problem using NBAR for filtering
szamani
i want to use NBAR for filtering some URLs. i did following config and it works good for LAN segment users but when i enter commanf "service-policy ..." in inteface group-async i got the error "CEF or distributed CEF switching is required for NBAR 'match protocol' command" 8 times and the filtering doesn't work for dialin users. Please help me. Thanks.
class-map match-any xxx
match protocol http url "*sex*"
match protocol http url "*xxx*"
match protocol http url "*teen*"
match protocol http url "*anal*"
match protocol http url "*fuck*"
match protocol http host "*sex.com*"
match protocol http host "*xxx.com*"
match protocol http host "*porno*"
match protocol http host "*teen*"
match protocol http host "*anal*"
match protocol http host "*fuck*"
policy-map mark-xxx
class xxx
set ip dscp 1
interface FastEthernet0/0
ip address 192.168.100.254 255.255.255.0 secondary
ip address 213.176.67.1 255.255.255.224
ip nat inside
no ip mroute-cache
duplex auto
speed auto
service-policy input mark-xxx
interface Ethernet2/0
bandwidth 512
ip address 213.176.67.33 255.255.255.224
ip access-group 102 in
ip access-group 111 out
ip nat outside
half-duplex
interface Group-Async1
bandwidth 38
ip unnumbered FastEthernet0/0
ip wccp web-cache redirect in
encapsulation ppp
ip tcp header-compression
async mode interactive
peer default ip address pool pool1
ppp authentication pap callin
group-range 33 48
access-list 111 deny ip any any dscp 1 log
access-list 111 permit ip any any
d-garnett
Level 3
Level 3
you need to enable cef (Cisco Express Fowarding) in global configuration mode. You should also enable cef accounting on the interface if your processor can handle it. Also know that NBAR can have a perfomance effect on your router if many match statements are in place (I'd feel safe using at least a 3700 if their is heavy traffic).
XXXXXXXX(config)#ip cef ?
accounting Enable CEF accounting
load-sharing Load sharing
table Set CEF forwarding table characteristics
traffic-statistics Enable collection of traffic statistics
afilandro
type "ip cef" in your config
