05-28-2013 10:00 AM - edited 07-04-2021 12:08 AM
Hi to all
I'm new on this Cisco AP ,, I configured for basic with a single ssid and no security authentication open . so
after the clients get connected an hour or couple hours the AP signal fall and I can't see the SSID ...
can you help us?
Solved! Go to Solution.
05-30-2013 12:31 PM
In the factory we dont know if we have a frecuency regulator rules .. so . its very strange that when we bought and install as the first configuration is worked for a year in half..
I have been testing the AP till yesterday with the dot11radio 1 antena disable . and no reporting any issue ..
I dont know why it blocked because after we put no dfs blocked it still failed ..
may be some devices afected the 5Ghz frequency ..
Thank you so much for your support .. I still monitoring and just one question ..
how can delete crash files .. and how can I read this files ..
05-30-2013 03:23 PM
Francisco,
Can you attach the crash info files crashinfo_20120305-014104 & crashinfo_20120219-231519, please?
05-31-2013 12:22 PM
HI ..
how can take this files out .. ?
how can I send it to a my computer as a files .. ?
thanks
06-03-2013 09:22 AM
Hi leolahohoo ..
How can we see the crash files .. ?
how can I see this logs ..
06-03-2013 05:09 PM
Telnet/SSH into the AP and copy the files into your computer.
06-04-2013 10:08 AM
Sorry if I no hunderstand ..
I try to put copy archive: file name but did not copy the file ..
this is the dir output
Directory of flash:/
2 -rwx 294 Mar 1 2002 00:00:11 +00:00 env_vars
3 -rwx 259345 Oct 3 2011 17:17:51 +00:00 crashinfo_20111003-171750
4 drwx 320 Jan 1 1970 00:06:14 +00:00 c1240-k9w7-mx.124-21a.JA1
154 -rwx 310852 Nov 26 2011 03:41:26 +00:00 crashinfo_20111126-034123
155 -rwx 299340 Oct 24 2011 16:29:07 +00:00 crashinfo_20111024-162904
156 -rwx 286989 Nov 26 2011 03:42:59 +00:00 crashinfo_20111126-034257
157 -rwx 1571 May 29 2013 11:03:36 +00:00 config.txt
158 -rwx 300211 Oct 24 2011 16:32:43 +00:00 crashinfo_20111024-163240
160 -rwx 276356 Dec 6 2011 18:41:50 +00:00 crashinfo_20111206-184149
161 -rwx 287394 Feb 19 2012 23:15:21 +00:00 crashinfo_20120219-231519
162 -rwx 5 May 29 2013 11:03:36 +00:00 private-config
163 -rwx 284122 Mar 5 2012 01:41:05 +00:00 crashinfo_20120305-014104
164 -rwx 1048 May 29 2013 11:03:36 +00:00 private-multiple-fs
what suppost to do to copy this files .. to a my computer ,,
06-04-2013 10:27 AM
BSS
*Oct 3 17:09:40.449: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 74de.2b92.f669 Associated KEY_MGMT[NONE]
*Oct 3 17:09:41.061: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 6427.3779.48a0 Associated KEY_MGMT[NONE]
*Oct 3 17:09:41.430: %DOT11-4-MAXRETRIES: Packet to client 74de.2b92.f669 reached max retries, removing the client
*Oct 3 17:09:41.430: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 74de.2b92.f669 Reason: Previous authentication no longer valid
*Oct 3 17:09:41.437: %DOT11-4-MAXRETRIES: Packet to client 74de.2b92.f669 reached max retries, removing the client
*Oct 3 17:09:46.029: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 2010.7a09.a8eb Associated KEY_MGMT[NONE]
*Oct 3 17:09:47.449: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 74de.2bbc.fb21 Associated KEY_MGMT[NONE]
*Oct 3 17:09:48.123: %DOT11-4-MAXRETRIES: Packet to client 2010.7a0b.906d reached max retries, removing the client
*Oct 3 17:09:48.124: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 2010.7a0b.906d Reason: Previous authentication no longer valid
*Oct 3 17:09:48.131: %DOT11-4-MAXRETRIES: Packet to client 2010.7a0b.906d reached max retries, removing the client
*Oct 3 17:09:49.916: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 60d8.1951.5aca Associated KEY_MGMT[NONE]
*Oct 3 17:09:58.670: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 904c.e58b.326d Reason: Sending station has left the BSS
*Oct 3 17:10:21.055: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 6427.376b.c934 Associated KEY_MGMT[NONE]
*Oct 3 17:10:22.126: %DOT11-4-MAXRETRIES: Packet to client 2010.7a05.c1ae reached max retries, removing the client
*Oct 3 17:10:22.127: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 2010.7a05.c1ae Reason: Previous authentication no longer valid
*Oct 3 17:10:22.134: %DOT11-4-MAXRETRIES: Packet to client 2010.7a05.c1ae reached max retries, removing the client
*Oct 3 17:10:37.170: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 74de.2bad.607a Reason: Sending station has left the BSS
*Oct 3 17:10:37.176: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 74de.2bad.607a Associated KEY_MGMT[NONE]
*Oct 3 17:10:41.602: %DOT11-6-ASSOC: Interface Dot11Radio0, Station f008.f185.a8dc Associated KEY_MGMT[NONE]
*Oct 3 17:10:42.340: %DOT11-6-ASSOC: Interface Dot11Radio0, Station ac81.1299.8bcd Associated KEY_MGMT[NONE]
*Oct 3 17:10:46.219: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f008.f185.a8dc Reason: Sending station has left the BSS
*Oct 3 17:10:46.226: %DOT11-4-MAXRETRIES: Packet to client f008.f185.a8dc reached max retries, removing the client
*Oct 3 17:10:58.128: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 2010.7a0b.5390 Associated KEY_MGMT[NONE]
*Oct 3 17:11:10.126: %DOT11-4-MAXRETRIES: Packet to client 74de.2bbc.fb21 reached max retries, removing the client
*Oct 3 17:11:10.127: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 74de.2bbc.fb21 Reason: Previous authentication no longer valid
*Oct 3 17:11:10.135: %DOT11-4-MAXRETRIES: Packet to client 74de.2bbc.fb21 reached max retries, removing the client
*Oct 3 17:11:14.400: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 001f.a714.9d86 Associated KEY_MGMT[NONE]
*Oct 3 17:11:15.138: %DOT11-4-MAXRETRIES: Packet to client 001f.a714.9d86 reached max retries, removing the client
*Oct 3 17:11:15.139: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 001f.a714.9d86 Reason: Previous authentication no longer valid
*Oct 3 17:11:15.146: %DOT11-4-MAXRETRIES: Packet to client 001f.a714.9d86 reached max retries, removing the client
*Oct 3 17:11:18.058: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 2010.7a07.a030 Associated KEY_MGMT[NONE]
*Oct 3 17:11:20.515: %DOT11-6-ASSOC: Interface Dot11Radio0, Station f008.f185.a8dc Associated KEY_MGMT[NONE]
*Oct 3 17:11:20.654: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 2010.7a10.5431 Reason: Sending station has left the BSS
*Oct 3 17:11:32.695: %DOT11-6-ASSOC: Interface Dot11Radio0, Station d0df.9ad5.99e4 Associated KEY_MGMT[NONE]
*Oct 3 17:11:37.064: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 60d8.198a.ee22 Associated KEY_MGMT[NONE]
*Oct 3 17:11:39.130: %DOT11-4-MAXRETRIES: Packet to client 60d8.198a.ee22 reached max retries, removing the client
*Oct 3 17:11:39.130: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 60d8.198a.ee22 Reason: Previous authentication no longer valid
*Oct 3 17:11:39.140: %DOT11-4-MAXRETRIES: Packet to client 60d8.198a.ee22 reached max retries, removing the client
*Oct 3 17:11:39.380: %DOT11-4-MAXRETRIES: Packet to client 60d8.198a.ee22 reached max retries, removing the client
*Oct 3 17:11:42.264: %DOT11-4-MAXRETRIES: Packet to client 60d8.198a.ee22 reached max retries, removing the client
*Oct 3 17:11:42.587: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 60d8.1963.251a Associated KEY_MGMT[NONE]
*Oct 3 17:11:43.370: %DOT11-6-ASSOC: Interface Dot11Radio0, Station d0df.9a9d.44b0 Associated KEY_MGMT[NONE]
*Oct 3 17:11:44.584: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 2010.7a1c.57f4 Reason: Sending station has left the BSS
*Oct 3 17:11:47.257: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 2010.7a1c.57f4 Associated KEY_MGMT[NONE]
*Oct 3 17:11:54.257: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 60d8.198a.ee22 Associated KEY_MGMT[NONE]
*Oct 3 17:11:55.327: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 2010.7a10.5431 Associated KEY_MGMT[NONE]
*Oct 3 17:11:58.128: %DOT11-4-MAXRETRIES: Packet to client 60d8.1951.5aca reached max retries, removing the client
*Oct 3 17:11:58.128: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 60d8.1951.5aca Reason: Previous authentication no longer valid
*Oct 3 17:11:58.135: %DOT11-4-MAXRETRIES: Packet to client 60d8.1951.5aca reached max retries, removing the client
*Oct 3 17:12:11.476: %DOT11-6-ASSOC: Interface Dot11Radio0, Station d0df.9abf.aa88 Associated KEY_MGMT[NONE]
*Oct 3 17:12:12.137: %DOT11-4-MAXRETRIES: Packet to client d0df.9abf.aa88 reached max retries, removing the client
*Oct 3 17:12:12.137: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station d0df.9abf.aa88 Reason: Previous authentication no longer valid
*Oct 3 17:12:12.144: %DOT11-4-MAXRETRIES: Packet to client d0df.9abf.aa88 reached max retries, removing the client
*Oct 3 17:12:13.870: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 60d8.1939.b633 Associated KEY_MGMT[NONE]
*Oct 3 17:12:14.588: %DOT11-6-ASSOC: Interface Dot11Radio0, Station d0df.9abf.aa88 Reassociated KEY_MGMT[NONE]
*Oct 3 17:12:17.518: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 6427.3733.022b Reason: Sending station has left the BSS
*Oct 3 17:12:18.038: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 60d8.1939.b633 Reason: Sending station has left the BSS
*Oct 3 17:12:18.052: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 60d8.1939.b633 Associated KEY_MGMT[NONE]
*Oct 3 17:12:22.419: %DOT11-6-ASSOC: Interface Dot11Radio0, Station e4d5.3d8b.927d Associated KEY_MGMT[NONE]
*Oct 3 17:12:28.112: %DOT11-6-ASSOC: Interface Dot11Radio0, Station d0df.9ac3.2fca Associated KEY_MGMT[NONE]
*Oct 3 17:12:31.136: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 6427.3733.7768 Associated KEY_MGMT[NONE]
*Oct 3 17:12:38.994: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 2010.7a04.6537 Associated KEY_MGMT[NONE]
*Oct 3 17:12:39.127: %DOT11-4-MAXRETRIES: Packet to client 60d8.198a.ee22 reached max retries, removing the client
*Oct 3 17:12:39.127: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 60d8.198a.ee22 Reason: Previous authentication no longer valid
*Oct 3 17:12:39.136: %DOT11-4-MAXRETRIES: Packet to client 60d8.198a.ee22 reached max retries, removing the client
*Oct 3 17:12:50.922: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f008.f185.a8dc Reason: Sending station has left the BSS
*Oct 3 17:12:53.684: %DOT11-6-ASSOC: Interface Dot11Radio0, Station ccaf.7815.6735 Associated KEY_MGMT[NONE]
*Oct 3 17:13:12.911: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 6427.3757.a177 Associated KEY_MGMT[NONE]
*Oct 3 17:13:20.327: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 74de.2b2d.305f Reason: Sending station has left the BSS
*Oct 3 17:13:32.550: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 74de.2b75.493f Associated KEY_MGMT[NONE]
*Oct 3 17:13:40.090: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 001f.a714.9d86 Associated KEY_MGMT[NONE]
*Oct 3 17:13:40.658: %DOT11-4-MAXRETRIES: Packet to client 001f.a714.9d86 reached max retries, removing the client
*Oct 3 17:13:40.658: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 001f.a714.9d86 Reason: Previous authentication no longer valid
*Oct 3 17:13:40.667: %DOT11-4-MAXRETRIES: Packet to client 001f.a714.9d86 reached max retries, removing the client
*Oct 3 17:13:43.708: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 2010.7a04.7e92 Associated KEY_MGMT[NONE]
*Oct 3 17:13:46.233: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 001f.a714.9d86 Associated KEY_MGMT[NONE]
*Oct 3 17:13:46.744: %DOT11-4-MAXRETRIES: Packet to client 001f.a714.9d86 reached max retries, removing the client
*Oct 3 17:13:46.745: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 001f.a714.9d86 Reason: Previous authentication no longer valid
*Oct 3 17:13:46.753: %DOT11-4-MAXRETRIES: Packet to client 001f.a714.9d86 reached max retries, removing the client
*Oct 3 17:13:47.387: %DOT11-6-ASSOC: Interface Dot11Radio0, Station ac81.12ad.7968 Associated KEY_MGMT[NONE]
*Oct 3 17:14:04.251: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 9439.e532.1e2f Associated KEY_MGMT[NONE]
*Oct 3 17:14:06.736: %DOT11-6-ASSOC: Interface Dot11Radio0, Station ac81.12a9.89d5 Associated KEY_MGMT[NONE]
*Oct 3 17:14:23.509: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 8c58.77ab.20f4 Associated KEY_MGMT[NONE]
*Oct 3 17:14:28.748: %DOT11-6-ASSOC: Interface Dot11Radio0, Station ac81.12ac.93cf Associated KEY_MGMT[NONE]
*Oct 3 17:14:33.408: %DOT11-6-ASSOC: Interface Dot11Radio0, Station b8f9.3480.dbf4 Associated KEY_MGMT[NONE]
*Oct 3 17:14:39.697: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station d0df.9abf.aa88 Reason: Previous authentication no longer valid
*Oct 3 17:14:39.700: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 8c58.77ab.20f4 Reason: Sending station has left the BSS
*Oct 3 17:14:39.707: %DOT11-4-MAXRETRIES: Packet to client 8c58.77ab.20f4 reached max retries, removing the client
*Oct 3 17:14:43.297: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 8c58.77ab.20f4 Associated KEY_MGMT[NONE]CMD: 'sh dot11 as' 17:14:44 UTC Mon Oct 3 2011
*Oct 3 17:14:44.443: %DOT11-4-MAXRETRIES: Packet to client 8c58.77ab.20f4 reached max retries, removing the client
*Oct 3 17:14:44.444: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 8c58.77ab.20f4 Reason: Previous authentication no longer valid
*Oct 3 17:14:44.453: %DOT11-4-MAXRETRIES: Packet to client 8c58.77ab.20f4 reached max retries, removing the client
*Oct 3 17:14:44.639: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station e4d5.3d99.6db3 Reason: Sending station has left the BSS
*Oct 3 17:14:46.833: %DOT11-6-ASSOC: Interface Dot11Radio0, Station e4d5.3d99.6db3 Associated KEY_MGMT[NONE]CMD: 'sh dot11 associations st' 17:14:47 UTC Mon Oct 3 2011
*Oct 3 17:14:47.804: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 8c58.77ab.20f4 Associated KEY_MGMT[NONE]
*Oct 3 17:14:48.852: %DOT11-4-MAXRETRIES: Packet to client e4d5.3d99.6db3 reached max retries, removing the client
*Oct 3 17:14:48.852: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station e4d5.3d99.6db3 Reason: Previous authentication no longer valid
*Oct 3 17:14:48.860: %DOT11-4-MAXRETRIES: Packet to client e4d5.3d99.6db3 reached max retries, removing the client
*Oct 3 17:14:48.989: %DOT11-4-MAXRETRIES: Packet to client e4d5.3d99.6db3 reached max retries, removing the client
*Oct 3 17:14:49.048: %DOT11-4-MAXRETRIES: Packet to client 8c58.77ab.20f4 reached max retries, removing the client
*Oct 3 17:14:49.049: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 8c58.77ab.20f4 Reason: Previous authentication no longer valid
*Oct 3 17:14:49.056: %DOT11-4-MAXRETRIES: Packet to client 8c58.77ab.20f4 reached max retries, removing the client
*Oct 3 17:14:49.327: %DOT11-4-MAXRETRIES: Packet to client e4d5.3d99.6db3 reached max retries, removing the client
*Oct 3 17:14:49.355: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 6427.3757.a177 Reason: Sending station has left the BSS
*Oct 3 17:14:50.274: %DOT11-6-ASSOC: Interface Dot11Radio0, Station e4d5.3d99.6db3 Associated KEY_MGMT[NONE]
*Oct 3 17:14:51.132: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 8c58.77ab.20f4 Associated KEY_MGMT[NONE]
*Oct 3 17:14:51.948: %DOT11-4-MAXRETRIES: Packet to client 8c58.77ab.20f4 reached max retries, removing the client
*Oct 3 17:14:51.948: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 8c58.77ab.20f4 Reason: Previous authentication no longer valid
*Oct 3 17:14:51.959: %DOT11-4-MAXRETRIES: Packet to client 8c58.77ab.20f4 reached max retries, removing the client
*Oct 3 17:14:52.187: %DOT11-4-MAXRETRIES: Packet to client 8c58.77ab.20f4 reached max retries, removing the clientCMD: 'reload' 17:14:52 UTC Mon Oct 3 2011
*Oct 3 17:14:56.599: %SYS-3-CPUHOG: Task is running for (1990)msecs, more than (2000)msecs (401/8),process = Dot11 driver.
