03-07-2020 07:30 AM
Hi Folks,
I am looking to replace my ASA 5510 with a 5512-x or 5515-x and looking for a little advice to ensure I get the right version to enable future learning/protect my small network.
Essentially I have my CCNA R&S and looking to start either my CCNP or CCIE now the new certifications have been released. So this firewall will be used in a lab environment and protect my home network. The difficulty is that I am limited to purchasing second hand devices as Cisco partners I have spoken to will not sell to an individual. As a result, I cannot get access to software releases and variation which means I need to get the correct OS and hardware config. Price, as always, is a factor.
My intention is to get a 5512-x or 5512-x with Firepower. I believe I need:
- OS version 9.2 or later (higher the better)
- SSD and SFR installed
The static licence will enable Firepower?
Any additional considerations or suggestions on were to pick up EOL devices that partners will provide a support contract to an individual?
Any advice and guidance is appreciated,
Solved! Go to Solution.
03-07-2020 07:52 AM
If i were you and preparing for CCIE sec or enhancing my skill set i wont spent money too much I shall make sure i have a server (with a lot of power with RAM and storage) you can get second hand server with good spec around $700.
everything is going software. day are gone when you needed a hardware to do your study etc. I did my ccie security with all software were virtual on the server. EVE-NG and GNS3 is good start.
firepower you can use FTD as this is the future of cisco firewalls. ASAv you can use/download in insitall in you lab. its all depend how you want to spent...ISE you can do a virtual appliance.
03-07-2020 07:52 AM
03-07-2020 08:01 AM
If you plan to learn for like CCNP, go with virtualisation,you'll have no issues. If you plan on learning for CCIE, depending which one, there are still many things which are supported ONLY in hardware. For example, for CCIE Security you would need physical ASA's to learn clustering and you would need a physical switch for some advanced 802.1x features (like IBNS 2.0).
Cristian Matei.
03-07-2020 08:06 AM
@Cristian Matei I did ASA's clustering and advanced 802.1x features (like IBNS 2.0) virtually all on server no physical hardware need at all. The only thing i see in long run is FTD multi-instance for this to learn you need a physical hardware.
03-07-2020 08:39 AM
Thanks to you both,
I am running Server 2012 with a reasonable spec to comfortably run a number of Virtual Machines on top of a few other services. A few extra Network cards have been installed to connect VM's to different points of my lab. I appreciate the recommend on Virtual tools, they are being installed now.
While I primarily use packet tracer, the lab has been useful physically deploying, learning products/reference features and maintaining as my home network. Basically, the firewall will be to tie my 2 FTTC routers together and run my internal network/lab because i loose 30 Mbps of bandwidth with ZBF enabled on my 88VA's. Therefore I will be getting a firewall but won't push my budget for features I am more than likely not going to utilize.
Your comments have been useful, thanks.
03-07-2020 09:40 AM
ASAv does not support multiple context (the commands are not even there), as for clustering, even though commands are there, it doesn't really work. How did you test these features in virtual? As for IBNS 2.0, there are many features which are supported only by the hardware switches.
Cristian Matei.
03-08-2020 03:55 AM
03-08-2020 05:36 AM
Do not mean to hijack this. but if you search around you can see there are images which can be install in eve-ng and on GNS3. which include the multi context and even asa clustering. there two image run in eve-ng/gns3 and give you a feel like you working on an actual hardware. (having said that, there are limitation on throughput but as long as you want to learn and polish your skill-set this is a great tool). on the other hand you have virtural ISE/WSA/FMC/FTD. even you can do a ZBFW in eve-ng/GNS3.
I was a fun of hardware but end of the day if i am learning I have to look my budget (electric cost/hardware etc). if you can afford hardware thats good. but if you need alternative there is always a way. it depends how to want to use your resources.
there is a difference between a learner and working in production network. when you are a learner you always try to find a way which is cost saving as we can not afforad cisco expensive kit. for example even i can not afforad buying ASA5512 with lic. too much cost. Cisco itself understand and kind to learn to give us 90 day trail lic for FTD/FMC/ISE etc.
as i said earlier and i stick with it if i where at your i would build my all lab virtual instead of physical. during my ccie day i always relay on virtual instead of going physical (as physical always cost me more).
i hope you understand what i am trying to say.
03-14-2020 09:21 AM
