10-08-2002 11:11 AM - edited 03-02-2019 01:55 AM
Host 10.10.6.11on my Network can get to the eth interface on my Router 10.10.101.11 but not the Serial interface 192.23.101.18 hence they can't connect to services on a remote Network, a trace end at 10.10.101.11 .I can ping 10.10.6.11 sourcing the packets from the eth int but not the serial and there are no restrictions on my Router. I have a default route configred that allows connectivity between the 10.10 subnets. I would appreciate any help.
10-08-2002 11:14 AM
Can you please post the router config? More info is needed to start diagnosing the issue.
Lance Wantland
10-08-2002 11:20 AM
ip subnet-zero
ip nat inside source static 10.10.6.11 159.175.5.25
clock timezone est -5
interface Ethernet0
ip address 10.10.101.11 255.255.255.0
ip nat inside
no ip mroute-cache
interface Serial0
no ip address
encapsulation frame-relay
no ip mroute-cache
frame-relay lmi-type ansi
interface Serial0.41 point-to-point
ip address 192.23.101.18 255.255.255.252
ip nat outside
no ip mroute-cache
no arp frame-relay
frame-relay interface-dlci 41 IETF
interface Serial1
no ip address
no ip mroute-cache
shutdown
interface TokenRing0
no ip address
no ip mroute-cache
shutdown
router bgp 65312
network 159.175.5.0 mask 255.255.255.0
neighbor 192.23.101.17 remote-as 15282
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.101.2
ip route 159.175.5.0 255.255.255.0 Null0
10-08-2002 11:50 AM
HI,
Do you have a default route configured on the router from which you are pinging ( I assume it tobe 10.10.101.2, in your case) or atleast any route to get to the 192.23.101.16 network.
10-08-2002 12:20 PM
Your Ethernet IP address is on the 10.10.101 network, and the node your working with is on the 10.10.6 network. I dont see a route anywhere in the router that tells it how to get back to 10.10.6 subnet. Add a static route pointing the 10.10.6 network out interface E0 and see what that does for ya.
Lance Wantland
10-08-2002 12:33 PM
After taking a second look, I also noticed that the inside global NAT address is being null routed. Any packet being send back to this host will be dropped in the bit bucket.
Lance Wantland