-Traceback= 0x500 0x7D01A4 0x5031C4 0x50C90C 0x1A3B30
*Oct 3 17:15:04.007: %SYS-3-CPUHOG: Task is running for (3970)msecs, more than (2000)msecs (1758/8),process = Dot11 driver.
-Traceback= 0x2E893C 0x7CECBC 0x7D01A4 0x5031C4 0x50C90C 0x1A3B30
*Oct 3 17:15:09.912: %SYS-3-CPUHOG: Task is running for (5955)msecs, more than (2000)msecs (2738/8),process = Dot11 driver.
-Traceback= 0x2E9F7C 0x2EA530 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC
*Oct 3 17:15:16.113: %SYS-3-CPUHOG: Task is running for (7939)msecs, more than (2000)msecs (3792/8),process = Dot11 driver.
-Traceback= 0x2EA288 0x2E9FE8 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC
*Oct 3 17:15:22.280: %SYS-3-CPUHOG: Task is running for (9923)msecs, more than (2000)msecs (4838/8),process = Dot11 driver.
-Traceback= 0x2E8948 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC
*Oct 3 17:15:27.890: %SYS-3-CPUHOG: Task is running for (11908)msecs, more than (2000)msecs (5744/8),process = Dot11 driver.
-Traceback= 0x2EA01C 0x2EA540 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC
*Oct 3 17:15:33.874: %SYS-3-CPUHOG: Task is running for (13892)msecs, more than (2000)msecs (6744/8),process = Dot11 driver.
-Traceback= 0x2E89C4 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC
*Oct 3 17:15:39.667: %SYS-3-CPUHOG: Task is running for (15877)msecs, more than (2000)msecs (7696/8),process = Dot11 driver.
-Traceback= 0x2E8978 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC
*Oct 3 17:15:46.250: %SYS-3-CPUHOG: Task is running for (17860)msecs, more than (2000)msecs (8846/8),process = Dot11 driver.
*Oct 3 17:15:52.464: %SYS-3-CPUHOG: Task is running for (19844)msecs, more than (2000)msecs (9904/8),process = Dot11 driver.
-Traceback= 0x2E9F8C 0x2EA540 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC
*Oct 3 17:15:58.449: %SYS-3-CPUHOG: Task is running for (21828)msecs, more than (2000)msecs (10904/8),process = Dot11 driver.
*Oct 3 17:16:05.016: %SYS-3-CPUHOG: Task is running for (23811)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
-Traceback= 0x2E8A18 0xFDABEC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC
*Oct 3 17:16:07.010: %SYS-3-CPUHOG: Task is running for (25806)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
-Traceback= 0x2E8A28 0xFDABEC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC
*Oct 3 17:16:09.005: %SYS-3-CPUHOG: Task is running for (27800)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:11.000: %SYS-3-CPUHOG: Task is running for (29795)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:12.995: %SYS-3-CPUHOG: Task is running for (31790)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:14.989: %SYS-3-CPUHOG: Task is running for (33785)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:16.984: %SYS-3-CPUHOG: Task is running for (35779)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:18.979: %SYS-3-CPUHOG: Task is running for (37774)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:20.974: %SYS-3-CPUHOG: Task is running for (39769)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:22.969: %SYS-3-CPUHOG: Task is running for (41764)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:24.963: %SYS-3-CPUHOG: Task is running for (43759)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:26.958: %SYS-3-CPUHOG: Task is running for (45753)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:28.953: %SYS-3-CPUHOG: Task is running for (47748)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:30.948: %SYS-3-CPUHOG: Task is running for (49743)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:32.942: %SYS-3-CPUHOG: Task is running for (51738)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:34.937: %SYS-3-CPUHOG: Task is running for (53732)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:36.932: %SYS-3-CPUHOG: Task is running for (55727)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:38.927: %SYS-3-CPUHOG: Task is running for (57722)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:40.922: %SYS-3-CPUHOG: Task is running for (59717)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:42.916: %SYS-3-CPUHOG: Task is running for (61712)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:44.911: %SYS-3-CPUHOG: Task is running for (63706)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:46.906: %SYS-3-CPUHOG: Task is running for (65701)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:48.901: %SYS-3-CPUHOG: Task is running for (67696)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:50.895: %SYS-3-CPUHOG: Task is running for (69691)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:52.890: %SYS-3-CPUHOG: Task is running for (71686)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:54.885: %SYS-3-CPUHOG: Task is running for (73680)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:56.880: %SYS-3-CPUHOG: Task is running for (75675)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:16:58.875: %SYS-3-CPUHOG: Task is running for (77670)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:00.869: %SYS-3-CPUHOG: Task is running for (79665)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:02.864: %SYS-3-CPUHOG: Task is running for (81659)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:04.859: %SYS-3-CPUHOG: Task is running for (83654)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:06.854: %SYS-3-CPUHOG: Task is running for (85649)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:08.849: %SYS-3-CPUHOG: Task is running for (87644)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:10.843: %SYS-3-CPUHOG: Task is running for (89639)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:12.838: %SYS-3-CPUHOG: Task is running for (91633)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:14.833: %SYS-3-CPUHOG: Task is running for (93628)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:16.828: %SYS-3-CPUHOG: Task is running for (95623)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:18.822: %SYS-3-CPUHOG: Task is running for (97618)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:20.817: %SYS-3-CPUHOG: Task is running for (99612)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:22.812: %SYS-3-CPUHOG: Task is running for (101607)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:24.807: %SYS-3-CPUHOG: Task is running for (103602)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:26.802: %SYS-3-CPUHOG: Task is running for (105597)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:28.796: %SYS-3-CPUHOG: Task is running for (107592)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:30.791: %SYS-3-CPUHOG: Task is running for (109586)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:32.786: %SYS-3-CPUHOG: Task is running for (111581)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:34.781: %SYS-3-CPUHOG: Task is running for (113576)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:36.775: %SYS-3-CPUHOG: Task is running for (115571)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:38.770: %SYS-3-CPUHOG: Task is running for (117565)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:40.765: %SYS-3-CPUHOG: Task is running for (119560)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:42.760: %SYS-3-CPUHOG: Task is running for (121555)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:44.755: %SYS-3-CPUHOG: Task is running for (123550)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:46.749: %SYS-3-CPUHOG: Task is running for (125545)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:48.744: %SYS-3-CPUHOG: Task is running for (127539)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
*Oct 3 17:17:49.207: %SYS-2-WATCHDOG: Process aborted on watchdog timeout, process = Dot11 driver.
*Oct 3 17:17:49.211: %SYS-3-CPUHOG: Task is running for (-48164)msecs, more than (2000)msecs (12050/8),process = Dot11 driver.
-Traceback= 0x2EC6D8 0x2E9434 0x71B3C 0x73070 0x728A8 0x19F9DC 0x1AB2A4 0x1AB7D8 0x1A22AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC
*Oct 3 17:17:49.276: %SYS-2-INTSCHED: 'sleep for' at level 0 -Process= "Dot11 driver", ipl= 0, pid= 28 -Traceback= 0x5E8D0 0x1A3690 0x175BD0 0x19FAA8 0x1AB2A4 0x1AB7D8 0x1A22AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC
=== Start of Crashinfo Collection (17:17:50 UTC Mon Oct 3 2011) ===
For image:
Cisco IOS Software, C1240 Software (C1240-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 19:06 by prod_rel_team
========= Show Alignment ============================
No alignment data has been recorded.
No spurious memory references have been recorded.
========= Malloc and Free Traces ====================
MallocFree Trace: ixmallocfree=0x31 ptr=0xC196E8
C19560: 1C8AE24 2000017C 1C8AE24 FCD44 CAB1B4 400001AA CAB1B4 FCCF4
C19580: 1C9D304 20000E1C 1C9D304 FCD44 CAB538 400001AA CAB538 FCCF4
C195A0: 1C8263C 20000FB0 1C8263C FCD44 CAB8BC 400001AA CAB8BC FCCF4
C195C0: 1C9D62C 20000C88 1C9D62C FCD44 CABC40 400001AA CABC40 FCCF4
C195E0: 1C82964 20000E1C 1C82964 FCD44 CABFC4 400001AA CABFC4 FCCF4
C19600: 1C9D954 20000AF4 1C9D954 FCD44 CAC348 400001AA CAC348 FCCF4
C19620: 1C9DC7C 20000960 1C9DC7C FCD44 CAC6CC 400001AA CAC6CC FCCF4
C19640: 1C9DFA4 200007CC 1C9DFA4 FCD44 CACA50 400001AA CACA50 FCCF4
C19660: 1C9E2CC 20000638 1C9E2CC FCD44 CACDD4 400001AA CACDD4 FCCF4
C19680: 1C9E5F4 200004A4 1C9E5F4 FCD44 CAD158 400001AA CAD158 FCCF4
C196A0: 1C9E91C 20000310 1C9E91C FCD44 CAD4DC 400001AA CAD4DC FCCF4
C196C0: 1C9EC44 2000017C 1C9EC44 FCD44 CAD860 400001AA CAD860 FCCF4
C196E0: 1C82C8C 20000C88 1C82C8C FCD44 C96B0C 400001AA C96B0C FCCF4
C19700: 1C8A4AC 20000638 1C8A4AC FCD44 1314DAC 400001AA 1314DAC FCCF4
C19720: 1C8A7D4 200004A4 1C8A7D4 FCD44 C95ED0 400001AA C95ED0 FCCF4
C19740: 1C8AAFC 20000310 1C8AAFC FCD44 C96254 400001AA C96254 FCCF4
========= Chunk Malloc and Chunk Free Traces=====================
C192A4: E74238 30EA74 316DB8 E74440 30EA74 316DB8
C1928C: E74648 30EA74 316DB8 E74030 30EA74 316DB8
C19274: EA4FB8 31328C 315C78 E74030 30E9C4 316DB8
C1955C: E74030 30EA74 316DB8 E74030 30E9C4 316DB8
C19544: E74440 30E9C4 316DB8 E74648 30E9C4 316DB8
C1952C: EA5318 3125D8 315C78 EA530C 3125D8 315C78
C19514: EA5300 31490C 315C78 EA5300 3125D8 315C78
C194FC: EA52F4 31490C 315C78 EA52F4 3125D8 315C78
C194E4: EA52E8 31490C 315C78 EA52E8 3125D8 315C78
C194CC: EA52DC 31490C 315C78 EA52DC 3125D8 315C78
C194B4: EA52D0 31490C 315C78 EA52D0 3125D8 315C78
C1949C: EA52C4 31490C 315C78 EA52C4 3125D8 315C78
C19484: EA52B8 31490C 315C78 EA52B8 3125D8 315C78
C1946C: EA52AC 31490C 315C78 EA52AC 3125D8 315C78
C19454: EA52A0 31490C 315C78 EA52A0 3125D8 315C78
C1943C: EA5294 31490C 315C78 EA5294 3125D8 315C78
C19424: EA5288 31490C 315C78 EA5288 3125D8 315C78
C1940C: EA4FAC 31490C 315C78 E74648 30EA74 316DB8
C193F4: E74648 30E9C4 316DB8 E74648 30EA74 316DB8
C193DC: E74648 30E9C4 316DB8 E74238 30E9C4 316DB8
C193C4: E74238 30EA74 316DB8 E74648 30EA74 316DB8
C193AC: E74440 30EA74 316DB8 E74030 30EA74 316DB8
C19394: EA4FAC 31328C 315C78 E74030 30E9C4 316DB8
