Configuration Asa 5585
Recently we had a problem with the handle and it was when we made the failover that we did not have the exact same configuration. Supposedly they should be in sync. The query is, apart from doing a show failover that gives us the output of context active or context standby ready, is there an snmp variable that can be queried to find out if they have the same config or a command that can be launched?
Thanks in advance.
balaji.bandi
If this is Active/Active Multi context FW, make sure the configuration changes to be done always on Active Node Only if any changes are done in Standby accidentally (they can not be synched and it will be overridden with Active one- also not recommended any changes in Standby)
here is the document explain about sync.
https://www.cisco.com/c/en/us/td/docs/security/asa/asa90/configuration/guide/asa_90_cli_config/ha_active_active.html#65140
BB
balaji.bandi
BB
HI,
This is active / passive configuration. Changes are normally made in the active context via asdm.
However, I am thinking that since we use rancid to back up the configuration, i will talk to the toolmates who handle the monitoring tool and that you can connect to a rancid and make a differential of the backup adn then so shows as alarm whether or not the settings of both contexts are the same.
I will review the document you indicate.
Thank you. @balaji.bandi
