08-08-2017 12:19 PM - edited 07-05-2021 07:30 AM
we want to extend for a customer the corporate network to another building just on the opposit side of the road (50 meters distance). We are thiking about installing 2 1562i APs as Point to Point Bridge. Both APs can me mounted on the roof and have direct line of sight.
What datarate can i expect ? Does anybody have experience with this AP in Bridge mode ? As i said the distance is not very far.
Greetings
08-08-2017 01:25 PM
Refer below datasheet
If you could use 80MHz channel bonding, then theoretical max value of 1.3Gbps across bridge. In practice you could get between 40-70% of that value.
If switch ports is 1 Gbps which effective capacity end to end (not 1.3Gbps
Refer below for reference wireless bridge config
https://mrncciew.com/2013/11/09/wireless-bridge-with-eap-fast/
Rasika
*** Pls rate all useful responses ***
08-08-2017 03:47 PM
Don't forget the 1562I requires 39.1 watts of power.
