07-18-2012 06:17 AM - edited 03-03-2019 06:41 AM
I'm trying to get a spare Sup. V engine module operational in a 4507E and get the above message when it try to boots.
I am not aware if this spare had been used in production before.
Not sure if I need to open a support ticket, so I thought I would see if anyone else has seen this behavior.
Tom
The following is displayed on Console:
Exiting to ios...
Rommon reg: 0x0E000380
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 12.2(37)SG1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 30-Jul-07 13:47 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11863D38
Unsupported chassis type 52, system can not boot
Rebooting in 10 seconds...
10 09 08 07 06 05 04 03 02 01
* Welcome to Rom Monitor for WS-X4516-10GE System. *
* Copyright (c) 2003-2006 by Cisco Systems, Inc. *
* All rights reserved. *
Rom Monitor Program Version 12.2(31r)SGA
Supervisor: WS-X4516-10GE Chassis: WS-C4507R-E
Hardware Revisions - Board: 4.11 CPLD Tie: 32 FPGA Pod: 14
MAC Address : 00-11-21-ac-cf-b0
Ip Address : Not set.
Netmask : Not set.
Gateway : Not set.
TftpServer : Not set.
Solved! Go to Solution.
07-18-2012 04:27 PM
Tom
You don't have the right IOS version to meet the minimum requirements for this chassis.
See the following document
Table 5 lists 12.2(40)SG as the minimum IOS required for a 4507R-E chassis and 12.2(54)SG as the minimum IOS for a 4507R+E chassis. You only have 12.2(37)SG1 on your engine, hence the lack of boot.
Upgrade the IOS via ROMMON (slow and painful, but it'll work) and re-try.
Cheers.
07-18-2012 04:27 PM
Tom
Cheers.
07-19-2012 04:12 AM
Thanks Darren. I appreciate your assitance. I suspected I had an issue with the IOS version.
Tom
07-19-2012 06:34 PM
Tom
No worries. Glad to help.
Cheers.
