Switch problem
sophaunsim
Switch 24 prot is not working although I restart that switch by unplug and plug the power again!
6 Replies 6
spremkumar
Level 9
Level 9
hi
In which switch model you are facing this problem ?
can you login to the switch and post the output of show interface fastethernet x/24 and show version ?
regds
Model Cisco Catalyst 2950 Series Switches! all the hosts can't communicated to each other!
intelide3
hi,
by restarting (unplug-plug) the switch doesnt mean that it will lost the config.
do you have access to the switch to see its switch-port vlan membership config? check their status - cables?
pls rate :)
ilnaiduccna
As your info. your using 2950S, what are the ports blinking status eithere keep on orage / green, are you sure vlan membership still is there or not, can you post the sh run it may help in this forum.
Naidu.
blinking status eithere keep on orange!
Check is there may be duplex mismatch.
Naidu.
