Bank ATM machine problems
jbouwkamp
I have been working on moving a Bank's ATM machine over from an old 2520 router to a newer 3640 router. The ATM machine works using BSTUN with a loopback address. I duplicated the configuration on the 2520 EXACTLY onto the 3640 but could not get the ATM machine talking with the new router, as soon as I put the old router back in place the ATM machine came up. Is there something easy I am missing when trying to make this switch? I can post the running configs of both if needed but it would require alot of editing (It is a bank..heh).... thanks in advance!
10 Replies 10
a.manosca
Level 4
Level 4
hmm, sounds familiar....
Sometimes, changing the router and copying the exact config doesn't work,
specially if the router was changed from one platform to another.
I assume you are using the same cable to connect to the ATM machine.
This be could be a software issue and it would be better if you could review
the Release Notes for the IOS version of your 3640.
Some of the default 3640 configurations might have an effect.
This troubleshooting guide might help:
http://www.cisco.com/warp/public/100/bsc_guide2.html
deilert
Level 6
Level 6
If the serial interface is a dce do not forget to set the clock
The original 2520 router had the ATM plugged in on Serial 1 with no clock rate settings, the new 3640 router has the ATM plugged in to serial 1/0 with no clock rate settings. So does that sound like the clock rate is a correct issue? (I would test it but its a two hour drive to the site and no remote access...) thanks! I had the baud rate set to 9600 so should clock rate be the same? When I do a show bstun events it shows that the remote router is sending signals but the local ATM is showing no packets, would no clock rate setting cause this? thanks for the help!!
you only need to set the clock if your serial interface is acting as the DCE. do a sh controllers and see if a dce cable is attached. If the line goes up it is not a clocking issue.
Can you paste configs from the 2520 & 3640
john-lucero
This is probably to simple, but is the new serial interface shutdown? The problem may be as simple as typeing no shutdown on the interface in question.
no shutdown has been entered :)
If it was working with the 2520 router with no clock settings,then it shouldn't be the culprit. It would be helpful if you can post the IOS versions of the routers,
an extract of the config, and some debugs you have captured.
Here is the config of the 2520 that is working, I changed a few IP addresses and passwords to protect the innocent....
Current configuration:
version 11.0
service udp-small-servers
service tcp-small-servers
hostname
enable secret
partition flash 2 8 8
isdn switch-type ntt
bstun peer-name 172.172.27.1
bstun protocol-group 2 bsc
source-bridge ring-group 1000
interface Loopback0
ip address 172.172.27.1 255.255.255.0
no ip mroute-cache
no ip route-cache
interface Ethernet0
ip address 172.15.10.251 255.255.255.0
interface Serial0
no ip address
interface Serial1
description ATM machine G2 c9 P33
no ip address
no ip mroute-cache
encapsulation bstun
no ip route-cache
bandwidth 9600
no keepalive
full-duplex
ignore-dcd
nrzi-encoding
bstun group 2
bsc char-set ebcdic
bsc primary
bstun route address C9 tcp 172.120.2.254
interface Serial2
no ip address
shutdown
interface Serial3
no ip address
shutdown
interface BRI0
no ip address
shutdown
router eigrp 10
network 172.15.0.0
network 172.172.0.0
ip classless
ip route 172.62.237.0 255.255.255.0 172.176.42.100
ip route 172.176.42.254 255.255.255.255 172.176.42.100
line con 0
line aux 0
transport input all
line vty 0
password
login
length 40
line vty 1 4
password
login
end
and here is the 3640 configuration:
Current configuration : 1490 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Main
enable secret 5
ip subnet-zero
no ip domain-lookup
call rsvp-sync
interface Loopback0
no ip route-cache
no ip mroute-cache
interface FastEthernet0/0
ip address 172.15.10.254 255.255.255.0
duplex auto
speed auto
interface Serial0/0
description T1 to
ip address 172.20.17.2 255.255.255.252
fair-queue
interface Serial0/1
description T1 to
ip address 172.22.8.2 255.255.255.252
interface Serial0/2
description T1 to
ip address 172.22.9.2 255.255.255.252
interface Serial0/3
no ip address
shutdown
clockrate 2000000
interface Serial1/0
bandwidth 9600
no ip address
encapsulation bstun
no ip route-cache
no ip mroute-cache
no keepalive
full-duplex
ignore-dcd
nrzi-encoding
bstun group 2
bsc primary
interface Serial1/1
no ip address
shutdown
clockrate 2000000
router eigrp 10
network 172.15.0.0
network 172.20.0.0
network 172.22.0.0
network 172.172.0.0
no auto-summary
ip classless
no ip http server
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password
login
end
Can you paste in the output of sh int s1/0 and sh bstun
It might be Monday before I can do that, I am 2 hours away from site and don't want to make the drive till I have a solution and the person that is on site that could get the configs for me is away on training this week. I will post them Monday for sure and I appreciate all the help!
