subnets please help
carl_townshend
Hi all, can anyone tell me, if I split a class c network in 4 on a 192 mask, the subnet starting 192.168.11.0/192 etc.
how would i reach all 4 subnets via static route, could I just use 192.168.11.0 , would this reach all 4 subnets, or would I have to point each one ? also if I used eigrp would i advertise all 4 seperately ?
cheers
Carl
6 Replies 6
ariela
Level 4
Level 4
your 4 nets are:
192.168.11. 00 | 000000
192.168.11. 01 | 000000
192.168.11. 10 | 000000
192.168.11. 11 | 000000
that is:
192.168.11.0/26
192.168.11.64/26
192.168.11.128/26
192.168.11.192/26
Please remember that the correct bit notation is /26 (24 C class + 2 subnetting) and not /192
for the static route, you have to use a single route that "summarize" all 4 routes: 192.168.11.0/24
for eigrp, something like
router eigrp 100
no auto-summary
network 192.168.11.0 0.0.0.255
would be ok.
If you need to work with eigrp routes, remember that by default, EIGRP summarizes subnet routes to the network level. The no auto-summary command can be entered to configure subnet level summarization, then use 'ip summary-address eigrp' on a specific interface. More infos:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hirp_r/rte_eih.htm#wp1097180
Andrea
Hi Andrea, thanks for your help, do I need to use the eigrp-summary address on my interface,or will it work fine without ? I guess this just stops all 3 networks being advertised out the interface right ?
Also is it possible for me to split the network
into a 128 subnet and 2 64's, how would I do this ?
Hi carl,
It will work fine. As you mentioned, it makes advertisements smaller. In this case, it will advertise on network instead of 3 if you configure eigrp...
As i understand u wanna create a subnet which include 128 IP addresses, and two more subnet which includes 64 IP Addresses. Yes it is possible with a enough block of IPs.
Here is a simple calculation for 192.168.11.0/24
Subnet 1
Network Address: 192.168.11.0
Subnet Mask : 255.255.255.128
Subnet 2
Network Address: 192.168.11.128
Both subnet has 128 IP address. Both u can use only 126 of them because the first one is network and the last one is for broadcast.
So lets have 64-IP Subnet
We will use the first one for 128-IP
So we have to subnet the second one to use as 64-IP
Subnet 2.1
Network Address:192.168.11.128
Subnet MAsk : 255.255.255.192
Subnet 2.2
Network Address: 192.168.11.192
After these calculations you have 3 subnets. The first one includes 128 IPs, and the others (Subnet 2.1 and 2.2) include 64 IPs
Regards.
Ahmet
Please Rate helpful posts.
is it possible we can have the first 2 64 subnets first and the 128 subnet last (higher in the range) ?
Exactly you can...
VLANs are like legos, you can build whatever u want...
But there is one important thing you have to consider is that:
If you wanna use first subnet (subnet zero), you have to configure your switches.
Here is the command:
router(config)# ip subnet-zero
Without enabling this, you cant use first subnet...
Regards...
Pls rate helpful posts...
so can i have my first 2 64 ip addresses in the lower range ie 0-64-128 and 128-256, or do u have to use the bigger one first in the lower range ?
