02-19-2003 07:05 PM - edited 03-09-2019 02:09 AM
02-20-2003 10:53 AM
Hi Mercy,
Can you post a more detail message. Thanks!!
Arul
02-21-2003 10:17 AM
Hi Arul,
Sorry I must have pressed enter so soon, any way, here's my scenario..
My pix515 is currently in parallel with 3005, no routers in the scene.. they're directly connected to the DSL. VPN clients are authenticated via NT domain.
I am planning to connect branches to HO, via vpn, terminating to 3005, tried to simulate but I was having problems, I was advised to put concentrator on dmz instead. Now I have made pix and 3005 ping each other.. but when I test authentication from 3005, it failed, that's why my vpn client could not establish tunnel.. I wonder if Im missing access-list or static..
below is the summary of my setup.
pix inside - 10.11.0.1
pix dmz - 10.50.0.1
pix outside - 66.13.1.2
gateway - 66.13.1.1
3005 outside - 10.50.0.2
3005 gateway - 10.50.0.1
3005 ip pool - 192.168.1.1-100
Here's my pix config:
hostname pixfirewall
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list ipsec permit ip 10.11.0.0 255.255.0.0 10.14.0.0 255.255.0.0
access-list europe permit ip 10.11.0.0 255.255.0.0 192.168.1.0 255.255.255.0
access-list nonat permit ip 10.11.0.0 255.255.0.0 10.14.0.0 255.255.0.0
access-list nonat permit ip 10.11.0.0 255.255.0.0 10.15.0.0 255.255.0.0
access-list nonat permit ip 10.11.0.0 255.255.0.0 192.168.1.0 255.255.255.0
access-list nonat permit ip any 192.168.0.0 255.255.255.0
access-list nonat permit ip 10.11.0.0 255.255.0.0 10.50.0.0 255.255.0.0
access-list 100 permit tcp any host 66.13.1.4 eq smtp
access-list 100 permit tcp any host 66.13.1.4 eq pop3
access-list 100 permit udp any host 66.13.1.3 eq isakmp
access-list 100 permit icmp any any
access-list 100 permit esp any host 66.13.1.3
access-list 100 permit tcp any host 66.13.1.3 eq 10000
access-list 200 permit ip 192.168.0.0 255.255.255.0 10.11.0.0 255.255.0.0
access-list 200 permit ip 10.50.0.0 255.255.0.0 10.11.0.0 255.255.0.0
access-list 200 permit icmp any any
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside 66.13.1.2 255.255.255.248
ip address inside 10.11.0.1 255.255.0.0
ip address dmz 10.50.0.1 255.255.0.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpnpool 10.15.0.101-10.15.0.105
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
failover ip address dmz 0.0.0.0
pdm history enable
arp timeout 14400
global (outside) 1 interface
global (dmz) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 10.11.0.0 255.255.0.0 0 0
nat (dmz) 0 access-list nonat
nat (dmz) 1 10.50.0.0 255.255.0.0 0 0
alias (inside) 10.11.0.8 66.13.1.4 255.255.255.255
static (inside,dmz) 10.11.0.0 10.11.0.0 netmask 255.255.0.0 0 0
static (inside,outside) 66.13.1.4 10.11.0.8 netmask 255.255.255.255 0 0
static (dmz,outside) 66.13.1.3 10.50.0.2 netmask 255.255.255.255 0 0
access-group 100 in interface outside
access-group 200 in interface dmz
route outside 0.0.0.0 0.0.0.0 66.13.1.1 1
route dmz 192.168.0.0 255.255.255.0 10.50.0.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip
0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set jersey esp-des esp-md5-hmac
crypto ipsec transform-set euro esp-3des esp-md5-hmac
crypto dynamic-map acndyn 20 set transform-set jersey
crypto map vpn_remote 10 ipsec-isakmp
crypto map vpn_remote 10 match address ipsec
crypto map vpn_remote 10 set peer 65.244.11.2
crypto map vpn_remote 10 set transform-set jersey
crypto map vpn_remote 20 ipsec-isakmp dynamic acndyn
crypto map vpn_remote 30 ipsec-isakmp
crypto map vpn_remote 30 match address europe
crypto map vpn_remote 30 set peer 206.220.218.10
crypto map vpn_remote 30 set transform-set euro
crypto map vpn_remote interface outside
isakmp enable outside
isakmp key ******** address 65.244.11.2 netmask 255.255.255.255
isakmp key ******** address 206.220.218.10 netmask 255.255.255.255
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 86400
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
isakmp policy 30 authentication pre-share
isakmp policy 30 encryption 3des
isakmp policy 30 hash md5
isakmp policy 30 group 2
isakmp policy 30 lifetime 86400
vpngroup acnmain address-pool vpnpool
vpngroup acnmain wins-server 10.11.0.6
vpngroup acnmain default-domain domain01
vpngroup acnmain split-tunnel nonat
vpngroup acnmain idle-time 1800
vpngroup acnmain password ********
I tried to add these access-list for NT authentication but I still cant get thru.
10.11.0.5 and 10.11.0.6 being my NT server and WINS respectively.
access-list 200 permit tcp any host 10.11.0.5 eq 139
access-list 200 permit udp any host 10.11.0.5 eq 138
access-list 200 permit udp any host 10.11.0.5 eq 137
access-list 200 permit tcp any host 10.11.0.6 eq 139
access-list 200 permit udp any host 10.11.0.6 eq 138
access-list 200 permit udp any host 10.11.0.6 eq 137
Thanks in advance.
cym
