06-03-2009 08:46 AM - edited 03-09-2019 10:20 PM
what are the commands to configure an interface as the outside interface on a router and leave all others as inside
Solved! Go to Solution.
06-03-2009 08:59 AM
ip inspect INSPECTNAME in
the easiest way to use that command is to set up your inspection rules and then apply that command on the inside interface.
06-03-2009 08:52 AM
can you be more specific? NAT? IOS Firewall? etc?
Or do you mean in general?
06-03-2009 08:54 AM
IOS Firewall
06-03-2009 08:59 AM
