05-04-2006 05:55 AM - edited 03-09-2019 02:48 PM
I have a PIX firewall with a dmz interface that VPN users come into. I would like to be able to define that a range of 4 source ip addresses coming into the dmz interface be able to go anywhere on the inside interface. I know I need an acl permitting the ip range through, but I need to set the translations so that they can go to any destination on the inside via its true inside address. I can't create a blanket config like "static (dmz,inside) 10.0.0.0 10.0.0.0, because that will conflict with other statics between those interfaces and I don't want any ip coming into the VPN dmz to be able to go to these inside addresses. How do I set it up so that only the 4 static ip addresses can go to any destination inside address without the normal need for creating a static statement for each destination they need to go, at the same time without this config interfering with anything else?
05-04-2006 06:35 AM
Use NAT exemption (nat 0 access-list)
Something like
permit ip (your 4 range) to (your internal network)
It's less flexible than static statement but if you dont have any need(now and in the future) for nat between those two interface, it's a simple config and can handle two way trafic.
Work's for me, I have 6 networks in my DMZ(VPN and AS) and I use that solution. NAT toward outside and NAT exemtion to inside.
05-04-2006 06:44 AM
I think the feature you're looking at is more or less similar to "outside NAT".
Maybe you can follow basic guide at the following url:
Maybe you can do something like this, since you mentioned it was for 4 IP Addresses:
nat (outside) 1 x.x.x.1 255.255.255.255 outside
nat (outside) 2 x.x.x.2 255.255.255.255 outside
nat (outside) 3 x.x.x.3 255.255.255.255 outside
nat (outside) 4 x.x.x.4 255.255.255.255 outside
global (inside) 1 y.y.y.1
global (inside) 2 y.y.y.2
global (inside) 3 y.y.y.3
global (inside) 4 y.y.y.4
Then use ACL to permit the 4 addresses to reach any internal IP/subnets.
Hope this helps.
Rgds,
AK
05-04-2006 07:21 AM
I'm a little confused. Doesn't doing the nat(outside) translate the source ip addresses to whatever is defined with the matching global statement? If I'm going from a dmz interface to a inside interface, I need a translation on the destination, not the source. Correct?
My internal network on the inside of the PIX is a 10.0.0.0/8, I want these 4 vpn users to be able to access any destination 10.0.0.0 address without having to translate each destination host individually. If I wasn't worried about it conflicting with other config, I'd just do a "static (inside,dmz) 10.0.0.0 10.0.0.0 netmask 255.0.0.0". However, that would be a blanket translation for anyone going to the inside network, I only want it to affect the 4 vpn users. right now, for example, if I want a specific vpn user to access the 10.1.1.1 server, I have to do a "static (inside,dmz) 10.1.1.1 10.1.1.1 netmask 255.255.255.255". As there are countless inside hosts that these 4 vpn users could be accessing, I don't want to have to do an individual translation for each possible destination address.
05-04-2006 08:04 AM
So you want to allow certain IPs on a DMZ (not the outside) to get to the inside?
This is low -> high security level, therefore you need static NAT (for inside IPs) and ACL entries, along the lines of:
static (inside,dmz) inside_subnet inside_subnet netmask ...
access-list in_dmz permit specific_IPs inside_IPs
05-04-2006 08:43 AM
If I did that:
How would this lock it down to only the 4 vpn users? Wouldn't that be a global command that affected everything? Is there a way to static against an access-list?
05-04-2006 02:24 PM
I still think you can use nat exemption
access-list no-nat permit ip 10.0.0.0 255.0.0.0 10.0.0.0 255.0.0.0
access-list no-nat permit icmp 10.0.0.0 255.0.0.0 10.0.0.0 255.0.0.0
nat (dmz) 0 access-list no-nat
