PRE5 / SCH1 - SPA problem
startx001
Hi all ,
I have ubr10k with IOS SCH1 , and PRE5 installed .
In chassis is SIP-600 with 3G SPA in bay 1/0 and all 3 port are connected to rfgw and working fine  as 1GE .
second 3G SPA in bay 1/1 is not working . connected port gi 1/1/2 to same rfgw ( 4th port ) as first SPA , and communication between gi 1/1/2 and 4th port in rfgw is not working .
on gi 1/1/2 is configured ip ,and also on 4th port of rfgw is configured ip but cant ping rfgw from cmts  . ( from all 3 port on SPA bay 1/0 i can ping )
output from cmts :
Sending 5, 100-byte ICMP Echos to 192.168.200.62, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
#ping 192.168.200.61         <<--- IP on 4th port of rfgw
Sending 5, 100-byte ICMP Echos to 192.168.200.61, timeout is 2 seconds:
Success rate is 0 percent (0/5)
#sh int gi 1/1/2
GigabitEthernet1/1/2 is up, line protocol is up
  Hardware is Half-height Gigabit Ethernet MAC Controller, address is bc16.6527.2617 (bia bc16.6527.2617)
  Internet address is 192.168.200.62/30
  MTU 1500 bytes, BW 10000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full Duplex, 1000Mbps, link type is auto, media type is unknown media type
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:09, output 00:00:01, output hang never
  Interface GigabitEthernet1/1/2 queueing strategy: PXF Class-based
     220 packets input, 24913 bytes
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     1192 packets output, 231155 bytes
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier, 0 pause output
#sh ip arp  gi 1/1/2
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  192.168.200.62          -   bc16.6527.2617  ARPA   GigabitEthernet1/1/2
Internet  192.168.200.61          0   38c8.5c2c.85be  ARPA   GigabitEthernet1/1/2
Changing SFP on cmts and rfgw didint help .
VZ
startx001
Does on CMTS with standby PRE5 , 10GE port  on standby PRE5 can work independent from activ PRE5 10GE port ?
KR
