02-12-2003 08:42 AM - edited 03-02-2019 05:02 AM
SUP1 shows Pinnacle error and continually reboots itself, have tried loading new IOS with xmodem but it will still not boot. Problem began after installation of a WS-X6348-RJ-45. Cannot get to console at all can anyone suggest a resolution.
Dan
02-12-2003 08:52 AM
What is the exact error you are seeing? If you are seeing Pinnacle Synch Failed messages, try the following
http://www.cisco.com/warp/customer/473/34.shtml#PINNACLE_SYNCH
02-12-2003 10:04 AM
We are getting the following output on boot:
Boot image: bootflash:cat6000-sup.6-3-8.bin
In Local Test Mode, Sync Failed. Retries: 4
Local Test Mode encounters Minor hardware problem in Module # 1
Running System Diagnostics from this Supervisor (Module 1)
This may take up to 2 minutes....please wait
Pinnacle Sync Failed. Retries: 4
Sync Status for module 1
Device Number: 0 Sync Status:0xa0
System Bootstrap, Version 5.2(1)CSX
Copyright (c) 1994-1999 by cisco Systems, Inc.
c6k_sup1 processor with 65536 Kbytes of main memory
If there is a fault with the 6348 could that cause a failure in the SUP1?
SUP1 was operating fine in the Chassis until the 6348 was installed.
thanks
Dan
02-12-2003 10:09 AM
Yes..Try powering up the switch without the line card. Also, try the ethernet card in a different slot. Make sure that Sup as well as the line cards are seated fully and the thumb screws tightenend
02-12-2003 10:18 AM
We have tried every possible configuration - SUP and 6348 in every slot, seated and screwed down.
The problem occurred after installing a 6348, and it's removal or movement has had no effect on the problem.
It would seem to me that the installation of the 6348 has somehow corrupted the config stored in NVRAM (we have tried booting from slot1 instead of onboard flash, but still get the same error so NVRAM would seem to be the only option.) I can't think of a way of clearing NVRAM with only romon as an interface, might there be a way of doing this short of putting the SUP1 in another chassis with a working SUP1?
