4500 - Changing from Layer2 to Layer3 on an interface causes switch to hang
craigallen
When issuing the NO SWITCHPORT command on a 4500 the switch hangs. The only workaround at the mement is to shut the interface down before changing processing layer on the interface.
7 Replies 7
Prashanth Krishnappa
What IOS are you running.. Are you able to recreate it everytime. I tested in lab and it works fine.
Switch#sh ver | include IOS
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(25)EWA, RELEASE SOFTWARE (fc1)
Switch#sh run interface fastEthernet 5/48
Building configuration...
Current configuration : 58 bytes
interface FastEthernet5/48
switchport mode access
end
Switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#int fas5/48
Switch(config-if)#no switchport
Switch(config-if)#ip add
Switch(config-if)#ip address 14.1.24.103 255.255.255.0
Switch(config-if)#end
Switch#
3d02h: %SYS-5-CONFIG_I: Configured from console by cisco on console
Switch#ping 14.1.24.1
Sending 5, 100-byte ICMP Echos to 14.1.24.1, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/3/4 ms
Switch#
I am able to replicate everytime. The TAC case is 601584841. Running 12.2.25EWA1
I tried it with EWA1 as well and it works fine. What kind of interface are you issuing "no switchport" under. What other config does it have?
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5S-M), Version 12.2(25)EWA1, RELEASE SOFTWARE (fc1)
Switch#
I attach show ver, show mod and show platform crashdump
YNRAMSS01#sho module
Chassis Type : WS-C4506
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 2 Supervisor IV 1000BaseX (GBIC) WS-X4515 JAE07371U09
2 6 1000BaseX (GBIC) WS-X4306-GB JAE0745060R
5 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE07440EK3
M MAC addresses Hw Fw Sw Status
1 000d.ed6d.2700 to 000d.ed6d.2701 3.0 12.1(12r)EW 12.2(25)EWA1 Ok
2 000b.5f3c.9c1c to 000b.5f3c.9c21 2.2 Ok
5 000e.3887.f9d0 to 000e.3887.f9ff 1.0 Ok
YNRAMSS01#
YNRAMSS01#sho ver
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Mon 25-Apr-05 15:37 by kellmill
Image text-base: 0x10000000, data-base: 0x114D5CF4
ROM: 12.1(12r)EW
Dagobah Revision 95, Swamp Revision 28
YNRAMSS01 uptime is 6 hours, 44 minutes
System restarted at 10:48:37 UTC Thu Jun 30 2005
System image file is "bootflash:cat4000-i5s-mz.122-25.EWA1.bin"
cisco WS-C4506 (MPC8245) processor (revision 7) with 524288K bytes of memory.
Processor board ID FOX074102UK
MPC8245 CPU at 333Mhz, Supervisor IV
Last reset from PowerUp
5 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
403K bytes of non-volatile configuration memory.
YNRAMSS01#
Crashdump
Probably not related to your problem but we ran 12.2(25)EWA1 for a couple of hours. Found CPU running about twice normal - we hit a bug (cannot remember the number).
Now running 12.2(20)EWA1 without a problem so far.
