11-27-2003 01:47 AM - edited 03-09-2019 05:40 AM
We have an internet connection from a pix 515e via a leased line router.
the users can access the internet no problem and also we can get people accessing our web server but we have no outbound or inbound email.
we have our own internal email server.
out internal email server is set to 192.168.1.3 and we have a static command in the pix to say
static (inside,outside) 1.1.1.1 192.168.1.3
(1.1.1.1 has been changed for security purposes)
so the real world address for out mail server is 1.1.1.1 and this is translated to 192.168.1.3 this does not work, no email at all.
but, we have a web server 1.1.1.2 real world address which gets translated to 192.168.1.11 and this works without any problems.
outbound internet is also working perfectly.
please see our config below.
: Saved
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security4
enable password xxxxx
passwd xxxxx
hostname TheWall
domain-name xxx.com
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list 101 permit tcp any host 1.1.1.1 eq smtp
access-list 101 permit tcp any host 1.1.1.2 eq www
access-list 101 permit tcp any host 1.1.1.2 eq login
access-list 101 permit icmp any any
access-list 101 permit icmp any any echo
access-list 101 permit icmp any any echo-reply
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
mtu intf2 1500
ip address outside 1.1.1.10 255.255.255.0
ip address inside 192.168.1.10 255.255.255.0
no ip address intf2
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
global (outside) 1 interface
access-group 101 in interface outside
conduit permit icmp any any
conduit permit udp any any
route outside 0.0.0.0 0.0.0.0 1.1.1.100
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxxxxxx
: end
11-27-2003 06:11 AM
Hi Chris,
Have a read of the following document and let me know if it helps or if you need further assistance:
Regards - Jay.
11-27-2003 06:32 AM
Hi Jay,
Thanks for the web link but this is nearly the same as what we have.
we have the static commands in and the access-lists required.
the nat (inside) 1 0.0.0.0 0.0.0.0
these 2 statements are need as we are associating everything that goes outbound to the internet to the outside interface as we can only use this address and the other outside address are taken up by www,mail and other servers.
can you please help.
regards
chris
11-28-2003 07:56 AM
Hi Chris,
static (inside,outside) tcp
access-list mail_in permit tcp any host
access-group mail_in in interface outside
Remember to execute command clear xlate after the modifications and save with command write memory.
Hope this sorts out your problem and let me know how you get on.
Jay.
11-29-2003 04:56 AM
i tried this but did not work, it works for the www address but not the smtp
12-01-2003 12:35 AM
Chris -
Forgot to add on my previous post, try adding the following command on the config:
> no fixup protocol smtp 25
Let me know your outcome.
Jay.
11-28-2003 10:46 PM
can you ping the smtp box from the pix:
pix1# ping inside 192.168.1.3
1. what is the gateway set for the smtp server? (shld be inside IP of PIX)
2. can the www box telnet to port 25 on the smtp box?
3. can you ping from the smtp box to the inside interface of the pix?
4. If yes to the above then check your ACE in the ACL for smtp , is there any count on that is it increasing when you try to access it from the ouside in?
5. If not then you have an ACL issue somewhere maybe. use "debug icmp trace" on the pix w/o the "" and see where the packet is going.
This should point you in the right direction to solve the problem.
- Jeff
12-02-2003 07:37 AM
Did you solve this problem? I am having the same problem with my Mail server and PIX. Do you have to have a static (inside,outside) translation for your Mail server?
12-02-2003 08:21 AM
hi,
no this did not solve my problem and i am still having major issues.
The config has a static (inside,outside) translation but yet this is not working for my mail server.
have you the same issue as well and have you managed to get round this
12-02-2003 08:25 AM
Hi Chris,
Can you post your PIX config to me at jmia@ohgroup.co.uk and please remember to change real IPs and passwords etc.
And did you try the no fixup smtp as I suggested earlier? make sure to clear translations with clear xlate after static or ACL modifications.
Jay.
12-02-2003 08:37 AM
I think I just found my mistake. I won't know until I test it tonight. I forgot to change the default gateway on my mail server when I put in the new PIX.
12-02-2003 10:23 AM
Here what I think my other problem is. Users on the outside send e-mail to us at johndoe@co.rock.wi.us. From outside our network I did an nslookup on co.rock.wi.us and found that the address that came back was only the ip address of my outside interface. I didn't see the address I'm using to statically map a translation to my internal Mail server. Therefore I would need my ISP, who hosts my external DNS, to change the address for smtp traffic.
12-03-2003 07:51 AM
can you email your config please, change the real world addressing remember.
i want to compare it with mine , i am having issues still
12-03-2003 11:04 AM
If this is a MS Exchange server, try using this command:
MS Exchange uses ESMTP.
12-04-2003 01:12 AM
Thanks for that information, will come in very usefull.
what access-list lists did u have in place to get this working ???
