Browsing not working from lan
fmatrine
Dear Sir,
We have a lan network 192.168.10.0/24
Topology of our network is LAN-PIX(506E)-Internet Router-ISP...
We hv configured the router and pix firewall as per our requirement.
Requirement is to allow lan users to access internet.
we are able to ping the outside but unable to browse from lan PC.
PC has default gateway as firewall internal interface.also we hv configured DNS in the network setting of PC....but still we are not getting internet pages...
we can ping the DNS and external world from lan.
we hv done PAT on Pix firewall for the Translation of private to public ip address.
PIX firewall config:-
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security10
enable password xxxx
passwd xxxx
hostname firewall
fixup protocol dns maximum-length 512
fixup protocol ftp 21
no fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
no fixup protocol rsh 514
no fixup protocol rtsp 554
no fixup protocol sip 5060
fixup protocol sip udp 5060
no fixup protocol skinny 2000
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list outside_access_in permit icmp any any
access-group outside_access_in in interface outside
access-list in_access_outside permit tcp any any
access-list in_access_outside permit udp any any
access-list in_access_outside permit ip any any
access-group in_access_outside in interface inside
pager lines 24
logging timestamp
logging trap debugging
logging history notifications
logging host inside 192.168.18.4
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside XXX.64.9.2 255.255.255.240
ip address inside 192.168.10.1 255.255.255.0
ip verify reverse-path interface inside
ip audit info action alarm
ip audit attack action alarm
no pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 XXX.64.9.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
snmp-server host inside 192.168.18.5
no snmp-server location
no snmp-server contact
snmp-server community xxxx
snmp-server enable traps
floodguard enable
telnet timeout 2
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxxx
: end
Kindly guide for the same
rgds
7 Replies 7
jmia
Level 7
Level 7
Firstly, by default the pix will allow any inside traffic out, so, I would suggest to you to clear the ACL's for the inside interface and the outside interface first.
After this you can start to configure ACL's and statics for any traffic you want to permit in from the outside on the outside interface, for example SMTP etc.
When you have cleared the ACL's make sure to save with write mem and also, a clear xlate would be a good idea too.
Let me know if this helps.
Jay
Still not working...
I can ping internet sites (e.g, www.yahoo.com) by name but still i cannot browse the same site from my PC.
Kindly advice
rgds
rpathani
Hi Kindly give the following commands on the Pix from the config terminal mode in the order in which these are writen:
clear access-list in_access_outside
fixup protocol dns maximum-length 1500
clear xlate
clear arp
clear local
write mem
Now try to access internet from your internal lan. If this dosen't work then try changing the primary and secondary DNS server address on the host and then see if this works for you.
It seems to be that the internal hosts are not resolving dns queries.
I'm sure this would help you.
Rahul Pathania.
I have a similar problem but the above solution does not work.
Any other suggestions?
rpathani
And yes, in addition to this the config you sent does not look that to be of Pix-506E as stated by you since you have mentioned about 3 interfaces on Pix and 506E model has only 2 interfaces.
Also to let you know that in most of these cases it is a internal DNS Server issue.
Rahul Pathania.
Hi Rahul,
Thnx for the guidance....
Will try this and get back with the results...
Also is the In_Out access-list not required...
rgds
rpathani
Yes, we do not require in_access_outside access-list as by default the traffic is permitted from higher to lower security level.
1) For traffic flow from higher to lower security, we need:
nat and global
OR
static
2) For traffic flow from lower to higher security, we need:
static and access-list.
Warm Regards,
Rahul.
