Trace tool for layer-2 devices
tvaris
Hi!
Is there any program which I can use to trace layer-2 devices? Like tracert works for layer-3 devices.
Thanks in Advance, Teemu
glen.grant
Depending on which version of code you are running on your cisco devices a lot of the newer codes support L2trace command which will do what you are looking for .
