10-24-2011 11:16 AM - edited 03-03-2019 06:24 AM
I had my VWIC-2MFT-E1 Card working perfectly on my 2811 router up until last month when I discontinued the E1 service.
I just tried dropping and E1 line on the card today but the card was inactive.
After several hours of troubleshooting and making no headway, i decided to post the issue here maybe someone can tell me what the problem is.
So far, I have swopped the card in all the 4 HWIC slots (always powering down the router before removing or fitting the card) but no luck.
Below is the show diag result I get:
ROUTER#sh diag
Slot 0:
C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time 00:03:42 ago
Onboard VPN : v2.3.3
EEPROM contents at hardware discovery:
PCB Serial Number : FOC13154UQF
Hardware Revision : 1.0
Top Assy. Part Number : 800-26920-05
Board Revision : A0
Deviation Number : 0
Fab Version : 04
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20090416
Chassis Serial Number : FCZ131971BK
Chassis MAC Address : 0025.45c8.6ec8
MAC Address block size : 24
CLEI Code : COMWL10CRA
Product (FRU) Number : CISCO2811
Part Number : 73-10258-05
Version Identifier : V06
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 33 31 35 34 55 51 46 40
0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 05 42 41 30
0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 8E 30 C2 8B 46 43 5A 31 33 31 39
0x40: 37 31 42 4B C3 06 00 25 45 C8 6E C8 43 00 18 C6
0x50: 8A 43 4F 4D 57 4C 31 30 43 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
0x70: 05 89 56 30 36 20 D9 02 40 C1 FF FF FF FF FF FF
PVDM Slot 0:
64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8541-05
Board Revision : B0
Fab Version : 04
PCB Serial Number : FOC1239672T
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-64
Version Identifier : V01
0x00: 04 FF 40 03 EC 41 04 00 82 49 21 5D 05 42 42 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 32 33 39
0x20: 36 37 32 54 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 36 34 89 56 30 31 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 1:
Unknown WAN daughter card
Unknown EEPROM ver 255
EEPROM format version 255
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
And the show version:
ROUTER#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(24)T1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 19-Jun-09 15:13 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
ROUTER uptime is 12 minutes
System restarted at 19:00:08 GMT Mon Oct 24 2011
System image file is "flash:c2800nm-adventerprisek9-mz.124-24.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2811 (revision 53.50) with 772096K/14336K bytes of memory.
Processor board ID FCZ131971BK
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
254464K bytes of ATA CompactFlash (Read/Write)
I also noticed the message below whenever the router boots up:
%GT96K_FEWAN-1-UNKNOWN_WIC: slot 0, wic card has an unknown id FF
Would appreciate any help as to what next to do please.
Femi
10-24-2011 11:47 AM
Contact the TAC to have the faulty card replaced. That requires a support contract.
10-24-2011 11:57 AM
Hi Paolo,
Thanks for your comments.
Are you confirming that the card is faulty? Unfortunately, I dont have a support contract on that card any more.
Do you think I can replace it with an HWIC-2CE1T1-PRI card I have in store?
The function of the VWIC card was to create a VoIP trunk between my callmanager express running on a 2811 router and another IP PBX, more like a SIP trunk. Do you think the HWIC card will work in the same way?
Femi
10-25-2011 06:15 AM
You can buy a support contract at any time.
As replied in another post: For VoIP trunking, no interface card is necessary.
