Uploading running configs to TFTP
a.lysyuk
Hello.
Can anybody tell me what string I should write into the following variable to upload running configuration from the router to tftp server.
Type: OBJECT-TYPE
OID: 1.3.6.1.4.1.9.2.1.55
Numerical syntax: Octets
Base syntax: OCTET STRING
Composed syntax: DisplayString
Status: mandatory
Max access: write-only
Description: Write configuration to host using TFTP.
Thanks in advance.
2 Accepted Solutions
uniemeyer
Hi, the octet string is the name of the network file.
For more Info:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a008009463e.shtml#task
New syntax is:
copy the running-config to a TFTP-server
snmpset -c private 1.3.6.1.4.1.9.9.96.1.1.1.1.14. integer 6 # delete temp. entry
snmpset -c private 1.3.6.1.4.1.9.9.96.1.1.1.1.14. integer 5 # create temp. entry
snmpset -c private 1.3.6.1.4.1.9.9.96.1.1.1.1.2. integer 1 # use tftp
snmpset -c private 1.3.6.1.4.1.9.9.96.1.1.1.1.3. integer 4 # source is running-config
snmpset -c private 1.3.6.1.4.1.9.9.96.1.1.1.1.4. integer 1 # destination is network file
snmpset -c private 1.3.6.1.4.1.9.9.96.1.1.1.1.5. ipAddress # TFTP-server IP
snmpset -c private 1.3.6.1.4.1.9.9.96.1.1.1.1.6. Displaystring test # name of the networkfie
snmpset -c private 1.3.6.1.4.1.9.9.96.1.1.1.1.14. integer 1 # do it
snmpget -c private 1.3.6.1.4.1.9.9.96.1.1.1.1.10. # read status of the action
"ccCopyEntryRowStatus" "1.3.6.1.4.1.9.9.96.1.1.1.1.14"
ccCopyEntryRowStatus OBJECT-TYPE
SYNTAX RowStatus
-- Rsyntax INTEGER {
-- active(1),
-- notInService(2),
-- notReady(3),
-- createAndGo(4),
-- createAndWait(5),
-- destroy(6)
"ccCopyProtocol" "1.3.6.1.4.1.9.9.96.1.1.1.1.2"
ConfigCopyProtocol ::= INTEGER {
tftp(1),
ftp(2),
rcp(3) }
"ccCopySourceFileType" "1.3.6.1.4.1.9.9.96.1.1.1.1.3"
ccCopySourceFileType OBJECT-TYPE
SYNTAX ConfigFileType
-- networkFile(1),
-- iosFile(2),
-- startupConfig(3),
-- runningConfig(4),
-- terminal(5)
"ccCopyDestFileType" "1.3.6.1.4.1.9.9.96.1.1.1.1.4"
ccCopyDestFileType OBJECT-TYPE
-- networkFile(1),
-- iosFile(2),
-- terminal(5)
"ccCopyServerAddress" "1.3.6.1.4.1.9.9.96.1.1.1.1.5"
ccCopyServerAddress OBJECT-TYPE
SYNTAX IpAddress
"ccCopyFileName" "1.3.6.1.4.1.9.9.96.1.1.1.1.6"
ccCopyFileName OBJECT-TYPE
SYNTAX DisplayString
"ccCopyState" "1.3.6.1.4.1.9.9.96.1.1.1.1.10"
ConfigCopyState ::= INTEGER {
waiting(1),
running(2),
successful(3),
failed(4)
"ccCopyFailCause" "1.3.6.1.4.1.9.9.96.1.1.1.1.13"
ConfigCopyFailCause ::= INTEGER {
unknown(1),
badFileName(2),
timeout(3),
noMem(4),
noConfig(5)
regards Ulrich Marzoli
uniemeyer
For more Info:
New syntax is:
SYNTAX RowStatus
-- active(1),
-- notInService(2),
-- notReady(3),
-- createAndGo(4),
-- destroy(6)
tftp(1),
ftp(2),
rcp(3) }
-- networkFile(1),
-- iosFile(2),
-- terminal(5)
-- networkFile(1),
-- iosFile(2),
-- terminal(5)
SYNTAX IpAddress
waiting(1),
running(2),
successful(3),
failed(4)
unknown(1),
badFileName(2),
timeout(3),
noMem(4),
noConfig(5)
Thank you for help. I used obsolete MIB, that, proposed by you is much more convenient.
