05-26-2005 03:52 PM - edited 03-02-2019 10:55 PM
Can you give me the reason for showing ''txload 10/255 , rxload 42/255" from the below output?
__________________________________________________
Serial3/3 is up, line protocol is up
Hardware is M4T
Description: -----Singtel Link------
Internet address is
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 255/255, txload 10/255, rxload 42/255
Encapsulation FRAME-RELAY IETF, crc 16, loopback not set
Keepalive set (15 sec)
Restart-Delay is 0 secs
LMI enq sent 76036, LMI stat recvd 76036, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 0 LMI type is ANSI Annex D frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0
Last input 00:00:01, output 00:00:00, output hang never
Last clearing of "show interface" counters 1w6d
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 259000 bits/sec, 39 packets/sec
5 minute output rate 62000 bits/sec, 35 packets/sec
30324595 packets input, 3176326065 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
27118434 packets output, 570890611 bytes, 0 underruns
0 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
_______________________________________________________
Thanks & regards
Yugendhran
05-26-2005 05:51 PM
Really nothing to tell your traffic is heavier one way than the other . This can happen when you have people say retrieving info off servers that may be hung off this router . A request for info will usually be smaller than what is being retreived from the servers so traffic will be higher in one direction, this is just one scenario . There is nothing wrong with this .
05-27-2005 10:55 AM
Thanks For your update.I am watching my bandwidth utilization of the link is 80kb - 120 kb in 2MBps with the help of solarwinds tool. Eventhough I am getting delay on the link is 290ms average. Can you give me the reason for this dealy?
05-27-2005 11:15 AM
What are you using as the Frame Relay network? Maybe the delays are introduced by the network, not by the router.
Kevin Dorrell
Luxembourg
05-28-2005 03:21 AM
It is not Frame-relay network. IPLC - Leased link
05-29-2005 11:40 PM
Where are you measuring the delay to. The reason I thought you were using a Frame Relay network is that your encapsulation is Frame Relay.
Kevin Dorrell
Luxembourg
05-28-2005 03:21 AM
05-29-2005 07:53 PM
hi
r u getting 290ms in ur p2p link or to any of the global sites hosted outside in the internet ??
if its with any or with all the global sites try to do a trace and chek out where ur exactly gettin onto the bottleneckk.i hope those trace results will help u out to find the reason for the same..
but if the latency is ther in ur p2p link with ur SP then i would suggest to chek up the cappings applied on ur interface @ SP end..
regds
07-14-2005 03:14 PM
Hi kevin,
I am really sorry, it is frame relay link. I am apologies for my mistake.
Thanks & regards
Yugendhran