C1937C: E74030 30EA74 316DB8 E74030 30E9C4 316DB8
C19364: E74648 30E9C4 316DB8 E74440 30E9C4 316DB8
C1934C: EA527C 3125D8 315C78 EA5270 31490C 315C78
C19334: EA5270 3125D8 315C78 EA5264 31490C 315C78
C1931C: EA5264 3125D8 315C78 EA5258 31490C 315C78
C19304: EA5258 3125D8 315C78 EA524C 31490C 315C78
C192EC: EA524C 3125D8 315C78 EA5240 31490C 315C78
C192D4: EA5240 3125D8 315C78 EA5234 31490C 315C78
C192BC: EA5234 3125D8 315C78 EA5228 31490C 315C78
========= Stack Trace ========
-Traceback= 0x19FAA8 0x19FAA8 0x1AB7D8 0x1A22AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC 0x2E89AC
========= Context ======================
Signal = 5, Vector = 0x2000
CPU Register Context:
PC : 0x0019FAA8, MSR : 0x00021230, CR : 0x33000033, LR : 0x0019FAA8,
CTR : 0x00666584, XER : 0xE0000001, TBL : 0xFDCA0EEA, TBU : 0x00000058,
USPRG0: 0x00000000,
R0 : 0x0019FAA8, R1 : 0x00EC5204, R2 : 0x00000000, R3 : 0x00000000,
R4 : 0x00EC511C, R5 : 0x0000001C, R6 : 0x00000002, R7 : 0x0002380E,
R8 : 0x00000000, R9 : 0x00BA0000, R10 : 0x0000380E, R11 : 0x00C6FA20,
R12 : 0xA0000000, R13 : 0x00000000, R14 : 0x00000000, R15 : 0x00000000,
R16 : 0x00000000, R17 : 0x00000000, R18 : 0x00000000, R19 : 0x01001980,
R20 : 0x00000000, R21 : 0x00000000, R22 : 0x00000000, R23 : 0x00EC5288,
R24 : 0x00000000, R25 : 0x00000000, R26 : 0x00000000, R27 : 0x0100080C,
R28 : 0x00000030, R29 : 0x00000000, R30 : 0x00000003, R31 : 0x00000000,
PVR : 0x51210950, EVPR : 0x00000000, ESR : 0x00000000, DEAR : 0x00000000,
SRR0 : 0x002EC6D8, SRR1 : 0x00021230, SRR2 : 0x0019FAA8, SRR3 : 0x00021230,
CCR0 : 0x00700000, TCR : 0x3C000000, TSR : 0x84000000, PIT : 0x00000000,
SPRG0 : 0x00004000, SPRG1 : 0x00006000, SPRG2 : 0x00000000, SPRG3 : 0x00000000,
PID : 0x00000000, ZPR : 0x00000000, DCCR : 0x80000000, ICCR : 0x80000001,
DCWR : 0x00000000, SGR : 0x00000000, SLER : 0x00000000, SU0R : 0x00000000,
DBSR : 0x10000000, DBCR0 : 0x41B00000, DBCR1 : 0xAC000000, ICDBDR: 0x55000000,
DVC1 : 0x00000000, DVC2 : 0x00010000, DAC1 : 0x00000000, DAC2 : 0x00000000,
IAC1 : 0x00000100, IAC2 : 0x008BA444, IAC3 : 0x00000400, IAC4 : 0x00600004
========= Stack Dump ==========================
Stack Frame Pointer in Context is 0xEC5204, at process level
EC4E04: FF81 EC4F60 C18AB8 FFFFFFFF 0 1B9 FFFFFFFE EC4EC8
EC4E24: 742EC EC4F70 6 FFFFFFFF 0 38353032 31FFFFF9 EC4EE8
EC4E44: 73070 EC4EF0 742EC A00000 3A00109A 43413938 45320000 EC005052
EC4E64: F01486D BE1EA8 C18B52 9B14CB 600064 210700 73746E75 0
EC4E84: 0 0 0 0 1001980 FFFFFFFF 0 EC4EC8
EC4EA4: FFFFFFFE EC4EC8 2 0 BE0000 EC4F60 F4 11C9740
EC4EC4: 8D7D54 EC4ED0 178ED0 EC4EE0 170F10 0 163052 EC4F00
EC4EE4: 6533B4 EC4F00 5E8CC EC4F60 0 8D7D54 8D7D54 EC4F98
EC4F04: 5E7C4 EC4F88 72D18 1000000 EC5020 EC4FA0 0 1000000
EC4F24: EC5020 EC4FA0 0 7000000 EC5020 EC4FA0 EC4F80 1000000
EC4F44: EC5020 EC4FA0 1C53B0 1000000 EC5020 EC4FA0 EC5288 7000000
EC4F64: EC5020 EC4FA0 10 1000000 EC5020 EC4FA0 EC4F90 EC51EC
EC4F84: 0 30 C00000 0 15 EC5018 5E8D0 2EC6D8
EC4FA4: FFFF43DC 7D0 2F12 8 EC4FDC C18AB8 30C00000 2E9434
EC4FC4: EC511C 0 FFFFFFFF 0 297 EC4FF4 EC5084 73DD8
EC4FE4: 0 1AB2A4 0 1AB7D8 30000000 1A22AC 0 EC5018
EC5004: 0 1000000 EC5020 EC4FA0 163052 EC5030 17565C 2E89AC
EC5024: BE1DCA EC4FF3 9B190D EC5048 1AB7E8 73070 0 0
EC5044: 0 0 0 1001980 0 0 EC5084 EC5288
EC5064: EC5084 0 0 BE0000 EC511C 16 11C9740 8D7ED4
EC5084: EC508C 178ED0 EC509C 170F10 0 163094 EC50BC 6533B4
EC50A4: EC50BC 5E8CC EC511C 0 8D7ED4 8D7ED4 EC5154 5E7C4
EC50C4: 30 0 10051D4 EC51DC EC515C 73070 10051D4 EC51DC
EC50E4: EC515C 5E8CC 30051D4 EC51DC EC515C 8D7D84 10051D4 EC51DC
EC5104: EC515C 2E89AC 10051D4 EC51DC EC515C 1 30051D4 EC51DC
EC5124: EC515C 1C5384 10051D4 EC51DC EC515C 0 0 100080C
EC5144: 19FAA4 0 3 9B42B4 EC51D4 5E8D0 0 9B42B4
EC5164: 0 EC51EC 0 FFFFFFFF 5E880 1 EC5204 728A8
EC5184: 30 0 0 EC51EC 0 0 C00000 BA0000
EC51A4: C18AB8 EC5164 0 0 5E880 0 EC51D4 0
EC51C4: 19FAA4 0 3 9B42B4 EC51EC 1A36A8 2E89AC 0
EC51E4: 3 BB8 EC5204 175BD0 30 0 3 0
EC5204: EC5214 19FAA8 0 0 EC5224 1AB2A4 0 14
EC5224: EC523C 1AB7D8 B220E8 1001980 2E8A28 21230 EC5288 1A22AC
EC5244: 10000 FDABEC EC5288 0 0 3 2 E8000000
EC5264: 0 0 138024 FDABEC 33000035 64 C0000001 1001980
EC5284: 2732A6 EC5288 2E89AC 10000 FDABEC EC5288 0 0
EC52A4: 3 2 E8000000 0 0 138024 FDABEC 33000035
EC52C4: 64 C0000001 2E8978 21230 FFFFFFFF 0 0 0
EC52E4: EC5338 0 138087 420C 0 0 EC5338 EC52D8
EC5304: 0 0 1382B8 14248 0 0 0 EC52D8
EC5324: 0 0 0 4248 0 EC52F8 EC52F8 EC52D8
EC5344: 0 0 138087 24248 0 0 138087 4
EC5364: 4 0 0 0 0 0 0 0
EC5384: 1A3B30 FFFFFFFF FD0110DF AB1234CD 1C0000 1D AB0808 1742E0
EC53A4: EC568C EC3C00 80000166 1 0 24 CF0B50 EC3C1C
EC53C4: D556D4 0 0 0 0 0 0 0
EC53E4: 0 0 0 0 0 0 0 FDABEC
EC5404: C00000 EC56BC 0 0 33000035 176464 29230 0
EC5424: 0 2EC6D8 1AB6F4 0 10000 1 0 0
EC5444: 0 0 1C 0 0 0 1B8524 5D80
EC5464: 1841C8 1841C8 13EF0 0 1D 0 0 0
EC5484: 138023 0 0 0 16304E 0 16304E 6F7
EC54A4: 11E95AC D690 6735 A49710 3 7D86 51 67
EC54C4: 72 1770 1770 CD08EC 0 0 0 0
EC54E4: 0 0 E65DF0 0 EC53C0 C18E74 0 0
EC5504: 0 BBB3F0 0 0 0 421C 0 0
EC5524: 0 EC5500 0 0 0 42AC EC53C0 0
EC5544: 0 0 0 EC5500 EC53C0 0 0 142E4
EC5564: 0 0 0 EC5500 EC53C0 0 0 242EC
EC5584: 0 0 0 0 0 0 EC56BC 0
EC55A4: 0 0 0 0 0 0 0 CDDE9C
EC55C4: EC571C EC55B0 EC56C4 0 C188C8 0 0 0
EC55E4: 0 0 0 0 FFFFFFF FFFFFFF 0 0
========= Process Level Info ==================
---- Current Process Block (at 0xEC53C0) ----
EC5390: AB1234CD 1C0000 1D AB0808 1742E0 EC568C EC3C00 80000166
EC53B0: 1 0 24 CF0B50 EC3C1C D556D4 0 0
EC53D0: 0 0 0 0 0 0 0 0
EC53F0: 0 0 0 0 FDABEC C00000 EC56BC 0
EC5410: 0 33000035 176464 29230 0 0 2EC6D8 1AB6F4
EC5430: 0 10000 1 0 0 0 0 1C
EC5450: 0 0 0 1B8524 5D80 1841C8 1841C8 13EF0
EC5470: 0 1D 0 0 0 138023 0 0
EC5490: 0 16304E 0 16304E 6F7 11E95AC D690 6735
EC54B0: A49710 3 7D86 51 67 72 1770 1770
EC54D0: CD08EC 0 0 0 0 0 0 E65DF0
EC54F0: 0 EC53C0 C18E74 0 0 0 BBB3F0 0
EC5510: 0 0 421C 0 0 0 EC5500 0
EC5530: 0 0 42AC EC53C0 0 0 0 0
EC5550: EC5500 EC53C0 0 0 142E4 0 0 0
EC5570: EC5500 EC53C0 0 0 242EC 0 0 0
EC5590: 0 0 0 EC56BC 0 0 0 0
EC55B0: 0 0 0 0 CDDE9C EC571C EC55B0 EC56C4
EC55D0: 0 C188C8 0 0 0 0 0 0
EC55F0: 0 FFFFFFF FFFFFFF 0 0 0 0 0
EC5610: 0 1367E9 0 EC57CC 0 0 FFFF82AD 0
EC5630: 0 1600 0 D4B7C8 D4B7C8 CF0BA4 EC56CC EC563C
EC5650: BB93A8 15F D0000 1 0 9B41DC 16D758 B1D128
EC5670: 0 CF0B50 0 0 BEEFCAFE 0
---- Partial decode of process block ----
Pid 28: Process "Dot11 driver "
stack 0xEC3C1C savedsp 0xD556D4
Flags: analyze prefers_new
Status 0x00000000 Orig_ra 0x002EC6D8 Routine 0x001AB6F4 Signal 0
Caller_pc 0x00000000 Callee_pc 0x00000000 Dbg_events 0x00000000 State 0
Totmalloc 1803556 Totfree 23936 Totgetbuf 81648
Totretbuf 0 Edisms 0x0 Eparm 0x0
Elapsed 0x6F7 Ncalls 0xD690 Ngiveups 0x6735
Priority_q 3 Ticks_5s 32134 Cpu_5sec 81 Cpu_1min 103
Cpu_5min 114 Stacksize 0x1770 Lowstack 0x1770
Ttyptr 0xCD08EC Mem_holding 0x1841C8 Thrash_count 0
Wakeup_reasons 0x0FFFFFFF Default_wakeup_reasons 0x0FFFFFFF
Direct_wakeup_major 0x00000000 Direct_wakeup_minor 0x00000000
Regs R14-R31, CR, PC, MSR at last suspend; R3 from proc creation:
R3 : 00000000 R14: 00000000 R15: 00000000 R16: 00000000 R17: 00000000
R18: 00000000 R19: 00000000 R20: 00000000 R21: 00000000 R22: 00000000
R23: 00000000 R24: 00000000 R25: 00000000 R26: 00000000 R27: 00FDABEC
R28: 00C00000 R29: 00EC56BC R30: 00000000 R31: 00000000 CR : 33000035
PC : 00176464 MSR: 00029230
---- Current Process Stack (0xA7C bytes used, out of 0x1770 available) ----
Current SP = 0xEC5204 , saved SP = 0xD556D4
EC4F8C: C00000 0 15 EC5018 5E8D0 2EC6D8 FFFF43DC 7D0
EC4FAC: 2F12 8 EC4FDC C18AB8 30C00000 2E9434 EC511C 0
EC4FCC: FFFFFFFF 0 297 EC4FF4 EC5084 73DD8 0 1AB2A4
EC4FEC: 0 1AB7D8 30000000 1A22AC 0 EC5018 0 1000000
EC500C: EC5020 EC4FA0 163052 EC5030 17565C 2E89AC BE1DCA EC4FF3
EC502C: 9B190D EC5048 1AB7E8 73070 0 0 0 0
EC504C: 0 1001980 0 0 EC5084 EC5288 EC5084 0
EC506C: 0 BE0000 EC511C 16 11C9740 8D7ED4 EC508C 178ED0
EC508C: EC509C 170F10 0 163094 EC50BC 6533B4 EC50BC 5E8CC
EC50AC: EC511C 0 8D7ED4 8D7ED4 EC5154 5E7C4 30 0
EC50CC: 10051D4 EC51DC EC515C 73070 10051D4 EC51DC EC515C 5E8CC
EC50EC: 30051D4 EC51DC EC515C 8D7D84 10051D4 EC51DC EC515C 2E89AC
EC510C: 10051D4 EC51DC EC515C 1 30051D4 EC51DC EC515C 1C5384
EC512C: 10051D4 EC51DC EC515C 0 0 100080C 19FAA4 0
EC514C: 3 9B42B4 EC51D4 5E8D0 0 9B42B4 0 EC51EC
EC516C: 0 FFFFFFFF 5E880 1 EC5204 728A8 30 0
EC518C: 0 EC51EC 0 0 C00000 BA0000 C18AB8 EC5164
EC51AC: 0 0 5E880 0 EC51D4 0 19FAA4 0
EC51CC: 3 9B42B4 EC51EC 1A36A8 2E89AC 0 3 BB8
EC51EC: EC5204 175BD0 30 0 3 0 EC5214 19FAA8
EC520C: 0 0 EC5224 1AB2A4 0 14 EC523C 1AB7D8
EC522C: B220E8 1001980 2E8A28 21230 EC5288 1A22AC 10000 FDABEC
EC524C: EC5288 0 0 3 2 E8000000 0 0
EC526C: 138024 FDABEC 33000035 64 C0000001 1001980 2732A6 EC5288
EC528C: 2E89AC 10000 FDABEC EC5288 0 0 3 2
EC52AC: E8000000 0 0 138024 FDABEC 33000035 64 C0000001
EC52CC: 2E8978 21230 FFFFFFFF 0 0 0 EC5338 0
EC52EC: 138087 420C 0 0 EC5338 EC52D8 0 0
EC530C: 1382B8 14248 0 0 0 EC52D8 0 0
EC532C: 0 4248 0 EC52F8 EC52F8 EC52D8 0 0
EC534C: 138087 24248 0 0 138087 4 4 0
EC536C: 0 0 0 0 0 0 1A3B30 FFFFFFFF
========= Interrupt Level Stack Dump ==========
---- Level 1 Interrupt stack (0x0 bytes used, out of 0x0 available) ----
intstacks[1]: base 0x0 stack 0x0 routine 0x0 count 0x0
size 0x0 low 0x0 desc 0x0
---- Level 2 Interrupt stack (0x0 bytes used, out of 0x0 available) ----
intstacks[2]: base 0x0 stack 0x0 routine 0x0 count 0x0
---- Level 3 Interrupt stack (0x0 bytes used, out of 0x0 available) ----
intstacks[3]: base 0x0 stack 0x0 routine 0x0 count 0x0
---- Level 4 Interrupt stack (0x788 bytes used, out of 0x2328 available) ----
intstacks[4]: base 0x1006F80 stack 0x10092A0 routine 0x0 count 0x40229E
size 0x2328 low 0x2328 desc 0xA498F4
1008EA8: 1067440 10676A0 1008ED0 10519C 1008ED0 1 1067440 0
1008EC8: 1008EE0 1067440 1008F48 0 132C17C D619D4 1008F08 FD700
1008EE8: 0 0 0 0 1008F10 132C17C D619D4 0
1008F08: DC4BEC D61CDC 1008F38 FD6A8 1C9C6D0 80000 0 0
1008F28: DC4BEC DC4BEC D61CDC DC4BEC 1008F70 FF1E4 1008F50 10092DC
1008F48: DC4BEC 0 1 80000 1008F70 1009E78 DC4BEC 10092DC
1008F68: 1008F80 DC4BEC 1008F80 10092DC 105AB7C 0 1008FF0 515C00
1008F88: 0 0 FEF334 1 DC4BEC EE2044 1 11E6F98
1008FA8: 1 11E4558 1009038 DC4BEC 1 1 18A4914 1
1008FC8: DC4BEC DC4BEC 1 0 0 DC4BEC 10092DC 10092DC
1008FE8: DC4BEC 0 1009028 515AC0 18A4914 1 33330000 4BEC
1009008: 1 0 3 10092DC CD3EE4 1067FDC 11E5B90 0
1009028: 1009158 4B3A78 D61CDC DCEA20 1 0 0 9C
1009048: 0 0 1009068 2 1009068 11E7CBC DC059C DC059C
1009068: 1009080 1016CC DC059C 11E7CBC 11E4558 DC059C 1009170 4AFF60
1009088: 132C17C CD67EC 10090A0 177B18 1227058 132C17C 10090B0 126E30
10090A8: D619D4 132C17C 1009130 48AA94 1067FDC 11E4558 FFFFFFFF FFFF00E0
10090C8: 18BFDC27 172 132C17C 0 10090F8 FF7A8 C2ECD8 53000033
10090E8: BFDE94 0 0 1067440 DC4BEC 80000000 C2ECD8 106869C
1009108: 2 0 1009170 11E4558 1 132C17C FC 201
1009128: 132C17C 0 0 1067440 DC4BEC 80000000 C2ECD8 106869C
1009148: 2 0 1009168 11E4558 1009168 CD76C8 1009180 1
1009168: 1009180 1 1009180 0 EAB9B0 EAB9B0 10091B8 16F450
