90.9.254.
The router's model is Cisco 2621XM running on ios ver 12.1.
ip subnet-zero
no ip source-route
no ip domain-lookup
no ip bootp server
interface FastEthernet0/0
description Office VLAN
ip address 10.90.9.254 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0.2
description Management VLAN
encapsulation dot1Q 1
ip address 10.90.8.254 255.255.255.0
no cdp enable
interface FastEthernet0/0.3
description Production1 VLAN
encapsulation dot1Q 200
ip address 10.90.10.254 255.255.255.0
no cdp enable
interface FastEthernet0/0.4
description Production2 VLAN
encapsulation dot1Q 300
ip address 10.90.11.254 255.255.255.0
no cdp enable
interface FastEthernet0/0.5
description Production3 VLAN
encapsulation dot1Q 400
ip address 10.90.12.254 255.255.255.0
no cdp enable
interface Serial0/0
ip address 10.90.16.1 255.255.255.0
interface FastEthernet0/1
ip address 10.90.13.252 255.255.255.0
duplex auto
speed auto
interface Serial0/1
ip address 10.39.1.217 255.255.255.252
router rip
redistribute static
network 10.0.0.0
HI
i dnot see any encapsulation command under u r interface.can u give it according to u r vlan info.
Mahmood
Hi! I've cleared the config in int fa0/0, and move it to int fa0/0.1 as below
interface FastEthernet0/0.1
description office vlan
encapsulation dot1Q 100
no cdp enable
HI
Can u please verify the port on the switch which u r connecting to u r router is configured as a trunk port and it is having encapsulation configured.
Mahmood
Hi! I'm not able to verify right now, as i'm not in the office but i remember there should be trunking for all vlan because if that's not the case the rest of the vlan will not work(eg. .10, .11, .12 and etc).These vlans are working fine, i can ping from one vlan to another. Any other possibility? Thks
David
Were the devices in that VLAN working when it was configured on the main interface (Fa0/0)?
What VLAN are these devices in on the switch? I am guessing that there is a mismatch between the VLAN number used in the router config and the VLAN number on the switch where these devices are connected.
Rick
Rick
Hi!
Yes, it was working when it was on the fa0/0 interface. It's in vlan 100 in the switch.
Thks.
macarpenter
Community Member
I don't see that you have a native VLan on the routers sub-interface...
encap dot1q vlan 100 native
If you are on the switch, do a
sh cdp nei det
and look at the cdp information at the bottom of the output. It should tell you if you have a native vlan problem. Also make sure that the .9 vlan is not shutdown.
Hi!
Must the native command be in the encap statement?
What is it use for in this case? The rest of the subinterfaces are working fine without the native command. Pls advise.
Thks!
Since the .9 vlan was on the physical interface, the packets were untagged. Now that you put the interface on a subinterface, they must be tagged. Be sure that the switchports native vlan is 100 and that you subinterface you are using on the router for the .9 network has the native keyword for the encapsulation. This should clear up your problem. Let me know.
David
What the native command is used for is to indicate that this VLAN is the native VLAN. Frames in the native VLAN are sent un-tagged and frames in other VLANs are sent framed.
Your config worked when the subnet was configured on the main interface (Fa0/0) because on the main interface frames are sent and received un-tagged. When you moved the configuration to the subinterface (without the native command) the router is expecting frames to be tagged as VLAN 100 but they are un-tagged - because they are in the native VLAN according to the switch.
So when you include the native command on the encapsulation command, it lets the router know that on this subinterface the frames will be un-tagged.
Rick
Rick
