Sup720 IOS Upload/Download problem
ks0309
I'm using Cat6509 with "s72033-psv-mz.122-18.SXD3.bin"
I tried to upload new IOS from my PC to Catalyst and download that IOS from Catalyst to my PC.
In both cases, during the process, it stops with displaying "timed out" message.
When it stops,in upload, the size of the incomplete IOS is 33.5MB
Do you know why this happens?
Thank you in advance~~~ ^ ^
bash-2.03# ls -lF
총 156800
-rwxrwxrwx 1 root other 33553920 6월 22일 20:42 s72033-psv-mz.122-18.SXD3.bin*
ankurbhasin
Level 9
Level 9
Hi Ks,
Are you using Cisco TFTP server. I have seen this problem many a times when I use Cisco TFTp server as for large files it times out.
Can you try some other TFTP server.
Ankur
amit-singh
Level 8
Level 8
The problem is with the TFTP server.
Please use TFTP32 tftp server, it works as a champ. Its the issue with the Large file size.
http://tftpd32.jounin.net/
HTH,
-amit singh
Nick Egloff
Another option that is POSSIBLE (but I'm not sure it is recommended) with the newer memory modules (CF) and Sup720 in native mode would be to use a USB flash memory drive to read and write the files to CF. Obviously you'd want to verify this in a non-production switch to make sure the formatting is compatible and the file is readable, but I have been able, on my 6513 with Sup720-3BXL and my USB 7-in-1 drive to read/write the CF after formatting it on the Cisco first and copy new code version to the CF card then insert & verify the bin file.
Please also note the SXD3 is deferred and is not recommended for deployment last I knew and can have a bad bug if you accidentally create a subdirectory on the CF card (while using the above method) where the whole switch will reboot and continue to reboot - SXD4 or SXD5 if it exists is the current recommended in that release train for SXD I think..
It's a documented bug in the bug tool, but doesn't SPECIFICALLY state that a subdirectory will trigger it, only "corrupted flash", which is what the IOS in that version thinks the directory existing really is... SXD4 fixes that bug. OR, even easier, don't create subdirectories on it if you are using a PC to transfer images to the CF! :-)
Either using FTP or a different TFTP server, as Amit and the other poster mentioned, will also work.
Prashanth Krishnappa
Try TFTPd32.. It works like a champ even with large files