1009188: 10091A0 10686A0 2 0 1067440 DE8574 10091B8 6
10091A8: 10091D8 13820B C166D0 EABA38 1067440 DE8574 10091D8 4
10091C8: 1009228 EAB9B0 4 EAB870 10091F8 176724 10091F8 CD9F40
10091E8: 1 EAB870 CDE04C 1009220 1009200 16B698 1009218 16B6E0
1009208: 21C6A9C4 C4A9C621 1009228 80000000 0 FDABEC FDABEC 200
1009228: 1009280 51A31C 1C6B990 106864C 4 0 1009298 5C7D34
1009248: 0 9C70EE5F C2ECD8 C00000 B40000 C2B98C 0 B3B9A8
1009268: BA0000 0 0 FFABEC FDABEC 200 1009298 5285D8
1009288: 1C B220E8 21230 EC5228 FFFFFFFF 2E88EC FFFFFFFF FFFFFFFF
PC : 0x00000001, MSR : 0x00EAB870, CR : 0x00CDE04C, LR : 0x01009220,
CTR : 0x01009200, XER : 0x0016B698, TBL : 0xC4A9C621, TBU : 0x21C6A9C4,
USPRG0: 0x01C6B990,
R0 : 0x01009180, R1 : 0x00000001, R2 : 0x01009180, R3 : 0x00000000,
R4 : 0x00EAB9B0, R5 : 0x00EAB9B0, R6 : 0x010091B8, R7 : 0x0016F450,
R8 : 0x010091A0, R9 : 0x010686A0, R10 : 0x00000002, R11 : 0x00000000,
R12 : 0x01067440, R13 : 0x00DE8574, R14 : 0x010091B8, R15 : 0x00000006,
R16 : 0x010091D8, R17 : 0x0013820B, R18 : 0x00C166D0, R19 : 0x00EABA38,
R20 : 0x01067440, R21 : 0x00DE8574, R22 : 0x010091D8, R23 : 0x00000004,
R24 : 0x01009228, R25 : 0x00EAB9B0, R26 : 0x00000004, R27 : 0x00EAB870,
R28 : 0x010091F8, R29 : 0x00176724, R30 : 0x010091F8, R31 : 0x00CD9F40,
PVR : 0x01009228, EVPR : 0x80000000, ESR : 0x00000000, DEAR : 0x00000200,
SRR0 : 0x01009218, SRR1 : 0x0016B6E0, SRR2 : 0x00FDABEC, SRR3 : 0x00FDABEC,
CCR0 : 0x0106864C, TCR : 0x00C2ECD8, TSR : 0x00C00000, PIT : 0x00B40000,
SPRG0 : 0x00000004, SPRG1 : 0x00000000, SPRG2 : 0x01009298, SPRG3 : 0x005C7D34,
PID : 0x00000000, ZPR : 0x9C70EE5F, DCCR : 0x01009280, ICCR : 0x0051A31C,
DCWR : 0x00B220E8, SGR : 0x00021230, SLER : 0x00EC5228, SU0R : 0xFFFFFFFF,
DBSR : 0x00C2B98C, DBCR0 : 0x00BA0000, DBCR1 : 0x00000000, ICDBDR: 0x0000001C,
DVC1 : 0x00000000, DVC2 : 0x00FFABEC, DAC1 : 0x00000000, DAC2 : 0x00B3B9A8,
IAC1 : 0x00FDABEC, IAC2 : 0x00000200, IAC3 : 0x01009298, IAC4 : 0x005285D8
---- Level 5 Interrupt stack (0x0 bytes used, out of 0x0 available) ----
intstacks[5]: base 0x0 stack 0x0 routine 0x0 count 0x0
---- Level 6 Interrupt stack (0x28 bytes used, out of 0x2328 available) ----
intstacks[6]: base 0x1004C58 stack 0x1006F78 routine 0x0 count 0x5AA
size 0x2328 low 0x2328 desc 0x9EB028
1006F58: 1006F68 FFFFFFFF 21200 C2A6DC 1006F70 2EC2D0 FFFFFFFF 2E88EC
1006F78: FFFFFFFF FFFFFFFF
---- Level 7 Interrupt stack (0x0 bytes used, out of 0x0 available) ----
intstacks[7]: base 0x0 stack 0x0 routine 0x0 count 0x0
========= Register Memory Dump ================
Reg00(PC ): 19FAA8
Reg01(MSR ): 21230
Reg02(CR ): 33000033 [Not RAM Addr]
Reg03(LR ): 19FAA8
Reg04(CTR ): 666584
Reg05(XER ): E0000001 [Not RAM Addr]
Reg06(R0 ): 19FAA8
Reg07(R1 ): EC5204
Reg08(R2 ): 0
Reg09(R3 ): 0
Reg10(R4 ): EC511C
Reg11(R5 ): 1C
Reg12(R6 ): 2
Reg13(R7 ): 2380E
Reg14(R8 ): 0
Reg15(R9 ): BA0000
Reg16(R10 ): 380E
Reg17(R11 ): C6FA20
Reg18(R12 ): A0000000 [Not RAM Addr]
Reg19(R13 ): 0
Reg20(R14 ): 0
Reg21(R15 ): 0
Reg22(R16 ): 0
Reg23(R17 ): 0
Reg24(R18 ): 0
Reg25(R19 ): 1001980 [In malloc Block 0x1001950]
Reg26(R20 ): 0
Reg27(R21 ): 0
Reg28(R22 ): 0
Reg29(R23 ): EC5288
Reg30(R24 ): 0
Reg31(R25 ): 0
Reg32(R26 ): 0
Reg33(R27 ): 100080C
Reg34(R28 ): 30
Reg35(R29 ): 0
Reg36(R30 ): 3
Reg37(R31 ): 0
Reg47(DEAR): 0
buffer check=0 sched_hc=0x0
---- block0 ptr=EC511C is_malloc=0 length=0x2E8 ----
EC50DC: 10051D4 EC51DC EC515C 5E8CC 30051D4 EC51DC EC515C 8D7D84
EC50FC: 10051D4 EC51DC EC515C 2E89AC 10051D4 EC51DC EC515C 1
EC511C: 30051D4 EC51DC EC515C 1C5384 10051D4 EC51DC EC515C 0
EC513C: 0 100080C 19FAA4 0 3 9B42B4 EC51D4 5E8D0
EC515C: 0 9B42B4 0 EC51EC 0 FFFFFFFF 5E880 1
EC517C: EC5204 728A8 30 0 0 EC51EC 0 0
EC519C: C00000 BA0000 C18AB8 EC5164 0 0 5E880 0
EC51BC: EC51D4 0 19FAA4 0 3 9B42B4 EC51EC 1A36A8
EC51DC: 2E89AC 0 3 BB8 EC5204 175BD0 30 0
EC51FC: 3 0 EC5214 19FAA8 0 0 EC5224 1AB2A4
EC521C: 0 14 EC523C 1AB7D8 B220E8 1001980 2E8A28 21230
EC523C: EC5288 1A22AC 10000 FDABEC EC5288 0 0 3
EC525C: 2 E8000000 0 0 138024 FDABEC 33000035 64
EC527C: C0000001 1001980 2732A6 EC5288 2E89AC 10000 FDABEC EC5288
EC529C: 0 0 3 2 E8000000 0 0 138024
EC52BC: FDABEC 33000035 64 C0000001 2E8978 21230 FFFFFFFF 0
EC52DC: 0 0 EC5338 0 138087 420C 0 0
EC52FC: EC5338 EC52D8 0 0 1382B8 14248 0 0
EC531C: 0 EC52D8 0 0 0 4248 0 EC52F8
EC533C: EC52F8 EC52D8 0 0 138087 24248 0 0
EC535C: 138087 4 4 0 0 0 0 0
EC537C: 0 0 1A3B30 FFFFFFFF FD0110DF AB1234CD 1C0000 1D
EC539C: AB0808 1742E0 EC568C EC3C00 80000166 1 0 24
EC53BC: CF0B50 EC3C1C D556D4 0 0 0 0 0
EC53DC: 0 0 0 0 0 0 0 0
EC53FC: 0 FDABEC
---- block1 ptr=19FAA8 is_malloc=0 length=0x100 ----
19FA68: 4BFDC6F9 2F9E0000 419E0038 3D2000C0 8009BBF8 2F800000 40BE0028 3860FFFE
19FA88: 3C80009C 3884D22C 4BED2D8D 2F9E0003 409D0008 3BC00003 1C7E03E8 4BFD6105
19FAA8: 7FE10808 38000000 3D2000B2 90091FA4 80010014 7C0803A6 BBC10008 38210010
19FAC8: 4E800020 7C681B78 7C6A1B78 39200000 89630000 2F8B0000 419E0078 380BFF9F
19FAE8: 2B800005 40BD0010 380BFFD0 2B800009 419D0060 552B2036 880A0000 7C000774
19FB08: 2F800039 419D0014 7D2B0214 3929FFD0 394A0001 48000018 892A0000 7D290774
19FB28: 7D2B4A14 3929FFA9 394A0001 896A0000 2F8B0000 419E001C 380BFF9F 2B800005
19FB48: 40BDFFB4 380BFFD0 2B800009 409DFFA8 38600000 7F8A4000 4D9E0020 91250000
19FB68: 91440000 38600001 4E800020 9421FFF0 7C0802A6 90010014 7C852378 38810008
19FB88: 4BFFFF45 80010014 7C0803A6 38210010 4E800020 9421FFE0 7C0802A6 BFC10018
---- block2 ptr=21230 is_malloc=0 length=0x100 ----
211F0: 480000C4 80010008 2F800001 40BE0038 807EA5D0 80810010 4BFF2E6D 2F830000
21210: 41BE0014 3C600097 3863CAA8 80810010 4803E32D 80610010 4BFFFE91 4BFFFD95
21230: 4BFFFF58 3C60008E 38638CD4 80810008 80A1000C 80C10010 4803D639 4BFFFF3C
21250: 807DA5D0 38800000 4BFF2E1D 2F830000 41BE0010 3C600097 3863CAE4 4803E2E1
21270: 4BFFFD51 2F830000 419E003C 4815415D 38000000 2F830000 41BE000C 48151399
21290: 38000001 2F800000 419EFFD8 48000018 3C60008E 38638C8C 80810014 80A10018
212B0: 4803D5D1 38610014 38810018 48157FF1 2F830000 409EFE88 4BFFFE7C 9421FFF8
212D0: 7C0802A6 9001000C 3C600002 38631104 3D2000BA 80893F58 38A01770 38C00003
212F0: 481532CD 3D2000C0 9069AAA0 3D2000BA 808947EC 3C600002 3863F8B8 3884000C
21310: 4815AA25 3D2000BA 80894790 3C600002 3863CAA8 38840028 4815AA0D 38600003
---- block3 ptr=666584 is_malloc=0 length=0x100 ----
666544: 8809FA20 70090040 4D820020 812B0004 39290001 912B0004 4E800020 3D2000C7
666564: 3969FA20 880B0008 70090040 4D820020 812B000C 39290001 912B000C 4E800020
666584: 3D2000C7 3969FA20 880B0010 70090040 4D820020 812B0014 39290001 912B0014
6665A4: 4E800020 3D2000C7 3969FA20 880B0018 70090040 4D820020 812B001C 39290001
6665C4: 912B001C 4E800020 3D2000C7 3969FA20 880B0020 70090040 4D820020 812B0024
6665E4: 39290001 912B0024 4E800020 3D2000C7 3969FA20 880B0028 70090040 4D820020
666604: 812B002C 39290001 912B002C 4E800020 3D2000C7 3969FA20 880B0030 70090040
666624: 4D820020 812B0034 39290001 912B0034 4E800020 3D2000C7 3969FA20 880B0038
666644: 70090040 4D820020 812B003C 39290001 912B003C 4E800020 39600000 3D2000C7
666664: 3949FA20 38E00000 39000000 55601838 7D205214 7CEA01AE 91090004 396B0001
---- block5 ptr=2380C is_malloc=0 length=0x100 ----
237CC: 3D2000AF 3BA95F30 48000018 3D2000AF 3BA95F34 4800000C 38600000 48000164
237EC: 7FE3FB78 4BFFEE2D 2F830000 409E002C 3D2000C0 8009A0B0 2F800000 41BE001C
2380C: 3C600097 3863CFCC 7F44D378 3D2000BA 80A93F44 4803BD2D 801E0004 2F800003
2382C: 40BE008C 813F0000 81290004 83290008 3D2000BA 81296074 81290E34 7D2903A6
2384C: 7F23CB78 4E800421 2F830000 40BE0034 3D2000C0 8009A0B0 2F800000 41BE00D8
2386C: 3C600097 3863D000 7F44D378 3D2000BA 80A93F44 7F26CB78 4803BCC9 480000B8
2388C: 817F0000 801F0004 813F0008 91610010 90010014 91210018 800B0000 90010010
238AC: 3929FFFF 91210018 3B610010 7F83E378 7FC4F378 7F65DB78 38C10020 4BFFF5B5
238CC: 2F830000 419E0070 801E0004 2F800003 40BE0028 7F83E378 7FA4EB78 7F25CB78
238EC: 80C10020 7FC7F378 4BFFFCD5 2F830000 419E0044 48000030 801E0004 2F800005
---- block6 ptr=BA0000 is_malloc=0 length=0x100 ----
B9FFC0: B9A848 28A 0 861FD8 861FB0 8620A8 862298 0
B9FFE0: 8064000 ADA810 8065000 ADA81C 8066000 ADA824 8067000 ADA830
BA0000: 8068000 ADA83C 0 0 8000064 A63824 8000065 ADA848
BA0020: 0 0 0 ADA8BC 8665A4 8671B4 866A60 866DE8
BA0040: 867490 83EF90 8678C0 8678D4 0 0 0 0
BA0060: ADA8EC 86793C 8679F0 867978 8679B4 0 0 867A2C
BA0080: 867A34 0 0 0 0 4064000 ADA970 407B000
BA00A0: ADA97C 4065000 ADA98C 4066000 ADA9A4 4067000 ADA9BC 4068000
BA00C0: ADA9D4 4069000 ADA9EC 406A000 ADAA00 407C000 ADAA10 406B000
BA00E0: ADAA1C 4079000 ADAA34 406C000 ADAA50 406D000 ADAA70 406E000
---- block7 ptr=380C is_malloc=0 length=0x100 ----
37CC: 3C6000C1 3863D528 7FE4FB78 481ACA35 2F9E0000 419E0010 801E0000 60000002
37EC: 901E0000 38000000 90010008 38610008 7F64DB78 3CA00096 38A55718 481B613D
380C: 80610008 2F830000 41BE0044 4802ABD1 907F00B4 7FE4FB78 48029679 80610008
382C: 481B2489 48000028 801F0010 7F80E000 419E001C 2F9E0000 419E0010 801E0000
384C: 60000004 901E0000 3BE00000 7FE3FB78 8001002C 7C0803A6 BB610014 38210028
386C: 4E800020 38000000 2C030000 41820008 800300A0 7C030378 4E800020 7C691B78
388C: 20030000 7C601914 7CAB2B78 21450000 7CAA2914 38000000 7C6A2B79 4082004C
38AC: 4800000C 38000001 48000040 38000000 900B0000 806900A0 2F830000 419E0028
38CC: 812B0000 39290001 912B0000 80030010 7F802000 41BEFFD0 80630000 2F830000
38EC: 409EFFE0 38000000 7C030378 4E800020 39200000 2C030000 41820028 812300A0
---- block8 ptr=C6FA20 is_malloc=0 length=0x100 ----
C6F9E0: 0 0 0 0 0 0 0 0
C6FA00: 0 0 0 0 0 0 0 0
C6FA20: 0 0 0 0 0 0 0 0
C6FA40: 0 0 0 0 0 0 0 0
C6FA60: 0 C6FA60 E6B0B0 1069CAC 0 13820C 420C 0
C6FA80: 1069BB4 106A07C 3 0 11E841C 11E841C 1 0
C6FAA0: 0 0 0 0 0 0 BE2F1C C6FBFC
C6FAC0: C6FAB0 BB93A8 2EB 10000 0 0 A91D0C 16D758
C6FAE0: B1D128 0 0 0 0 0 0 0
C6FB00: 0 0 0 0 0 0 0 0
---- block9 ptr=1001950 is_malloc=1 length=0xA00 ----
1001910: 0 0 0 0 0 0 0 0
1001930: 0 0 0 0 0 0 0 FD0110DF
1001950: AB1234CD FFFE0000 0 ABD39C 7D81D8 10046E4 FDABD0 800016B2
1001970: 1 0 1 CF1DE8 E8000000 40 A0000000 80000000
1001990: A0000800 0 7101 A0000848 A0000938 1C6A1BC 1 0
10019B0: 0 1C6A9C4 1C6AAA4 1C6AB84 1C6AC64 1 CD25B8 CD2630
10019D0: 14 46 A0000958 A0000970 F5D60C F5A858 F60AC8 F634F8
10019F0: 10019E4 38890156 40000096 104369 73636F20 53797374 656D7300 0
1001A10: 0 0 0 4149 522D4150 31323432 47410000 364D
1001A30: 33302E31 3300003A 9A1096D0 3A00109A D0960020 0 0 4020C0B
1001A50: 16122418 3030FFF 20005 8000B E0011 140010 A0DD0000 630800D
1001A70: 6BBB 0 37B4741 4D313533 3636354E 4300096C 9710976 97B0980
1001A90: 985098A 98F0994 999099E 0 1FF 1F4830 6C600000 FFF
1001AB0: 20005 8000B E0011 0 0 0 0 0
1001AD0: 0 0 0 0 0 0 0 0
1001AF0: 0 0 96C 9710976 97B0980 985098A 98F0994 999099E
1001B10: 9A309A8 9B40000 0 0 0 0 0 0
1001B30: 0 0 0 0 0 0 FFC4FFF5 B23A00
1001B50: 109AD096 0 0 0 0 0 0 0
1001B70: 0 0 0 0 0 0 0 0
1001B90: 0 0 0 0 0 640000 0 10000
1001BB0: 0 0 6C 0 0 6000 5F000000 75355
1001BD0: 1200000 140000 0 0 110000 FF0F0011 FFC40002 4E0000
1001BF0: 2A0000 F80000 0 80000 2020064 1640264 3640464 5640664
