Trunk between 65XX & 3750 does not work
aparikh
I have 7603 router with 2-ws6516-ge-tx cards (disk0:/c6k222-pk9sv-mz.122-18.SXD2.bin). I want to use card 1 as a swithcport. I enable trunk on port1 & it does not work with c3750. Trunking on cisco 3750 works o.k. with 3500XL switch.
Following is the config from 7603 & 3750
7603:
interface GigabitEthernet2/1
no ip address
switchport
switchport mode trunk
end
3750:
interface GigabitEthernet1/0/3
no ip address
no mdix auto
end
Also, can you enable clustering on WS-65xx card ?
amit-singh
Level 8
Level 8
Do you see link lights on both the sides. Did you try changing the cable. Do you see some errors on the interface on either of the side.
Config seems to be OK. What does" show int gig x/x " shows to you on both the sides.
No, 65xx doesnot support clustering.
regards,
-amit singh
the configs look ok; do you have physical connectivity when connecting the trunk ports on the 7603 and the 3750, that is, are the ports in up/up state ?
GP
