My Cisco Agents wont register with Mngmt Center
vlecha
Im using the 4.0.1 build. My workstations have sucessfully downloaded the agent but are unable to communicate with the Mngmt server. I did a packet capture and I receive a checksum error. The Mngmt Server has the correct license...Any ideas?
5 Replies 5
nkhawaja
hi,
check the log file named csalog.txt on the agent, it should give more information about the issue.
Nadeem
The log unfortuntaley only points out the painfully obvious with no other clues. Here is the output from the log
[2004-08-02 03:52:19.838] [PID=532] [Csamanager]: Registering with server enosc-1f98ewvri, Failure (2035)
[2004-08-02 03:52:19.838] [PID=532] [Csamanager]: Will retry to register in 10 sec
[2004-08-02 03:52:19.898] [PID=532] [Csamanager]: Archived previous log messages into logfile 'C:\Program Files\Cisco\CSAgent\log\csalog.015.txt'
[2004-08-02 03:52:30.043] [PID=532] [Csamanager]: Registration failed without message Error code=2035
[2004-08-02 03:52:30.043] [PID=532] [Csamanager]: Registering with server enosc-1f98ewvri, Failure (2035)
This log message obvisouly shows up countless times. Any other suggestions or ideas?
The error code 2035 translates to
OKENA_STATUS_INVALID_LICENSE = 2035,
You need license for your agents.
Nadeem
Huh?? Under Licenses in the Mngmt Center I show a valid license for 3 agents, but maybe they gave me a wrong license I will check with my vendor. Thanks for you timely responses and help
Sorry about my last post. I didnt check the csalog for CSAMC. The error I receive there is
Feature: desktopagent
License path: D:\PROGRA~1\CSCOpx\CSAMC\cfg\CSA4.0-NFR.lic
FLEXlm error: -5,357
For further information, refer to the FLEXlm End User Manual,
available at "www.globetrotter.com".
[2004-08-02 06:58:30.953] [PID=3948] [webagent]: Agent Req 'Registration' Failure(2035), ip=192.168.2.151, huid={6DF14834-AA29-4FFF-B65D-ACA74049C1CD}
[2004-08-02 06:58:34.750] [PID=3948] [webagent]: No such feature exists
No such feature exists?? I looked on google and Flexlm -5 error code means exactly that:
http://www.abaqus.com/support/flexlm/chap14.htm
Any more ideas, suggestions or any recommendations on who I should contact would be greatly appreciated?
Victor
