Vlan encapsulation issue
wingu
I'm going to use Metro-Ethernet with fast ethenet port on 4ESW in 2851XM router.
Because the port can not work as L3, I set VLAN. But far end device is not Cisco. I need to dot1q for this connection but I can't.
How can I enable dot1q encapsulation for VLAN?
a.hajhamad
Level 4
Level 4
at the trunk links you can set the encapsulation to 802.1q.
I hope that i got your point!
Abd Alqader
minumathur
when you confire the trunk port, at the time, you can find encapulation type...
I hope this will sovle the problem
-Minu
ekhoo
Hi Winqu,
Try this... it should work.
Config sample
configure terminal
interface fastethernet 2/3
shutdown
switchport mode trunk
no shutdown
exit
Verify:
show interfaces fastethernet 2/3 switchport
show interfaces fastethernet 2/3 trunk
regards,
sean
