2960 will not allow "switchport trunk encapsulation dot1q" CLI
stepnharp
I have a Cisco 2960 switch that is not allowing me to setup switchport trunk encapsulation dot1q on a trunking interface.
The show capabilities shows that the interface can use 802.1q, but when I try to CLI the command the work encapsulation is not an option.
Please advise with a solution.
Thanks, S
Model - WS-C2960G-24TC-L
SW Version - 12.2(44)SE6
SW Image - C2960-LANBASEK9-M
S1#
S1#sh int gi0/23 capabilities
GigabitEthernet0/23
Model:                 WS-C2960G-24TC-L
Type:                 1000BaseLX SFP
Speed:                 1000
Duplex:               full
Trunk encap. type:     802.1Q
Trunk mode:           on,off,desirable,nonegotiate
Channel:               yes
Broadcast suppression: percentage(0-100)
Flowcontrol:           rx-(off,on,desired),tx-(none)
Fast Start:           yes
QoS scheduling:       rx-(not configurable on per port basis),
                         tx-(4q3t) (3t: Two configurable values and one fixed.)
CoS rewrite:           yes
ToS rewrite:           yes
UDLD:                 yes
Inline power:         no
SPAN:                 source/destination
PortSecure:           yes
Dot1x:                yes
Multiple Media Types: rj45, sfp, auto-select
S1#
S1#
S1#
S1(config-if)#switchport ?
access         Set access mode characteristics of the interface
backup         Set backup for the interface
block         Disable forwarding of unknown uni/multi cast addresses
host           Set port host
mode           Set trunking mode of the interface
nonegotiate   Device will not engage in negotiation protocol on this
                 interface
port-security Security related command
priority       Set appliance 802.1p priority
protected     Configure an interface to be a protected port
trunk         Set trunking characteristics of the interface
voice         Voice appliance attributes
S1#
S1#
S1#
S1(config-if)#switchport trunk ?
allowed Set allowed VLAN characteristics when interface is in trunking mode
native   Set trunking native characteristics when interface is in trunking
           mode
pruning Set pruning VLAN characteristics when interface is in trunking mode
S1#
S1#
S1#
daniel.dib
Level 7
Level 7
Newer devices don't support ISL so you can only run 802.1Q. That means that there is no need for an encapsulation command because only one encapsulation is supported. If the device had support for ISL then you would also have that command.
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib
CCIE #37149
CCDE #20160011
6 Replies 6
daniel.dib
Level 7
Level 7
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
As Daniel correctly noted: +5
Just put in your "switchport mode trunk" (preferred) or let the interface autonegotiate trunk/aceess type.
Thanks for your answer.  Scott
Thxs Daniel,
This has been something that has been on my mind for while as i have not found a logcial explanation for this!
Sincerly
DaKING
RBeugnies
You can use the "show interface <interface> switchport" command to confirm the operational trunking encapsulation. ISL is not supported on newer devices.