1001C10: 7640864 9640A64 B640C64 D640E64 F641064 11641264 13641464 15641664
1001C30: 17641864 19641A64 1B641C64 1D641E64 1F642064 21642264 23642464 25642664
1001C50: 27642864 29642A64 2B642C64 2D642E62 2F60305E 315C325A 33583456 35543652
1001C70: 3750384E 394C3A4A 3B483C46 3D443E42 3F40403E 413C423A 43384436 45344632
1001C90: 4730482E 492C4A2A 4B284C26 4D244E22 4F20501E 511C521A 53185416 55145612
1001CB0: 5710580E 590C5A0A 5B095C08 5D075E06 5F056004 61036202 63016400 65006600
1001CD0: 67006800 69006A00 6B006C00 6D006E00 6F007000 71007200 73007400 75007600
1001CF0: 77007800 79007A00 7B007C00 7D007E00 7F008000 81008200 83008400 85008600
1001D10: 87008800 89008A00 8B008C00 8D008E00 8F009000 91009200 93009400 95009600
1001D30: 97009800 99009A00 9B009C00 9D009E00 9F00A000 A100A200 A300A400 A500A600
1001D50: A700A800 A900AA00 AB00AC00 AD00AE00 AF00B000 B100B200 B300B400 B500B600
1001D70: B700B800 B900BA00 BB00BC00 BD00BE00 BF00C000 C100C200 C300C400 C500C600
1001D90: C700C800 C900CA00 CB00CC00 CD00CE00 CF00D000 D100D200 D300D400 D500D600
1001DB0: D700D800 D900DA00 DB00DC00 DD00DE00 DF00E000 E100E200 E300E400 E500E600
1001DD0: E700E800 E900EA00 EB00EC00 ED00EE00 EF00F000 F100F200 F300F400 F500F600
1001DF0: F700F800 F900FA00 FB00FC00 FD00FE00 FF000000 0 8000A000 80009228
1001E10: 8000C000 8000A000 0 7A1200 0 0 1 0
1001E30: 0 0 0 0 0 0 0 0
1001E50: 0 0 0 0 0 0 0 0
1001E70: 0 0 0 0 0 0 0 0
1001E90: 0 0 0 0 0 0 0 0
1001EB0: 0 0 0 0 0 0 0 0
1001ED0: 0 0 0 0 0 0 0 0
1001EF0: 0 0 0 0 0 0 0 0
1001F10: 0 0 0 0 0 0 0 0
1001F30: 0 0 0 0 0 0 0 0
1001F50: 0 0 0 0 0 0 0 0
1001F70: 0 0 0 0 0 0 0 0
1001F90: 0 0 0 0 0 0 0 0
1001FB0: 0 0 0 0 0 0 0 0
1001FD0: 0 0 0 0 0 0 0 0
1001FF0: 0 0 0 0 0 0 0 0
1002010: 0 0 0 0 0 0 0 0
1002030: 0 0 0 0 0 0 0 0
1002050: 0 0 0 0 0 0 0 0
1002070: 0 0 0 0 0 0 0 0
1002090: 0 0 0 0 0 0 0 0
10020B0: 0 0 0 0 0 0 0 0
10020D0: 0 0 0 0 0 0 0 0
10020F0: 0 0 0 0 0 0 0 0
1002110: 0 0 0 0 0 0 0 0
1002130: 0 0 0 0 0 0 0 0
1002150: 0 0 0 0 0 0 0 0
1002170: 0 0 0 0 0 0 0 0
1002190: 0 0 0 0 0 0 0 0
10021B0: 0 0 0 0 0 0 0 0
10021D0: 0 0 0 0 0 0 0 0
10021F0: 0 0 0 0 0 0 0 0
1002210: 0 0 0 0 0 0 0 0
1002230: 0 0 0 0 0 0 0 0
1002250: 0 0 0 0 0 0 0 0
1002270: 0 0 0 0 0 0 0 0
1002290: 0 0 0 0 0 0 0 0
10022B0: 0 0 0 0 0 0 0 0
10022D0: 0 0 0 0 0 0 0 0
10022F0: 0 0 0 0 0 0 0 0
1002310: 0 0 0 0 0 0 0 0
1002330: 0 0 0 0 0 0 0 0
---- block10 ptr=100080C is_malloc=0 length=0x100 ----
10007CC: 7D7CA0 7D7DA4 7D7E74 7D7F88 7D1764 7CE818 7CE73C 7D4C30
10007EC: 7D4D0C 7D4E80 7D4ED8 7D49F8 7D4A18 7D4C2C 7D4C28 7D1B00
100080C: 0 0 0 33009 0 EE14A8 FDABEC 1001980
100082C: 0 0 0 0 0 0 0 0
100084C: 0 0 0 0 0 0 0 0
100086C: 0 0 0 0 0 0 0 0
100088C: 0 0 0 0 0 0 0 0
10008AC: 0 0 0 0 500 A506 71000000 E8000000
10008CC: A0000000 80000000 0 0 0 0 0 0
10008EC: 0 4149522D 41503132 34324741 0 0 0 0
---- block11 ptr=1004BC8 is_malloc=1 length=0xA00 ----
1004B88: 0 0 0 0 0 0 0 0
1004BA8: 0 0 0 0 0 0 0 FD0110DF
1004BC8: AB1234CD FFFE0000 0 966878 7B2CBC 1004C28 10046F8 80000018
1004BE8: 1 0 1 CF1DE8 EE1448 0 0 0
1004C08: 0 0 0 0 0 0 0 FD0110DF
1004C28: AB1234CD FFFE0000 0 9BDC80 1ABFB8 10092AC 1004BDC 8000232A
1004C48: 1 0 1 CF1DE8 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004C68: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004C88: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004CA8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004CC8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004CE8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004D08: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004D28: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004D48: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004D68: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004D88: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004DA8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004DC8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004DE8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004E08: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004E28: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004E48: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004E68: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004E88: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004EA8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004EC8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004EE8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004F08: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004F28: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004F48: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004F68: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004F88: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004FA8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004FC8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1004FE8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005008: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005028: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005048: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005068: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005088: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10050A8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10050C8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10050E8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005108: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005128: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005148: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005168: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005188: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10051A8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10051C8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10051E8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005208: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005228: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005248: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005268: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005288: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10052A8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10052C8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10052E8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005308: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005328: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005348: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005368: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005388: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10053A8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10053C8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10053E8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005408: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005428: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005448: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005468: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005488: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10054A8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10054C8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10054E8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005508: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005528: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005548: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005568: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1005588: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10055A8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
---- block12 ptr=9B42B4 is_malloc=0 length=0x100 ----
9B4274: 6C752920 63742025 2D326420 20253138 73000000 54414B45 4E000000 50726F63
9B4294: 6573733A 20257300 4576656E 743A2025 73000000 736C6565 7020756E 74696C00
9B42B4: 736C6565 7020666F 72000000 736C6565 70207065 72696F64 69630000 736C6565
9B42D4: 70206F6E 2074696D 65720000 6D657373 61676520 6576656E 74000000 626F6F6C
9B42F4: 65616E20 27257327 0 6D657373 61676520 71756575 65202725 73270000
9B4314: 745F6964 6C650000 6576656E 74206D61 67696300 70726F63 65737320 64617461
9B4334: 20656E71 75657565 0 70726F63 65737320 64617461 20646571 75657565
9B4354: 0 6D676420 74696D65 72000000 626F6F6C 0 6B656570 0
9B4374: 57617463 68656420 6D657373 61676573 0 57617463 68656420 51756575
9B4394: 65000000 57617463 68656420 426F6F6C 65616E00 57617463 68656420 42697466
---- block13 ptr=C00000 is_malloc=0 length=0x100 ----
BFFFC0: 0 0 0 0 0 0 0 0
BFFFE0: 0 0 0 0 0 0 0 0
C00000: 0 0 0 0 0 0 0 0
C00020: 0 0 0 0 0 0 0 0
C00040: 0 0 0 C1C930 C704B4 2 0 1165108
C00060: 1169464 C00204 CE4538 C0005C BB93A8 B8 10000 2
C00080: FFFF 96E524 16D758 B1D128 0 0 0 0
C000A0: 0 0 0 0 0 0 0 0
C000C0: 0 0 0 0 0 0 0 0
C000E0: 0 0 0 0 0 0 0 0
---- block14 ptr=C18AB8 is_malloc=0 length=0x100 ----
C18A78: 1 0 0 0 C187E0 C1903C C18A80 BB93A8
C18A98: E 90000 0 0 9BDB64 1A27F4 B1D128 0
C18AB8: A2D5472 61636562 61636B3D 20307832 45433644 38203078 32453934 33342030
C18AD8: 78373142 33432030 78373330 37302030 78373238 41382030 78313946 39444320
C18AF8: 30783141 42324134 20307831 41423744 38203078 31413232 41432030 78324538
C18B18: 39414320 30783245 38394143 20307832 45383941 43203078 32453839 41432030
C18B38: 78324538 39414320 30783245 38394143 20307832 45383941 43200043 20000000
C18B58: 0 0 0 0 0 0 0 0
C18B78: 0 0 0 0 0 0 0 0
C18B98: 0 0 0 0 0 0 0 0
---- block15 ptr=B220E8 is_malloc=0 length=0x100 ----
B220A8: BFBBEC BA4914 BA4918 BA4910 0 0 0 0
B220C8: BFBBB0 BA4924 BA4928 BA4920 2328 2328 1004BF8 A498F4
B220E8: BFBBA0 BA4934 BA4938 BA4930 0 0 0 0
B22108: BFBB4C BA4944 BA4948 BA4940 2328 2328 CD2448 9EB028
B22128: BFBB48 BA4954 BA4958 BA4950 0 0 0 0
B22148: 0 9BE1A0 0 1 1 1 1 0
B22168: 1 0 0 0 0 0 0 8
B22188: 0 0 0 0 0 0 0 0
B221A8: 0 0 0 0 0 BBB410 10 11
B221C8: 12 0 8 7 9 6 A 5
---- block16 ptr=FDABBC is_malloc=1 length=0xA00 ----
FDAB7C: F57E28 F61554 F57720 F57018 F5B9EC F58530 F62A6C F5E7A0
FDAB9C: F5F5B0 F5AF60 F62DF0 F57E28 F5739C F5E098 F5C0F4 FD0110DF
FDABBC: AB1234CD FFFE0000 0 A49888 50F040 1001950 FDA2D0 800136B2
FDABDC: 1 0 1 CF1DE8 D15CD15C 20205 0 0
FDABFC: 0 0 0 0 0 1 0 0
FDAC1C: 0 0 0 0 0 0 0 FE72B0
FDAC3C: FDAD4C FDAD4C 105B88C 1056650 0 1 2 0
FDAC5C: 2 4 4 9 A3 1 9 22
FDAC7C: FE72C4 0 FDAC3C 0 0 0 2 3
FDAC9C: 0 0 0 0 0 0 0 0
FDACBC: 0 FE72D8 FDAC3C FDAC80 0 0 0 3
FDACDC: 4 0 1 0 1 2 146 0
FDACFC: 2 44 FE72EC 0 FDACC4 0 0 0
FDAD1C: 4 0 0 0 0 0 0 0
FDAD3C: 0 0 0 FEEF84 0 FDAD90 1058C04 1056C40
FDAD5C: 0 5 0 1E 6 1F 1F 7
FDAD7C: 5 1 7 2 FE72B0 0 FDADD4 0
FDAD9C: 0 0 6 0 0 0 0 0
FDADBC: 0 0 0 0 0 FEEFAC 0 FDAE18
FDADDC: 0 0 0 7 0 0 0 0
FDADFC: 0 0 0 0 0 0 FEEFC0 0
FDAE1C: FDAE5C 0 0 0 8 0 0 0
FDAE3C: 0 0 0 0 0 0 0 FEEFD4
FDAE5C: 0 FDAEA0 0 0 0 9 0 0
FDAE7C: 0 0 0 0 0 0 0 0
FDAE9C: FEEFE8 0 FDAEE4 0 0 0 A 0
FDAEBC: 0 0 0 0 0 0 0 0
FDAEDC: 0 FEEFFC 0 FDAF28 0 0 0 B
FDAEFC: 0 0 0 0 0 0 0 0
FDAF1C: 0 0 FEF010 0 FDAF6C 0 0 0
FDAF3C: C 0 0 0 0 0 0 0
