08-13-2010 02:22 AM
My CS-MARS-20-K9 version: 4.2.1 (2251). I want to upgade to lastest version 6.0.7.
I see two way to upgrade:
method 1. re-image using a 6.0.1 dvd recovery. and upgrade use other patch: 6.02, 6.03, 6.0.4, 6.0.5, 6.0.6, 6.0.7. I lose my database this way.
Method 2. upgarde to 4.3.6 (upgrade around 15 patch from 4.2.1 to 4.3.6) so I can upgrade to 6.0.1 and upgrade use other patch: 6.02, 6.03, 6.0.4, 6.0.5, 6.0.6, 6.0.7. I wont lose database.
Is this correct method?
I know csmars v 4.x using license is 25 key string. And cs-mars use licence file recently. If I upgrade as above, I still can use 25 key string license?
thank you
Solved! Go to Solution.
08-14-2010 09:13 PM
Yes the two options you have mentioned are correct. The only difference being (as mentioned) in method 1 you will lose all the configuration while in method 2 you will be migrating the data from 4.3.6 to 6.0.1.
"I know csmars v 4.x using license is 25 key string. And cs-mars use licence file recently. If I upgrade as above, I still can use 25 key string license?"
The license format depends only on the MARS appliance you have. For all MARS Gen1 appliances, the license is a 25 character string while for Gen2 appliances, it is a license file. So basically, the license format following the upgrade of your MARS will still be the 25 character string.
All the best!!
Prapanch
08-16-2010 04:49 AM
To clarify the process, if you are going to re-image the CS-MARS, you may re-image directly to the latest release (currently 6.0.7). You do not need to re-image to 6.0.1 and then upgrade to the most recent release.
Recovery DVD ISOs can be found here:
http://www.cisco.com/cgi-bin/tablebuild.pl/cs-mars-recovery
Scott
08-14-2010 09:13 PM
All the best!!
Prapanch
08-16-2010 04:49 AM
Scott
08-16-2010 06:32 PM
thank you,
Iam trying to upgrade using method 2 and will use 6.0.7 recovery dvd.
08-17-2010 03:04 AM
For the second method (upgrade to 4.3.6 first), you will need to re-image to 6.0.1 and not 6.0.7. The import process of the 4.3.6 data requires that you be running release 6.0.1. You will then need to upgrade to each successive release until you reach 6.0.7.
My comment on re-imaging directly to 6.0.7 was based on the first method where no data retention is maintained/
Scott
08-17-2010 03:43 AM
yeah, ty
