07-16-2006 05:03 AM - edited 03-03-2019 04:04 AM
Hi Expert
I Want to setup the HSRP Between the 2 Dist 6509-SUP1.PS Have a look to all my config in the Attachment!ps focus in the etherchannel config(L2)!etherchannel Config(L3) TOward the core!the HSRP Config in all VLANs!also the root primary & the root secondery!ps find where my mistake?advise to the optimum config!what u advise me!My config its correct?PS Help!PS HAVE A LOOK TO THE the Attachment!
10xs for ur time to help.
07-19-2006 12:05 AM
IC. Just reading an article that referred by other Netpro. You can also consider GLBP.
http://www.cisco.com/en/US/products/ps6600/prod_presentation0900aecd801790a3.html
For the HSRP config., your new configuration is fine and just need to add another HSRP group w/ another virtual IP address (e.g. .4). Then you allocate the LAN user to two groups, one point to 1st HSRP group V.IP, another group point to 2nd HSRP group V.IP. Please read the link and it mentioned the operation.
07-19-2006 12:17 AM
Hi!
As i mentioned in the second post of mine, if you need to load-balance then I think you should go for GLBP. Whereas if your only need is redundancy for fail-over, then HSRP is good enough.
You'll find the links for GLBP and HSRP in the above posts of mine.
Hope this helps.
AbhisheK
Please rate all posts!!!
07-19-2006 03:38 AM
friends ya rit can i use GLBP;But my 6509 its Sup1!
10xs
07-19-2006 04:44 PM
Please check the release notes of your Sup OS to determine the possibility to use GLBP. For a simple initial setup, I suggest to try multi-HSRP first then GLBP.
07-19-2006 08:49 PM
Certainly you can use GLBP!!! And its not difficult to configure either. Almost the same way as HSRP.
To check whether your switch supports it or not, enter the following commands:
- enable
- configure terminal
- interface vlan 'id'
- glbp ?
If the prompt says "unrecognized command", then your switch doesnt support GLBP. On the other hand if your switch shows command options then your switch supports GLBP!!!
Hope this helps.
AbhisheK
07-19-2006 09:48 PM
Thanks. Abhishek. I learn more from you.
07-19-2006 10:04 PM
6509-1
interface Vlan10
ip address 10.20.20.1 255.255.255.0
ip helper-address 10.20.3.200
no ip redirects
standby 10 ip 10.20.20.3
standby 10 timers 3 9
standby 10 priority 110
standby 10 preempt
no sh
ex
6509-2
interface Vlan10
ip address 10.20.20.2 255.255.255.0
no ip redirects
standby 10 priority 105
standby 10 preempt
no sh
ex
hOW Can i configure MHSRPIN THE ABOVE Can u PS Editing my config?what is the Benifets of MHSRP Rather than HSRP IN MY SITUATION
10XS
07-19-2006 10:45 PM
You have below :
6509-1
interface Vlan10
no ip redirects
standby 10 preempt
standby 20 ip 10.20.20.4
standby 20 timers 3 9
standby 20 priority 105
standby 20 preempt
6509-2
interface Vlan10
no ip redirects
standby 10 preempt
standby 20 priority 110
standby 20 preempt
Just add one more group w/ new virtual IP and reserve the priority. Then one group of user will point to the .3 as GW and the other group point to the .4 as GW. You can MANUAL load-sharing the traffic at two routers but require additional admin work on the IP GW assignment at user PC.
Hope this helps.
07-19-2006 11:50 PM
Sorry. Should be reverse the priority.
07-20-2006 12:32 AM
what do u mean by rverse the priority!
10xs
07-19-2006 10:07 PM
You are welcome!
07-20-2006 12:26 AM
HI
Now i have 2 virtual ip.whcih one sould i assign in my DHCP Scope?as DG.
10XS
07-20-2006 12:32 AM
As I mentioned before, you have to assign part of the user to use ,3 and other user to use .4 as the default gateway.So 2 profiles in DHCP server is required.
07-20-2006 02:17 AM
hi Jakcy!
i tested the HSRP IN VLAN 10.but when i Disconnected the Active.30 time out occur until the standby beame Active than i received reply.how can reduce the time out?B/W: SWITCH 1 ACT AS ROOT BRIDGE
SWITCH2 ACT AS SECONDERY ROOT BRIDGE
10xs
07-20-2006 03:48 AM
PS;Can u Help how to reduce these 30 Timeout until the Standby became Active?
10xs