FDAF5C: 0 0 0 FEF024 0 FDAFB0 0 0
FDAF7C: 0 D 0 0 0 0 0 0
FDAF9C: 0 0 0 0 FEF038 0 FDAFF4 0
FDAFBC: 0 0 E 0 0 0 0 0
FDAFDC: 0 0 0 0 0 FEF04C 0 FDB038
FDAFFC: 0 0 0 F 0 0 0 0
FDB01C: 0 0 0 0 0 0 FEF060 0
FDB03C: FDB07C 0 0 0 10 0 0 0
FDB05C: 0 0 0 0 0 0 0 FEF074
FDB07C: 0 FDB0C0 0 0 0 11 0 0
FDB09C: 0 0 0 0 0 0 0 0
FDB0BC: FEF088 0 FDB104 0 0 0 12 0
FDB0DC: 0 0 0 0 0 0 0 0
FDB0FC: 0 FEF09C 0 FDB148 0 0 0 13
FDB11C: 0 0 0 0 0 0 0 0
FDB13C: 0 0 FEF0B0 0 FDABF8 0 0 0
FDB15C: 14 0 0 0 0 0 0 0
FDB17C: 0 0 0 FEF0C4 FDACC4 2 0 1
FDB19C: 0 0 0 0 0 0 0 0
FDB1BC: 0 0 0 0 0 0 0 0
FDB1DC: 0 0 0 0 0 0 0 0
FDB1FC: 0 0 0 0 0 0 0 0
FDB21C: 0 0 0 0 0 0 3A9A10 96D00003
FDB23C: 10 1F 20000 FDAD4C 0 0 0 0
FDB25C: 0 0 0 0 0 FDAD90 1 0
FDB27C: 0 0 0 0 0 0 0 FDADD4
FDB29C: 2 0 0 0 0 0 0 0
FDB2BC: 0 FDAE18 3 0 0 0 0 0
FDB2DC: 0 0 0 FDAE5C 4 0 0 0
FDB2FC: 0 0 0 0 0 FDAEA0 5 0
FDB31C: 0 0 0 0 0 0 0 FDAEE4
FDB33C: 6 0 0 0 0 0 0 0
FDB35C: 0 FDAF28 7 0 0 0 0 0
FDB37C: 0 0 0 FDAF6C 8 0 0 0
FDB39C: 0 0 0 0 0 FDAFB0 9 0
FDB3BC: 0 0 0 0 0 0 0 FDAFF4
FDB3DC: A 0 0 0 0 0 0 0
FDB3FC: 0 FDB038 B 0 0 0 0 0
FDB41C: 0 0 0 FDB07C C 0 0 0
FDB43C: 0 0 0 0 0 FDB0C0 D 0
FDB45C: 0 0 0 0 0 0 0 FDB104
FDB47C: E 0 0 0 0 0 0 0
FDB49C: 0 FDB148 F 0 0 0 C0000000 8C5877AB
FDB4BC: 20F4003A 9A1096D0 3A9A10 96D00000 0 0 FDB4B8 FDB4BE
FDB4DC: 18000000 8020000 33330001 2003A 9A1096D0 EC9A74FE C5530000 0
FDB4FC: 0 FDB4E4 FDB4F0 18000000 8030000 0 0 0
FDB51C: 0 0 0 0 FDB51C FDB524 1E000000 0
FDB53C: 0 0 0 0 0 0 0 1000000
FDB55C: 0 0 0 10100000 170AC81 12AD7968 80000F0 9439E532
FDB57C: 1E2F0800 1009439 E5321E2F 8000160 AC8112A9 89D50800 170AC81 12A989D5
FDB59C: 800DE10 8C5877AB 20F40800 DE208C58 77AB20F4 8000160 AD8112AC 93CF0800
---- block17 ptr=ADA83C is_malloc=0 length=0x100 ----
ADA7FC: 302E392E 37622031 30204170 72203230 30330000 4F424A5F 63726561 74650000
ADA81C: 4F424A5F 64757000 4F424A5F 6E696432 6C6E0000 4F424A5F 6E696432 6F626A00
ADA83C: 4F424A5F 6E696432 736E0000 756E6B6E 6F776E20 6E696400 2E2E2F63 72797074
ADA85C: 6F2F7373 6C2F7273 615F6368 6B2E6300 2E2E2F63 72797074 6F2F7373 6C2F7273
ADA87C: 615F6E6F 6E652E63 0 2E2E2F63 72797074 6F2F7373 6C2F7273 615F7369
ADA89C: 676E2E63 0 2E2E2F63 72797074 6F2F7373 6C2F6F62 6A5F6C69 622E6300
ADA8BC: 45726963 20596F75 6E672773 20504B43 53233120 52534100 2E2E2F63 72797074
ADA8DC: 6F2F7373 6C2F7273 615F6561 792E6300 4E756C6C 20525341 0 2E2E2F63
ADA8FC: 72797074 6F2F7373 6C2F7273 615F6E75 6C6C2E63 0 2E2E2F63 72797074
ADA91C: 6F2F7373 6C2F7273 615F7373 6C2E6300 53746163 6B207061 7274206F 66204F70
---- block18 ptr=A63824 is_malloc=0 length=0x100 ----
A637E4: 6E666967 75726520 75736572 6E616D65 20616E64 20706173 73776F72 642D2000
A63804: 776C6363 70206170 20757365 726E616D 650A0000 A77635F 69703A20 20257320
A63824: 6D616C6C 6F632066 61696C75 72650000 77635F69 705F6772 655F7072 6F636573
A63844: 73000000 A77635F 69703A20 20456E61 626C6520 57697265 6C657373 20436F6E
A63864: 74726F6C 204C6179 65722033 2E2E2E2E 0 A77635F 69703A20 20257320
A63884: 6D6E2025 65000000 A77635F 69703A20 20446973 61626C65 20576972 656C6573
A638A4: 7320436F 6E74726F 6C204C61 79657220 332E2E2E 2E000000 A77635F 69703A20
A638C4: 20666169 6C656420 746F2064 65737472 6F792077 635F6970 5F676C6F 62616C5F
A638E4: 7074722D 3E776F72 6B715F73 70206368 756E6B20 A202020 20202020 20202020
A63904: 20202020 20202020 20202020 2020706F 6F6C2E0A 0 77635F69 70000000
---- block19 ptr=ADA970 is_malloc=0 length=0x100 ----
ADA930: 6B207061 7274206F 66204F70 656E5353 4C20302E 392E3762 20313020 41707220
ADA950: 32303033 0 2E2E2F63 72797074 6F2F7373 6C2F7374 61636B2E 63000000
ADA970: 4D454D4F 52595F4C 4F434B00 5253415F 63686563 6B5F6B65 79000000 5253415F
ADA990: 4541595F 50524956 4154455F 44454352 59505400 5253415F 4541595F 50524956
ADA9B0: 4154455F 454E4352 59505400 5253415F 4541595F 5055424C 49435F44 45435259
ADA9D0: 50540000 5253415F 4541595F 5055424C 49435F45 4E435259 50540000 5253415F
ADA9F0: 67656E65 72617465 5F6B6579 0 5253415F 6E65775F 6D657468 6F640000
ADAA10: 5253415F 4E554C4C 0 5253415F 70616464 696E675F 6164645F 6E6F6E65
ADAA30: 0 5253415F 70616464 696E675F 6164645F 504B4353 315F4F41 45500000
ADAA50: 5253415F 70616464 696E675F 6164645F 504B4353 315F7479 70655F31 0
---- block20 ptr=ADAA70 is_malloc=0 length=0x100 ----
ADAA70: 5253415F 70616464 696E675F 6164645F 504B4353 315F7479 70655F32 0
ADAA90: 5253415F 70616464 696E675F 6164645F 53534C76 32330000 5253415F 70616464
ADAAB0: 696E675F 63686563 6B5F6E6F 6E650000 5253415F 70616464 696E675F 63686563
ADAAD0: 6B5F504B 4353315F 4F414550 0 5253415F 70616464 696E675F 63686563
ADAAF0: 6B5F504B 4353315F 74797065 5F310000 5253415F 70616464 696E675F 63686563
ADAB10: 6B5F504B 4353315F 74797065 5F320000 5253415F 70616464 696E675F 63686563
ADAB30: 6B5F5353 4C763233 0 5253415F 7072696E 74000000 5253415F 7072696E
ADAB50: 745F6670 0 5253415F 7369676E 0 5253415F 7369676E 5F41534E
---- block21 ptr=E6AEC8 is_malloc=1 length=0x354 ----
E6AE88: E6B118 E6B0B0 1 C6FA60 E6AEC8 16EA10 0 13820C
E6AEA8: 0 0 E6AEC8 BA0000 C00000 E6B24C 0 0
E6AEC8: E6AEE0 176460 C70000 C00000 C6FA60 11E8514 E6AF10 667494
E6AEE8: 0 13820C 1 0 0 0 0 0
E6AF08: 0 0 0 1A3B30 FFFFFFFF FD0110DF AB1234CD F0000
E6AF28: F AB0808 1742E0 E6B21C E69790 80000166 1 0
E6AF48: 16 CF126C E697AC E6AEC8 0 0 0 0
E6AF68: 0 0 0 0 0 0 0 0
E6AF88: 0 C6FA60 BA0000 C00000 E6B24C 0 0 30000005
E6AFA8: 176464 29230 0 0 0 667470 0 10100
E6AFC8: 1 0 0 0 4 F 667490 17637C
E6AFE8: 0 0 0 1B64 1B64 0 0 F
E6B008: 0 0 0 1377C2 0 0 0 1377C2
E6B028: 0 1377C2 0 11E8F60 17D 0 A8E9C8 3
E6B048: 0 0 0 0 1770 1770 CD08EC 0
E6B068: 0 0 0 0 0 D4A2C4 1122134 E6AF50
E6B088: C19034 0 1122148 1127CB8 BBB3F0 E6B0B0 0 13820C
E6B0A8: 421C 0 0 E6B0B0 E6B090 C6FA60 0 13820C
E6B0C8: 42AC E6AF50 0 0 0 0 E6B090 E6AF50
E6B0E8: 0 0 142E4 0 0 0 E6B090 E6AF50
E6B108: 0 0 242E4 0 C6FA60 0 0 0
E6B128: 0 E6B24C 0 0 0 0 0 0
E6B148: 0 0 0 E6B2AC E6B140 E6B254 0 C188C8
E6B168: 0 0 0 0 0 0 0 FFFFFFF
E6B188: FFFFFFF 0 0 0 0 0 0 0
E6B1A8: 0 E6B35C 0 0 32 0 0 4FA
E6B1C8: 0 D4BAD4 D4BAD4 CF12C0 E6B25C E6B1CC BB93A8 EC
E6B1E8: D0000 1 0 9B41DC 16D758 B1D128 0 CF126C
E6B208: 0 0 BEEFCAFE 0 FD0110DF
---- block22 ptr=1069B84 is_malloc=1 length=0x1F8 ----
1069B44: BE5BD8 BE5BD8 BE5BD8 1069DD0 0 1 0 1
1069B64: 0 1 1 0 0 1069A78 0 FD0110DF
1069B84: AB1234CD FFFE0000 0 966878 666708 1069C18 1069B24 80000032
1069BA4: 1 0 1 CF1DE8 1069E44 1069A78 4D2 0
1069BC4: 93CA99 166D3 A2CA 0 BA89C2 0 0 18561
1069BE4: 126A9 0 0 1069C48 0 93CA99 0 BA89C2
1069C04: 0 C409 0 5EB8 FD0110DF AB1234CD FFFE0000 0
1069C24: 966878 66673C 1069C7C 1069B98 8000001A 1 0 1
1069C44: CF1DE8 A2CA BA45 0 6C64 0 A2CA 0
1069C64: 0 0 BA45 0 6C64 FD0110DF AB1234CD FFFE0000
1069C84: 0 966878 666798 1069CD8 1069C2C 80000016 1 0
1069CA4: 1 CF1DE8 11E8514 11E8514 C6FA60 1069CAC 0 13820C
1069CC4: 4248 0 0 2710 FD0110DF AB1234CD FFFE0000 0
1069CE4: A20FE4 42035C 1069D44 1069C90 8000001E 1 0 1
1069D04: CF1DE8 0 2 3 0 1 10092DC 1069DD0
1069D24: 1069E44 0 0 0 0 0 0 FD0110DF
1069D44: AB1234CD FFFE0000 0 966878 4230F8 1069DA0 1069CEC 80000016
1069D64: 1 0 1 CF1DE8 0 EBA878
---- block23 ptr=1069FD8 is_malloc=1 length=0x174 ----
1069F98: 1 0 1 CF1DE8 11C4EE0 EBA830 0 1069FB8
1069FB8: 3 3 46617374 45746865 726E6574 30000000 0 FD0110DF
1069FD8: AB1234CD FFFE0000 0 A20FF0 420540 106A04C 1069F8C 80000022
1069FF8: 1 0 1 CF1DE8 11C4F38 BE5BD8 BE5BD8 BE5BD8
106A018: 11C4F38 1069DD0 3 0 3 0 1 0
106A038: 0 0 1069F3C 0 FD0110DF AB1234CD FFFE0000 0
106A058: 966878 666708 106A0E0 1069FEC 80000032 1 0 1
106A078: CF1DE8 0 1069F3C 4D2 0 6CC2F2 EC87 A645
106A098: 0 551A43 0 0 DA74 A429 0 0
106A0B8: 106A110 0 6CC2F2 0 551A43 0 4642 0
106A0D8: 364B FD0110DF AB1234CD FFFE0000 0 966878 66673C 106A144
106A0F8: 106A060 8000001A 1 0 1 CF1DE8 A619 5DE0
106A118: 2C 4649 0 A619 0 2C 0 5DE0
106A138: 0 4649 FD0110DF AB1234CD FFFE0000
---- block24 ptr=11E8378 is_malloc=1 length=0x174 ----
11E8338: 11E8378 11E82CC 80000012 1 0 1 CF1DE8 0
11E8358: EBA838 0 11E8364 5 3 42564931 0 FD0110DF
11E8378: AB1234CD FFFE0000 0 A20FF0 420540 11E83EC 11E8338 80000022
11E8398: 1 0 1 CF1DE8 11C4F38 BE5BD8 BE5BD8 BE5BD8
11E83B8: 0 11C4F38 5 0 5 0 1 0
11E83D8: 0 0 11E82E8 0 FD0110DF AB1234CD FFFE0000 0
11E83F8: 966878 666708 11E8480 11E838C 80000032 1 0 1
11E8418: CF1DE8 0 11E82E8 4D2 1 2FE338 83AF 0
11E8438: 0 4951 0 0 9A 0 0 0
11E8458: 11E84B0 0 2FE338 0 4951 0 83AF 0
11E8478: 9A FD0110DF AB1234CD FFFE0000 0 966878 66673C 11E84E4
11E8498: 11E8400 8000001A 1 0 1 CF1DE8 0 0
11E84B8: 0 0 0 0 0 0 0 0
11E84D8: 0 0 FD0110DF AB1234CD FFFE0000
---- block25 ptr=BE2F14 is_malloc=0 length=0x108 ----
BE2ED4: 0 0 0 0 0 0 0 0
BE2EF4: 0 0 0 0 0 0 0 0
BE2F14: 0 0 BE2F54 C6FAB8 BE2F14 BB93A8 2EC 10000
BE2F34: 0 0 A91D24 16D758 B1D128 0 0 0
BE2F54: BE5770 BE2F1C BE2F4C BB93A8 2ED 10000 0 0
BE2F74: A91D3C 16D758 B1D128 0 0 0 0 0
BE2F94: 0 0 0 0 0 0 0 0
BE2FB4: 0 0 0 0 0 0 0 0
BE2FD4: 0 0 0 0 0 0 0 0
BE2FF4: 0 0 0 0 0 0 0 0
BE3014: 0 0
---- block26 ptr=ABD39C is_malloc=0 length=0x100 ----
ABD35C: 25642C25 64292E0A 0 A20646F 74313128 726D293A 20476F74 20696E76
ABD37C: 616C6964 20646470 20524D20 52494452 50542028 25642C25 642C2564 290A0000
ABD39C: 44495343 20737065 63696669 63207374 72756374 75726520 6D656D62 65727300
ABD3BC: 646F7431 315F6469 61670000 A556E61 626C6520 746F2061 64642070 61727365
ABD3DC: 7220636F 6D6D616E 64732066 6F722064 65627567 67657200 69665F64 6F743131
ABD3FC: 5F68616C 5F613530 78000000 A282575 29205B25 752F2575 2F25755D 205B2575
ABD41C: 2F25755D 0 5B25645D 3A202564 20200000 A414D41 43204462 67205372
ABD43C: 763A2074 6F6F206D 616E7920 72616469 6F733A20 25640000 A414D41 43204462
ABD45C: 67205372 763A2063 616E206E 6F742073 74617274 20414D41 43204465 62756767
ABD47C: 65722053 65727665 72000000 A414D41 43204462 67205372 763A2063 6D642073
---- block27 ptr=10046E4 is_malloc=1 length=0x4E4 ----
10046A4: 0 0 0 0 0 0 0 0
10046C4: 0 0 0 0 0 2 FFFFFFCC FD0110DF
10046E4: AB1234CD FFFE0000 0 966878 50F460 1004BC8 1001964 8000025A
1004704: 1 0 1 CF1DE8 0 0 0 0
1004724: 0 0 0 0 0 0 0 0
1004744: 0 0 0 0 0 0 0 0
1004764: 0 0 0 0 0 0 0 0
1004784: 0 0 0 0 0 0 0 0
10047A4: 0 0 0 0 0 0 0 0
10047C4: 0 0 0 0 0 0 0 0
10047E4: 0 0 0 0 0 0 0 0
1004804: 0 0 0 0 0 0 0 0
1004824: 0 0 0 0 0 0 0 0
1004844: 0 0 0 0 0 0 0 0
1004864: 0 0 0 0 0 0 0 0
1004884: 0 0 0 0 0 0 0 0
10048A4: 0 0 0 0 0 0 0 0
10048C4: 0 0 0 0 0 0 0 0
10048E4: 0 0 0 0 0 0 0 0
1004904: 0 0 0 0 0 0 0 0
1004924: 0 0 0 0 0 0 0 0
1004944: 0 0 0 0 0 0 0 0
1004964: 0 0 0 0 0 0 0 0
1004984: 0 0 0 0 0 0 0 0
10049A4: 0 0 0 0 0 0 0 0
10049C4: 0 0 0 0 0 0 0 0
10049E4: 0 0 0 0 0 0 0 0
1004A04: 0 0 0 0 0 0 0 0
1004A24: 0 0 0 0 0 0 0 0
1004A44: 0 0 0 0 0 0 0 0
1004A64: 0 0 0 0 0 0 0 0
1004A84: 0 0 0 0 0 0 0 0
1004AA4: 0 0 0 0 0 0 0 0
1004AC4: 0 0 0 0 0 0 0 0
1004AE4: 0 0 0 0 0 0 0 0
1004B04: 0 0 0 0 0 0 0 0
1004B24: 0 0 0 0 0 0 0 0
1004B44: 0 0 0 0 0 0 0 0
1004B64: 0 0 0 0 0 0 0 0
1004B84: 0 0 0 0 0 0 0 0
1004BA4: 0 0 0 0 0 0 0 0
1004BC4: FD0110DF
---- block28 ptr=CF1D98 is_malloc=0 length=0x150 ----
CF1D58: CED074 0 1000002 0 CECE00 0 0 0
CF1D78: FF CEB454 0 0 0 0 0 0
CF1D98: CF1D0C CF1E24 CF1D5C CECE48 CE57E0 CE56E8 CE57A0 CE581C
