7921 USB install on Windows 7?
tazwell13
I can not get the newest version loaded on my Windows 7 machine. Anybody had any luck with this.
7 Replies 7
tazwell13
Found out that Cisco does not have a driver for Windows 7 yet.
erle
I got around this issue by installing Windows XP mode and then loading the application into XP mode.
Then I connected the phone to the USB and then presented the USB device to the XP Mode client and then I was able to make changes to the 7921. I had to do this with my 7920 aswell.
Windows 7 will see it as an unknown device.
migilles
Not supported on Windows 7, Vista or MAC OS.
kshort
Has there been any new USB drivers created yet to support Windows 7?  If so can someone please point me to them?
Thanks!
There are no plans to offer a USB driver for Windows 7 or Vista at this time.
Only Windows XP and 2000 are supported currently.
It's not supported but it works, but only with windows 7 32bit.
You have to start the USB-Install-7921-7925.1-0-2a.exe via right click "Run as administrator" in the administrator context (UAC!)
Also when you are logged in as an administrator.
Works like a charm.  Thanks.
