09-15-2004 03:08 AM - edited 03-02-2019 06:29 PM
After upgading RAM from 128 MB to 256 MB on 2621XM commands: 'sh ver' + 'sh mem stat' show only 128 MB. 'Sh c2600' shows 2x128MB.
What's the problem and does the router use all the available memory. I enclose output from these commands.Thanks for help.
Router#sh ver
IOS (tm) C2600 Software (C2600-ADVENTERPRISEK9-M), Version 12.3(10), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 17-Aug-04 05:11 by kellythw
Image text-base: 0x80008098, data-base: 0x81FE20D4
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Router uptime is 2 hours, 16 minutes
System image file is "flash:c2600-adventerprisek9-mz.123-10.bin"
cisco 2621XM (MPC860P) processor (revision 0x301) with 126976K/4096K bytes of memory.
Processor board ID JAE0828PJE2 (3985486292)
M860 processor: part number 5, mask 2
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Bridging software.
TN3270 Emulation software.
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
1 Virtual Private Network (VPN) Module(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Router#sh c26
Router#sh c2600
C2600 Platform Information:
DIMM Slot 0:
DIMM Type : Dual-bank
DIMM Size : 128MBytes
DIMM Slot 1:
Router#
Solved! Go to Solution.
09-15-2004 04:48 AM
Currently the maximum memory used by Cisco IOS® Software is 128 MB. Some future Cisco IOS Software releases will use more than 128 MB of memory and will require this new ROMmon support to provide access to memory between 128 MB and 256 MB. Cisco IOS Software usage of more than 128 MB of SDRAM (in specific software images) is scheduled for
October 2004
http://www.cisco.com/en/US/products/hw/routers/ps259/prod_bulletin0900aecd800f51b6.html
09-15-2004 03:14 AM
it seems so that the second module is not seated correctly. You should reinstall the DRAM again. In the moment the router works with 128 MB DRAM.
Peter
09-15-2004 03:28 AM
Thanks for reply.
We have ugraded +20 routers, everyone behaves the same way.
Don't you think 'sh c2600' shows that DIMMs were installed properly?
Adam
09-15-2004 04:04 AM
Hi Adam,
yes, i thinks thats possible that the DIMM was installed wrong. Perhaps try to change the slots and last but not leat, the module is defect.
Peter
09-15-2004 03:51 AM
May be a bug in the "show vers" for this router although I couldn't find anything on the bug database. What does "show mem" give you?
Kevin Dorrell
Luxembourg
09-15-2004 04:48 AM
October 2004
10-01-2004 04:31 AM
Now there is 12.3.11T witch is supposed to support up to 256mb
