12-23-2018 09:47 AM - edited 03-10-2019 01:08 AM
So we have a couple of dedicated MPLS and point to point Ethernet links provided by an ISP to link all of our offices, the question has arisen if there is anyway we can protect our data if someone from the ISP sniffs it, as it goes across their network, so far we have come up with running an IPSEC VPN over the dedicated point to point links, but it's not great solution, is there any other technology made for this situation that we could use? Essentially, we want everything that leaves our device to go onto the ISP network to be encrypted. Changing ISP is not really an option since the country we are operating in, everything is owned by the government and they're all the same.
12-23-2018 12:32 PM
If you have many links, they also need to talk to each other.
Look at option of DMVPN or GETVPN.
https://www.cisco.com/c/en/us/products/security/group-encrypted-transport-vpn/index.html
12-25-2018 07:58 PM
Thank you for reply, the only problem is we are using ASA and this does not support the DMVPN or GetVPN, I will see if we can use a router instead. Thanks for the idea.
12-23-2018 08:55 PM
Whats the issue with ipsec?
12-24-2018 12:04 AM