CF1DB8: CF1DA8 BB93A8 37 90000 3 0 9B4F70 16D758
CF1DD8: B1D128 0 0 CED074 0 1000001 0 CECE00
CF1DF8: 0 0 0 FF CEB468 0 0 0
CF1E18: 0 0 0 CF1D98 0 CF1DE8 CECE48 CE5954
CF1E38: CE585C CE5914 CECE88 CF1E34 BB93A8 33 90000 3
CF1E58: 0 9B4F70 16D758 B1D128 0 0 0 0
CF1E78: 0 0 0 0 0 0 0 FD0110DF
CF1E98: AB1234CD FFFE0000 0 9786A0 7BFD4 CF1EFC CED058 8000001A
CF1EB8: 1 1B7EC4 1 CF1DE8 63707500 0 0 0
CF1ED8: 0 0 0 0
---- block29 ptr=1C6A18C is_malloc=1 length=0x808 ----
1C6A14C: 0 0 0 0 0 0 0 0
1C6A16C: 0 0 0 0 0 0 0 FD0110DF
1C6A18C: AB1234CD FFFE0000 0 966878 7D1C10 1C6A994 1C6970C 800003EC
1C6A1AC: 1 0 1 CF1DE8 B200003A 9A1096D0 0 0
1C6A1CC: 0 0 0 0 0 0 0 0
1C6A1EC: 0 0 0 0 0 0 0 0
1C6A20C: 0 0 64000000 0 1000000 0 0 6C00
1C6A22C: 0 0 60 5F0000 7005553 20010000 14000000 0
1C6A24C: 0 11000000 FFF1100 C4FF0200 4E000000 2A000000 F8000000 0
1C6A26C: 8000000 0 0 0 0 0 32000000 1D000000
1C6A28C: 0 0 0 2000000 0 0 0 0
1C6A2AC: 0 0 0 0 0 0 0 0
1C6A2CC: 0 0 0 0 0 0 0 0
1C6A2EC: 0 0 0 0 0 0 0 0
1C6A30C: 0 0 0 0 0 0 0 0
1C6A32C: 54630000 875B0000 4B474C00 5000000 0 0 0 0
1C6A34C: 0 0 0 0 0 0 0 0
1C6A36C: 0 0 0 0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1C6A38C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF EF00F0 F100F2 F300F4 F500F6
1C6A3AC: F700F8 F900FA FB00FC FD00FE FF0000 0 0 0
1C6A3CC: 0 0 0 0 0 0 0 0
1C6A3EC: 0 0 0 0 0 0 0 0
1C6A40C: 0 0 0 0 0 0 0 0
1C6A42C: 0 0 0 0 0 0 0 0
1C6A44C: 0 0 0 0 0 0 0 0
1C6A46C: 0 0 0 0 0 0 0 0
1C6A48C: 0 0 0 0 0 0 0 0
1C6A4AC: 0 0 0 0 0 0 0 0
1C6A4CC: 0 0 0 0 0 0 0 0
1C6A4EC: 0 0 0 0 0 0 0 0
1C6A50C: 0 0 0 0 0 0 0 0
1C6A52C: 0 0 0 0 0 0 0 0
1C6A54C: 0 0 0 0 0 0 0 0
1C6A56C: 0 0 0 0 0 0 0 0
1C6A58C: 0 0 0 0 0 0 0 0
1C6A5AC: 0 0 0 0 0 0 0 0
1C6A5CC: 0 0 0 0 0 0 0 0
1C6A5EC: 0 0 0 0 0 0 0 0
1C6A60C: 0 0 0 0 0 0 0 0
1C6A62C: 0 0 0 0 0 0 0 0
1C6A64C: 0 0 0 0 0 0 0 0
1C6A66C: 0 0 0 0 0 0 0 0
1C6A68C: 0 0 0 0 0 0 0 0
1C6A6AC: 0 0 0 0 0 0 0 0
1C6A6CC: 0 0 0 0 0 0 0 0
1C6A6EC: 0 0 0 0 0 0 0 0
1C6A70C: 0 0 0 0 0 0 0 0
1C6A72C: 0 0 0 0 0 0 0 0
1C6A74C: 0 0 0 0 0 0 0 0
1C6A76C: 0 0 0 0 0 0 0 0
1C6A78C: 0 0 0 0 0 0 0 0
1C6A7AC: 0 0 0 0 0 0 0 0
1C6A7CC: 0 0 0 0 0 0 0 0
1C6A7EC: 0 0 0 0 0 0 0 0
1C6A80C: 0 0 0 0 0 0 0 0
1C6A82C: 0 0 0 0 0 0 0 0
1C6A84C: 0 0 0 0 0 0 0 0
1C6A86C: 0 0 0 0 0 0 0 0
1C6A88C: 0 0 0 0 0 0 0 0
1C6A8AC: 0 0 0 0 0 0 0 0
1C6A8CC: 0 0 0 0 0 0 0 0
1C6A8EC: 0 0 0 0 0 0 0 0
1C6A90C: 0 0 0 0 0 0 0 0
1C6A92C: 0 0 0 0 0 0 0 0
1C6A94C: 0 0 0 0 0 0 0 0
1C6A96C: 0 0 0 0 0 0 0 0
1C6A98C: 0 FD0110DF
---- block30 ptr=1C6A994 is_malloc=1 length=0x100 ----
1C6A954: 0 0 0 0 0 0 0 0
1C6A974: 0 0 0 0 0 0 0 FD0110DF
1C6A994: AB1234CD FFFE0000 0 966878 7D3188 1C6AA74 1C6A1A0 80000058
1C6A9B4: 1 0 1 CF1DE8 CD26A8 3A00 2F080000 48B
1C6A9D4: 3A001E 8220000 FFFFFFFF FFFF003A 9A1096D0 7E90F C7D840A5 0
1C6A9F4: 1200 AAAA0000 0 0 FFFFFFFF 8417AAAA 38008121 C4A5FA17
1C6AA14: 13D10 200 7E90F C7D80000 0 0 0 0
1C6AA34: 0 0 0 0 0 0 0 0
1C6AA54: 0 0 0 0 0 0 0 FD0110DF
1C6AA74: AB1234CD FFFE0000 0 966878 7D3188 1C6AB54 1C6A9A8 80000058
---- block31 ptr=EE1418 is_malloc=1 length=0xA00 ----
EE13D8: 9786A0 7BFD4 EE1418 EE131C 8000000E 1 0 1
EE13F8: CF1DE8 446F7431 31206472 69766572 206C6F67 0 0 FD0110DF
EE1418: AB1234CD FFFE0000 0 966878 7B2CBC EE1478 EE13E0 80000018
EE1438: 1 0 1 CF1DE8 EC57CC 0 0 0
EE1458: 0 0 0 0 0 0 0 FD0110DF
EE1478: AB1234CD FFFE0000 0 99AB9C 105DFC EE2014 EE142C 800005B6
EE1498: 1 0 1 CF1DE8 10092DC 0 0 0
EE14B8: 0 0 EE2044 EA 0 5157C8 3 0
EE14D8: 0 1000000 0 23E184 2 0 0 0
EE14F8: 1 5EA E 0 0 0 0 0
EE1518: 0 0 0 5EA 0 0 0 0
EE1538: 1 1 2 0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
EE1558: 0 0 0 0 0 0 0 0
EE1578: 0 0 9A3AD4 A4995C EE26B4 EE2700 5DC05DC 1
EE1598: 5F4 8FC EE274C 1 0 210040 10 0
EE15B8: 0 40000000 4 5 0 5 0 0
EE15D8: 0 138021 0 14994E 0 0 0 7CA5
EE15F8: 0 0 C16DC0 EE14A8 0 0 1424C 0
EE1618: 0 0 0 978C70 FDABEC 0 1 1
EE1638: 1 0 0 0 0 50DF64 1010001 FD000009
EE1658: 0 0 0 0 0 0 0 0
EE1678: 0 0 0 0 0 0 0 0
EE1698: 0 0 0 0 0 0 0 0
EE16B8: 0 0 0 1E 1E 1E 1E 1E
EE16D8: 1E 1E 1E 1E 1E 1E 1E 1E
EE16F8: 1E 1E 1E 1E 0 0 0 1E
EE1718: 0 0 0 1E 0 0 0 1E
EE1738: 0 0 0 1E 0 0 0 1E
EE1758: 0 0 0 1E 0 0 0 1E
EE1778: 0 0 0 1E 0 0 0 1E
EE1798: 0 0 0 1E 0 0 0 1E
EE17B8: 0 0 0 1E 0 0 0 1E
EE17D8: 0 0 0 1E 0 0 0 1E
EE17F8: 0 0 0 1E 0 0 0 1E
EE1818: 0 EE14A8 0 0 0 467 467 0
EE1838: 0 0 10559C 1055F4 0 20C234 20B8D0 0
EE1858: 86E18 0 0 51B108 0 0 104834 1050A4
EE1878: 0 126C88 0 20AE30 503AD0 503B24 20F1C4 50E4CC
EE1898: 20A940 0 20AD84 0 0 0 0 503D78
EE18B8: 503B04 503D8C 503D8C 503D8C 0 0 51B100 0
EE18D8: 0 0 0 0 0 0 0 0
EE18F8: 0 0 4FA6A0 4FB8B0 0 0 0 0
EE1918: 0 0 0 0 0 1281A 0 BB612A
EE1938: 34 0 94838E 2C 0 7480 0 0
EE1958: 0 32CFE1 A361 0 0 0 0 0
EE1978: 0 0 0 0 0 0 0 0
EE1998: 12A7C E3 0 0 0 0 21E7 0
EE19B8: 0 0 0 0 0 0 0 0
EE19D8: 0 0 0 0 0 0 0 0
EE19F8: 0 0 E929 0 0 0 0 0
EE1A18: 0 0 0 0 0 0 0 0
EE1A38: 0 0 2 0 0 0 0 0
EE1A58: 96D0D4 18730 38 1689E 35 E3 0 0
EE1A78: 0 6CFA 0 EE1B24 EE1B68 0 0 0
EE1A98: 0 0 E2D238 0 0 0 0 0
EE1AB8: 0 0 0 0 E2D27C 0 0 0
EE1AD8: 0 0 0 0 0 0 0 0
EE1AF8: 0 0 0 0 0 0 0 E2D1B0
EE1B18: 0 0 0 0 0 0 0 0
EE1B38: 0 0 0 0 0 0 0 354
EE1B58: 0 7A30 0 0 0 0 0 0
EE1B78: 0 0 0 0 0 0 3C4 E1F0
EE1B98: 3AF 0 C6EA 0 0 0 0 0
EE1BB8: 0 0 0 138000 0 0 0 0
EE1BD8: C16980 EE14A8 0 0 4424C 0 0 0
EE1BF8: 0 0 0 0 0 0 0 0
EE1C18: 0 0 0 0 0 0 0 0
EE1C38: 0 0 0 0 0 0 0 0
EE1C58: 0 0 0 0 0 0 0 0
EE1C78: 0 0 0 0 0 0 0 0
EE1C98: 0 0 0 0 0 0 0 0
EE1CB8: 0 0 0 0 0 0 0 0
EE1CD8: 0 0 0 0 0 0 0 0
EE1CF8: 0 0 0 0 0 0 0 0
EE1D18: EE2580 FDB71C CD3E7C 10B6A04 10E64BC 11C77A4 E77338 0
EE1D38: 0 0 0 0 0 0 0 0
EE1D58: 0 0 0 0 0 0 0 0
EE1D78: 0 0 0 0 0 0 0 0
EE1D98: 0 0 0 0 0 0 0 E77338
EE1DB8: 0 0 0 0 0 0 1000000 0
EE1DD8: 0 0 0 0 0 0 0 0
EE1DF8: 1000000 0 0 0 0 0 0 0
---- block32 ptr=9BDC80 is_malloc=0 length=0x100 ----
9BDC40: 756E6B73 0 43505520 524F2055 73657273 0 4661696C 65642063
9BDC60: 70755F72 6F20696E 2025733A 25642065 72726F72 20636F64 653A2025 75200A00
9BDC80: 496E7465 72727570 74205374 61636B00 A535441 434B533A 20637265 6174656C
9BDCA0: 6576656C 2063616C 6C656420 77697468 20626164 206C6576 656C206E 756D6265
9BDCC0: 72000000 A535441 434B533A 206D756C 7469706C 65206465 76696365 73206173
9BDCE0: 7369676E 65642074 6F206C65 76656C20 25643A20 25732C20 616E6420 25732E00
9BDD00: A535441 434B533A 20636861 6E67656C 6576656C 2063616C 6C656420 77697468
9BDD20: 20626164 206C6576 656C206E 756D6265 72000000 A535441 434B533A 20617474
9BDD40: 656D7074 20746F20 6368616E 67652061 206E6F6E 2D657869 7374656E 74206C65
9BDD60: 76656C20 25643A20 25730000 A494E54 53544143 4B3A2053 7461636B 20666F72
---- block33 ptr=10092AC is_malloc=1 length=0xA00 ----
100926C: 0 0 FFABEC FDABEC 200 1009298 5285D8 1C
100928C: B220E8 21230 EC5228 FFFFFFFF 2E88EC FFFFFFFF FFFFFFFF FD0110DF
10092AC: AB1234CD FFFE0000 0 99AB9C 105DFC 1009E48 1004C3C 800005B6
10092CC: 1 7D1020 1 CF1DE8 1067440 0 0 0
10092EC: 0 0 CD3EE4 EA 0 5157C8 0 0
100930C: 0 1000000 0 23E184 3 0 0 0
100932C: 1 5EA E 0 0 0 0 0
100934C: 0 0 0 5EA 0 0 0 1
100936C: 2 2 3 0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
100938C: 0 0 0 0 0 0 0 0
10093AC: 0 0 9A3AD4 A49934 CD4554 CD45A0 5DC05DC 1
10093CC: 5F4 8FC EE274C 1 0 210040 10 0
10093EC: 0 40000000 4 5 0 5 0 0
100940C: 0 0 0 0 0 0 0 3CF4
100942C: 0 0 C16DC0 10092DC 0 0 1424C 0
100944C: 0 0 0 978C70 1009E78 0 1 1
100946C: 1 0 0 0 0 50DF64 1010001 FF000009
100948C: 0 0 0 0 0 0 0 0
10094AC: 0 0 0 0 0 0 0 0
10094CC: 0 0 0 0 0 0 0 0
10094EC: 0 0 0 1E 1E 1E 1E 1E
100950C: 1E 1E 1E 1E 1E 1E 1E 1E
100952C: 1E 1E 1E 1E 0 0 0 1E
100954C: 0 0 0 1E 0 0 0 1E
100956C: 0 0 0 1E 0 0 0 1E
100958C: 0 0 0 1E 0 0 0 1E
10095AC: 0 0 0 1E 0 0 0 1E
10095CC: 0 0 0 1E 0 0 0 1E
10095EC: 0 0 0 1E 0 0 0 1E
100960C: 0 0 0 1E 0 0 0 1E
100962C: 0 0 0 1E 0 0 0 1E
100964C: 0 10092DC 0 0 0 467 467 0
100966C: 0 0 10559C 1055F4 0 20C234 20B8D0 0
100968C: 86E18 0 0 51B108 0 0 104834 1050A4
10096AC: 0 126C88 0 20AE30 503AD0 503B24 20F1C4 50E4CC
10096CC: 20A940 0 20AD84 0 0 0 0 503D78
10096EC: 503B04 503D8C 503D8C 503D8C 0 0 51B100 0
100970C: 0 0 0 0 0 0 0 0
100972C: 0 0 4FA6A0 4FB8B0 0 0 0 0
100974C: 0 0 0 0 0 0 0 0
100976C: 0 0 0 0 0 0 0 0
100978C: 0 0 0 0 0 0 0 0
10097AC: 0 0 0 0 0 0 0 0
10097CC: 0 0 0 0 0 0 338 0
10097EC: 0 0 0 0 0 0 0 0
100980C: 0 0 0 0 0 0 0 0
100982C: 0 0 E318 0 0 0 0 0
100984C: 0 0 0 0 0 0 0 0
100986C: 0 0 2 0 0 0 0 0
100988C: 0 0 0 0 0 0 0 0
10098AC: 0 0 0 1009958 100999C 0 0 0
10098CC: 0 0 E2D2C0 0 0 0 0 0
10098EC: 0 0 0 0 E2D304 0 0 0
100990C: 0 0 0 0 0 0 0 0
100992C: 0 0 0 0 0 0 0 0
100994C: 0 0 0 0 0 0 0 0
100996C: 0 0 0 0 0 0 0 0
100998C: 0 0 0 0 0 0 0 0
10099AC: 0 0 0 0 0 0 0 0
10099CC: 0 0 0 0 0 0 0 0
10099EC: 0 0 0 138000 0 0 0 0
1009A0C: C16980 10092DC 0 0 4424C 0 0 0
1009A2C: 0 0 0 0 0 0 0 0
1009A4C: 0 0 0 0 0 0 0 0
1009A6C: 0 0 0 0 0 0 0 0
1009A8C: 0 0 0 0 0 0 0 0
1009AAC: 0 0 0 0 0 0 0 0
1009ACC: 0 0 0 0 0 0 0 0
1009AEC: 0 0 0 0 0 0 0 0
1009B0C: 0 0 0 0 0 0 0 0
1009B2C: 0 0 0 0 0 0 0 0
1009B4C: CD4420 100A9A8 1035AA8 10B6A50 10E5DAC 11C7840 11E6F44 0
1009B6C: 0 0 0 0 0 0 0 0
1009B8C: 0 0 0 0 0 0 0 0
1009BAC: 0 0 0 0 0 0 0 0
1009BCC: 0 0 0 0 0 0 0 11E6F44
1009BEC: 0 0 0 0 0 0 1000000 0
1009C0C: 0 0 0 0 0 0 0 0
1009C2C: 1000000 0 0 0 0 0 0 0
1009C4C: 0 0 0 0 0 0 0 0
1009C6C: 0 0 0 0 0 0 0 0
1009C8C: 0 0 0 0 0 0 0 0
---- block34 ptr=C1C930 is_malloc=0 length=0x100 ----
C1C8F0: 0 0 0 0 0 0 0 0
C1C910: 0 C1C910 EB9F50 121E8B4 0 16E2C9 420C 0
C1C930: C704B4 1 A01D78 9C9540 5 2246FC 86DD8 86DD8
C1C950: 22CFF0 231D78 22C1E0 231CD4 22BCF4 231D40 231DBC 7DC48
C1C970: 227DDC 7DC48 227F6C 2282F8 7DCB0 228044 7DC48 228184
C1C990: 231C28 228354 227FF0 7DC48 4A63C 7DC48 7DC48 7DC48
C1C9B0: 7DC48 7DC48 7DC48 7DC48 7DC48 7DC48 7DC48 231BCC
C1C9D0: 812BC 81350 7DC48 7DC48 7DC48 7DC48 7DC48 7DC48
C1C9F0: 7DC48 7DC48 7DC48 7DC48 7DC50 0 0 0
C1CA10: C24AC8 0 0 0 4204 0 0 C1CA28
---- block35 ptr=C704B4 is_malloc=0 length=0x100 ----
C70474: 7DC48 7DC48 7DC48 7DC48 7DC48 7DC48 7DC48 7DC48
C70494: 7DC48 7DC48 7DC48 7DC48 7DC48 7DC48 7DC48 7DC50
C704B4: 0 2 966CE8 AB1128 6 86DD8 86DD8 86DD8
C704D4: 70EA28 86DD8 86E38 706300 706708 86DD8 709E8C 0
C704F4: 0 0 0 0 0 0 0 0
C70514: 0 0 0 0 0 0 0 0
C70534: 0 0 0 0 0 0 0 0
C70554: 0 0 0 0 0 0 0 0
C70574: 0 0 0 0 0 0 0 0
C70594: 0 0 0 0 0 0 0 0
---- block36 ptr=116508C is_malloc=1 length=0x14C ----
116504C: 9B9EB0 1919B4 116508C 1165008 8000000E 1 0 1
116506C: CF1DE8 190A38 190A40 190A48 0 1904C8 9A3480 FD0110DF
116508C: AB1234CD FFFE0000 0 97FD08 A42E0 11650D8 1165054 8000000E
11650AC: 1 382C 1 CF1DE8 0 0 0 0
11650CC: 0 0 FD0110DF AB1234CD FFFE0000 0 96F274 2E41C
11650EC: 1165138 11650A0 80000018 1 0 1 CF1DE8 1169464
116510C: 0 1169590 C0005C 0 0 0 0 0
116512C: 0 0 FD0110DF AB1234CD FFFE0000 0 97FCFC A4278
116514C: 11651A4 11650EC 8000001E 1 0 1 CF1DE8 1168F5C
116516C: 9E35BC 9E37E0 9E37F4 965C64 0 0 2C1EBC 3
116518C: B3875C 1072298 11651D4 0 0 FD0110DF AB1234CD FFFE0000
11651AC: 0 97FD18 A4304 11651F0 116514C 8000000E 1 0
11651CC: 1 CF1DE8 0
---- block37 ptr=11693E8 is_malloc=1 length=0x14C ----
11693A8: 9656F0 3764 11693E8 11692C4 8000000E 1 0 1
