Integrating routing and switching
ptorrico
Hi all.
How can I integrate a routing network into a switching network.
I mean try to have vlans and routed networks working togeher.
Pablo
efrahim
Level 4
Level 4
Can you plz describe in more detail what specially you are trying to achieve,,
thanks
Ok, I have a routed network and I want to put my new equipment working in it.
In the new equipment there is a 6506 catalyst and several 3550(48) switches.
The idea is to have vlans in the 6506 and make to work with the current routed network.
I define a vlan 100 in the 6506 .
In the rsm is the
int vlan 100
ip add 172.16.40.254 255.255.255.0
the management vlan1 is 172.16.1.0
When I try to reach the other subnets in the routed part ie 172.16.2.0, 172.16.4.0 I can´t.
I defined a eigrp in the rsm and still doesn´t work
Then I removed an its the same
It this make clear the idea?
Pablo
I solve the issue
