Very Strange problem
loyalty
Host 10.10.6.11on my Network can get to the eth interface on my Router 10.10.101.11 but not the Serial interface 192.23.101.18 hence they can't connect to services on a remote Network, a trace end at 10.10.101.11 .I can ping 10.10.6.11 sourcing the packets from the eth int but not the serial and there are no restrictions on my Router. I have a default route configred that allows connectivity between the 10.10 subnets. I would appreciate any help.
5 Replies 5
lwantland
Can you please post the router config? More info is needed to start diagnosing the issue.
Lance Wantland
loyalty
ip subnet-zero
ip nat inside source static 10.10.6.11 159.175.5.25
clock timezone est -5
interface Ethernet0
ip address 10.10.101.11 255.255.255.0
ip nat inside
no ip mroute-cache
interface Serial0
no ip address
encapsulation frame-relay
no ip mroute-cache
frame-relay lmi-type ansi
interface Serial0.41 point-to-point
ip address 192.23.101.18 255.255.255.252
ip nat outside
no ip mroute-cache
no arp frame-relay
frame-relay interface-dlci 41 IETF
interface Serial1
no ip address
no ip mroute-cache
shutdown
interface TokenRing0
no ip address
no ip mroute-cache
shutdown
router bgp 65312
network 159.175.5.0 mask 255.255.255.0
neighbor 192.23.101.17 remote-as 15282
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.101.2
ip route 159.175.5.0 255.255.255.0 Null0
HI,
Do you have a default route configured on the router from which you are pinging ( I assume it tobe 10.10.101.2, in your case) or atleast any route to get to the 192.23.101.16 network.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
lwantland
Your Ethernet IP address is on the 10.10.101 network, and the node your working with is on the 10.10.6 network. I don’t see a route anywhere in the router that tells it how to get back to 10.10.6 subnet. Add a static route pointing the 10.10.6 network out interface E0 and see what that does for ya.
Lance Wantland
After taking a second look, I also noticed that the inside global NAT address is being null routed. Any packet being send back to this host will be dropped in the bit bucket.
Lance Wantland
