04-29-2009 06:08 AM - edited 03-01-2019 02:11 PM
We have one requirement from our customer side.
They want to make Video conference between Two Locations With The help of Cisco CCM and Presence. One side Customer Ready to give Pri Link (E1), other side they are offering 3 ISDN (BRI) Link, I would like to know that whether this scenario is work around able or if it's possible please share your valuable feed back on this case
if any kind of document available or not
NB: our main concern is Video will work or not with this scenario.
Sunish
04-29-2009 04:36 PM
If 192Kbps is enough for your video conference then there is no reason why it shouldn't work.
Laurent.
04-29-2009 08:23 PM
I would like to know that How to configure between PRI and BRI.
Sunish
04-30-2009 04:25 AM
Hi Sunish,
There is nothing special to consider. Configure your BRI and PRI interface as usual. You need PPP multilink to use all the 6x B-channels
Just don't configure the PRI to add links in the mulitlink bundle because it has more links than than the 3x BRI
Here is the configuration guide for your reference:
And some configuration examples:
http://www.cisco.com/en/US/tech/tk801/tk133/tech_configuration_examples_list.html
Laurent.