11693C8: CF1DE8 72616469 75730000 0 0 0 0 FD0110DF
11693E8: AB1234CD FFFE0000 0 9786A0 7BFD4 1169434 11693B0 8000000E
1169408: 1 382C 1 CF1DE8 54504C55 53000000 0 0
1169428: 0 0 FD0110DF AB1234CD FFFE0000 0 96F274 2E41C
1169448: 11694A0 11693FC 8000001E 1 0 1 CF1DE8 0
1169468: 1165108 11722FC C0005C 0 0 0 0 0
1169488: 0 0 0 0 0 FD0110DF AB1234CD FFFE0000
11694A8: 0 96F288 2E458 1169560 1169448 80000048 1 0
11694C8: 1 CF1DE8 73616365 1 11716AC 0 1 1
11694E8: 0 0 0 0 11695E0 0 FFFFFFFF FFFFFFFF
1169508: FFFFFFFF 0 0 0 0 0 0 0
1169528: 0 0 1
---- block38 ptr=C001FC is_malloc=0 length=0x108 ----
C001BC: 0 0 0 0 0 0 0 0
C001DC: 0 0 0 0 0 0 0 0
C001FC: 0 0 E29A98 C00064 C001FC BB93A8 B9 10000
C0021C: 0 FFFF 96E578 16D758 B1D128 0 0 0
C0023C: 0 0 0 0 0 0 0 0
C0025C: 0 0 0 0 0 0 0 0
C0027C: 0 0 0 0 0 0 0 0
C0029C: 0 0 0 0 0 0 0 0
C002BC: 0 0 0 0 0 0 0 0
C002DC: 0 0 0 0 0 0 0 0
C002FC: 0 0
---- block39 ptr=BFBB4C is_malloc=0 length=0x154 ----
BFBB0C: 4B9 0 B3B7B8 0 2 0 0 2F60
BFBB2C: CD08EC 0 0 0 E20114 0 C28F18 0
BFBB4C: 1004C58 A 1 428 0 0 0 0
BFBB6C: 177864 C18E74 0 9C4 0 CE0764 D15614 1D4C0
BFBB8C: 453AA0 B10 0 2 0 0 0 1
BFBBAC: 0 1006F80 4E2 EC53C0 8B73F4 BFFD84 1000000 0
BFBBCC: 97 0 8A3 0 0 0 163541 0
BFBBEC: 0 0 0 0 1000000 7D0 5E880 0
BFBC0C: 0 BA5 1A27773 0 5715C 0 0 0
BFBC2C: 0 0 2F60 0 0 0 0 0
BFBC4C: 13780A 0 0 0 0 0 0 0
BFBC6C: 0 0 0 0 0 0 CD7A80 0
BFBC8C: 1C475C 1C479C 0 3 CD7A0C
---- block40 ptr=BA4930 is_malloc=0 length=0x104 ----
BA48F0: 0 0 0 0 0 0 0 0
BA4910: 0 0 0 0 40229E 10092A0 0 0
BA4930: 0 0 0 0 5AA 1006F78 0 0
BA4950: 0 0 0 0 BBB3F0 0 FEEDFACE 0
BA4970: 1ABFB8 1ABF5C 1ABF5C 7B1A70 1ABF5C 1ABF5C 1ABF5C 1ABF80
BA4990: 1ABF64 1ABF5C 1ABF98 1ABF9C 1ABF5C 97 0 1
BA49B0: 1 0 B2215C EC53C0 0 0 0 8DC868
BA49D0: 8DC874 8DC87C 8DC884 8DC88C 8DC894 8DC8D8 6D616C6C 6F630000
BA49F0: 8DC8F0 8DC8F8 8DC900 8DC908 1 64 18 2
BA4A10: 1 1 B223B0 6 1F4 1F4 0 0
BA4A30: EA60
---- block41 ptr=CD2418 is_malloc=1 length=0x100 ----
CD23D8: 45545249 45533A20 5061636B 65742074 6F20636C 69656E74 20386335 382E3737
CD23F8: 61622E32 30663420 72656163 68656420 6D617820 72657472 6965732C FD0110DF
CD2418: AB1234CD FFFE0000 0 98EC98 7B2CBC CD2478 CD21F8 80000018
CD2438: 1 0 1 CF1DE8 0 0 0 0
CD2458: 0 0 0 0 0 0 0 FD0110DF
CD2478: AB1234CD FFFE0000 0 AB7648 7B1108 CD24C4 CD242C 8000000E
CD2498: 1 3195D4 1 CF1DE8 7B0BF4 7B0C10 7B0C20 CD2AD8
CD24B8: 20 1F FD0110DF AB1234CD 270000 28 A36558 4CA1F8
CD24D8: CD2538 CD248C 80000022 1 177830 2F CF054C 11E4A34
CD24F8: CD3EE4 917D10 11C7934 1145FB8 0 0 0 1
---- block42 ptr=9EB028 is_malloc=0 length=0x100 ----
9EAFE8: 20307825 30386C78 2C204941 43332020 3A203078 2530386C 782C2049 41433420
9EB008: 203A2030 78253038 6C780A00 454E4142 4C455F49 4F535F42 5245414B 0
9EB028: 4E533136 35353020 56454354 4F520000 A726573 65745F69 6E746572 72757074
9EB048: 5F6C6576 656C3A20 72657665 72736520 72657365 74206C65 76656C20 63757272
9EB068: 656E7420 6C657665 6C202564 206E6577 206C6576 656C2025 64000000 A20496E
9EB088: 74657272 75707420 5468726F 74746C69 6E673A0A 0 20205468 726F7474
9EB0A8: 6C652043 6F756E74 203D2025 30387520 20205469 6D657220 436F756E 74202020
9EB0C8: 20202020 3D202530 38750A00 20204E65 74696E74 20746963 6B732020 203D2025
9EB0E8: 30387520 20204E65 74696E74 204D6173 6B207469 636B7320 3D202530 38750A00
9EB108: 20204E65 74696E74 20757365 63202020 203D2025 30387520 20204E65 74696E74
---- block43 ptr=BFBB48 is_malloc=0 length=0x100 ----
BFBB08: 67E40 4B9 0 B3B7B8 0 2 0 0
BFBB28: 2F60 CD08EC 0 0 0 E20114 0 C28F18
BFBB48: 0 1004C58 A 1 428 0 0 0
BFBB68: 0 177864 C18E74 0 9C4 0 CE0764 D15614
BFBB88: 1D4C0 453AA0 B10 0 2 0 0 0
BFBBA8: 1 0 1006F80 4E2 EC53C0 8B73F4 BFFD84 1000000
BFBBC8: 0 97 0 8A3 0 0 0 163541
BFBBE8: 0 0 0 0 0 1000000 7D0 5E880
BFBC08: 0 0 BA5 1A27773 0 5715C 0 0
BFBC28: 0 0 0 2F60 0 0 0 0
---- block44 ptr=A49888 is_malloc=0 length=0x100 ----
A49848: 20494442 20746F20 74686520 6D61696E 206C6973 74000000 A526164 696F2564
A49868: 20257320 70726573 656E7420 25782025 78202578 20257820 25782025 78000000
A49888: 3830322E 31312064 72697665 7220496E 7374616E 63650000 A496E63 6F6D7061
A498A8: 7469626C 65204841 4C207665 7273696F 6E20666F 72207468 69732073 6F667477
A498C8: 61726520 72656C65 61736500 696E7466 5F726573 65745F63 6F6D706C 65746500
A498E8: 696E7466 5F726561 64790000 646F7431 31207261 64696F20 696E7465 72727570
A49908: 74000000 3830322E 31314E20 3547487A 20526164 696F0000 3830322E 31312D34
A49928: 2E392052 6164696F 0 3830322E 31314120 52616469 6F000000 3830322E
A49948: 31314E20 322E3447 487A2052 6164696F 0 3830322E 31314720 52616469
A49968: 6F000000 3830322E 31314220 52616469 6F000000 4149522D 4C415031 35323241
---- block45 ptr=FDA2BC is_malloc=1 length=0x900 ----
FDA27C: 0 0 0 0 0 0 0 0
FDA29C: 0 0 0 0 0 0 0 FD0110DF
FDA2BC: AB1234CD FFFE0000 0 8DD934 1C7048 FDABBC FD9F4C 80000468
FDA2DC: 1 0 1 CF1DE8 FD8348 EE2C54 EE2FD8 EE87BC
FDA2FC: EEBC78 EE3A64 EE3DE8 EE416C EE44F0 EE4874 EE6110 EE4F7C
FDA31C: EEB8F4 EE5684 EEDFA0 EE5D8C EE6110 EE6494 EE6818 EE87BC
FDA33C: EEB8F4 EE72A4 EE7628 EEDFA0 EE7D30 EE80B4 EE8438 EEAE68
FDA35C: EE8B40 EE8EC4 EE9248 EE95CC EEB8F4 EE9CD4 EEA058 EEDFA0
FDA37C: EEA760 EEAAE4 EEAE68 EEB1EC EEC704 EEB8F4 EEBC78 EED190
FDA39C: EEC380 EF307C EECA88 EECE0C EF3E8C EED514 EED898 EEDC1C
FDA3BC: EEDFA0 EEE324 EF064C EF0D54 EF307C EEF134 EEF4B8 EEF83C
FDA3DC: EEFBC0 EEFF44 EF02C8 EF226C EF09D0 EF0D54 EF2CF8 EF4594
FDA3FC: EF4C9C EF1B64 EF1EE8 EF226C EF7DD4 EF2974 EF2CF8 EF307C
FDA41C: EF3400 EF3784 EF3B08 EF3E8C EF4210 EF4594 EF4918 EF4C9C
FDA43C: EF6FC4 EF7A50 EF5728 EF8F68 EF5E30 EF61B4 EF99F4 EF68BC
FDA45C: EF6C40 EF6FC4 EF7348 EF76CC EF7A50 EF7DD4 EF8158 EF84DC
FDA47C: EF8860 EF8BE4 EF8F68 EFE3C8 EF9670 EF99F4 EF9D78 EFF1D8
FDA49C: EFA480 EFA804 EFCB2C EFCEB0 EFB290 EFB614 EFB998 EFE044
FDA4BC: EFC0A0 EFEAD0 EFC7A8 F01F8C EFFC64 EFD234 EFD5B8 EFD93C
FDA4DC: EFDCC0 EFE044 EFE3C8 EFE74C F01500 EFEE54 EFF1D8 EFF55C
FDA4FC: EFF8E0 F01F8C EFFFE8 F0036C F006F0 F00A74 F00DF8 F0117C
FDA51C: F03120 F01884 F01C08 F03828 F0900C F02694 F02A18 F049BC
FDA53C: F05448 F05B50 F03828 F03BAC F0AC2C F042B4 F04638 F049BC
FDA55C: F04D40 F050C4 F05448 F057CC F05B50 F05ED4 F0A8A8 F073EC
FDA57C: F0900C F06CE4 F07E78 F09A98 F07770 F0AC2C F07E78 F081FC
FDA59C: F09A98 F08904 F0A8A8 F0EB74 F0AFB0 F09714 F09A98 F0C144
FDA5BC: F0A1A0 F0A524 F0A8A8 F0CF54 F13548 F0B334 F0B6B8 F0BA3C
FDA5DC: F0BDC0 F0C144 F0F984 F0C84C F0CBD0 F0CF54 F0EB74 F13548
FDA5FC: F11220 F0DD64 F0F600 F0E46C F0E7F0 F12738 F12E40 F10E9C
FDA61C: F0F600 F0F984 F0FD08 F1008C F10410 F10794 F12738 F12E40
FDA63C: F11220 F115A4 F11928 F11CAC F15BF4 F123B4 F14DE4 F12ABC
FDA65C: F12E40 F131C4 F13548 F138CC F13C50 F13FD4 F14358 F146DC
FDA67C: F14A60 F15BF4 F18D2C F16A04 F19EC0 F15BF4 F17490 F162FC
FDA69C: F1E18C F17F1C F16D88 F1710C F19EC0 F17814 F1B3D8 F1E18C
FDA6BC: F1B75C F19EC0 F189A8 F21648 F190B0 F19434 F1B75C F19B3C
FDA6DC: F19EC0 F1A244 F1FA28 F1B3D8 F1CC74 F1D700 F1B3D8 F1C56C
FDA6FC: F1BAE0 F1BE64 F21D50 F1C56C F1E18C F1CC74 F1CFF8 F1D37C
FDA71C: F1EC18 F1DA84 F1DE08 F1FA28 F1E510 F204B4 F1EC18 F21D50
FDA73C: F219CC F1F6A4 F271B0 F1FDAC F21648 F227DC F20838 F235EC
FDA75C: F20F40 F28344 F21648 F24078 F22EE4 F220D4 F25C98 F24078
FDA77C: F24780 F22EE4 F23268 F24E88 F271B0 F25C98 F24078 F243FC
FDA79C: F24780 F263A0 F24E88 F27FC0 F25590 F25914 F25C98 F2A9F0
FDA7BC: F263A0 F26724 F26AA8 F26E2C F27FC0 F29154 F278B8 F2DB28
FDA7DC: F27FC0 F2E230 F286C8 F2985C F28DD0 F2A66C F2C610 F2985C
FDA7FC: F29BE0 F29F64 F2DB28 F2BB84 F30FE4 F2AD74 F2B0F8 F2B47C
FDA81C: F2ECBC F2DB28 F2BF08 F30FE4 F2C610 F2C994 F2CD18 F2D09C
FDA83C: F301D4 F2D7A4 F2ECBC F3411C F2E230 F2F748 F32F88 F308DC
FDA85C: F2F040 F2F3C4 F3411C F2FACC F37254 F301D4 F30558 F308DC
FDA87C: F3876C F3411C F31368 F316EC F31A70 F31DF4 F37254 F33690
FDA89C: F32880 F32C04 F3A710 F3330C F33690 F33A14 F33D98 F3876C
FDA8BC: F344A0 F34824 F34BA8 F36B4C F3A710 F35634 F37CE0 F35D3C
FDA8DC: F360C0 F3957C F367C8 F36B4C F36ED0 F3FEF4 F375D8 F3795C
FDA8FC: F37CE0 F38064 F383E8 F3876C F38AF0 F38E74 F391F8 F3957C
FDA91C: F39900 F39C84 F3A008 F3A38C F3FEF4 F3AA94 F3D848 F3B19C
FDA93C: F3E2D4 F3B8A4 F3BC28 F3BFAC F3E9DC F3C6B4 F3CA38 F3CDBC
FDA95C: F3FB70 F3D4C4 F3D848 F3DBCC F3DF50 F3E2D4 F41088 F3E9DC
FDA97C: F3ED60 F3F0E4 F3F468 F3F7EC F3FB70 F3FEF4 F40278 F42CA8
FDA99C: F40980 F433B0 F41088 F4140C F41790 F4686C F41E98 F441C0
FDA9BC: F425A0 F42924 F47D84 F4302C F48810 F43734 F45DE0 F43E3C
FDA9DC: F4686C F44544 F448C8 F44C4C F47D84 F45354 F48810 F45A5C
FDA9FC: F45DE0 F46164 F464E8 F4686C F46BF0 F46F74 F472F8 F49D28
FDAA1C: F47A00 F47D84 F48108 F4A430 F48810 F48B94 F48F18 F4B5C4
FDAA3C: F49620 F499A4 F4C050 F4EE04 F4A430 F4A7B4 F4AB38 F4AEBC
FDAA5C: F4B240 F4B5C4 F4B948 F4BCCC F4DFF4 F4C3D4 F4EA80 F51834
FDAA7C: F51F3C F4D1E4 F4D568 F4FF98 F4DC70 F506A0 F4E378 F4E6FC
FDAA9C: F514B0 F4EE04 F4F188 F51834 F4F890 F4FC14 F4FF98 F5031C
FDAABC: F530D0 F50A24 F50DA8 F5112C F514B0 F545E8 F51BB8 F51F3C
FDAADC: F522C0 F52644 F529C8 F52D4C F581AC F53454 F537D8 F53B5C
FDAAFC: F53EE0 F54264 F545E8 F618D8 F5FCB8 F55074 F553F8 F5577C
FDAB1C: F55B00 F60744 F56910 F59340 F58FBC F5EB24 F618D8 F59A48
FDAB3C: F5FCB8 F5B2E4 F588B4 F5DD14 F60744 F581AC F56910 F62364
FDAB5C: F5F22C F5A150 F58530 F588B4 F5F5B0 F59DCC F581AC F57AA4
---- block46 ptr=FE72B0 is_malloc=0 length=0x100 ----
FE7270: 0 0 0 0 0 0 0 0
FE7290: 0 0 0 0 0 0 0 0
FE72B0: 14 11431 0 0 0 21D3 6D15 17
FE72D0: 1704 D0A 0 0 0 0 0 0
FE72F0: 48C CC C4 6D 0 0 0 0
FE7310: 0 0 0 0 0 0 0 0
FE7330: 0 0 0 0 0 0 0 0
FE7350: 0 0 0 0 0 0 0 0
FE7370: 0 0 0 0 0 0 B9 0
FE7390: 0 0 0 2 0 0 0 0
---- block47 ptr=105B88C is_malloc=0 length=0x100 ----
105B84C: 0 BEAD000D BEAD0003 BEAD0001 BEAD0005 BEAD0007 0 0
105B86C: 10500 0 FF000000 20002 BEAD000B 8 0 BEAD0009
105B88C: 105B380 0 105B380 0 FDAC3C F5658C C9E30C 1ADD71C
105B8AC: BEAD0007 400030 95000000 10500 400040 FF000000 6C006C C9EBE8
105B8CC: 8 6057756D 1ADD708 105A754 0 0 0 BEAD000D
105B8EC: BEAD0003 BEAD0001 BEAD0005 BEAD0007 0 38000000 10500 400040
105B90C: FF000000 6C006C BEAD000B 8 0 BEAD0009 1056144 0
105B92C: 1056144 1053210 FDAD4C D88520 0 1812DA0 FDB234 420020
105B94C: 0 10500 0 FF000000 B000B FE61E0 8 653AAF5D
105B96C: 1812D8C 1053AF8 0 105C258 0 BEAD000D BEAD0003 BEAD0001
---- block48 ptr=1056650 is_malloc=0 length=0x100 ----
1056610: 0 BEAD000D BEAD0003 BEAD0001 BEAD0005 BEAD0007 0 45000000
1056630: 10500 400040 FF000000 6C006C BEAD000B 8 0 BEAD0009
1056650: 0 105B380 0 105B380 FDAC3C F56208 C9E30C 1ADCC88
1056670: BEAD0007 400030 95000000 10500 400040 FF000000 B C9EBE8
1056690: 8 63CC7863 1ADCC74 1053768 0 0 0 BEAD000D
10566B0: BEAD0003 BEAD0001 BEAD0005 BEAD0007 0 0 10500 0
10566D0: FF000000 20002 BEAD000B 8 0 BEAD0009 1058A3C 0
10566F0: 1058A3C 1053AAC FDAD4C D94D84 0 181E188 FDB234 420020
1056710: 0 10500 0 FF000000 B000B FE61E0 8 4FA6FFB1
1056730: 181E174 1056AC4 0 1056AC4 0 BEAD000D BEAD0003 BEAD0001
---- block49 ptr=AB0808 is_malloc=0 length=0x100 ----
AB07C8: 72000000 53534820 73747275 63747572 65000000 A535348 25732564 3A207374
AB07E8: 61727469 6E672053 53482063 6F6E7472 6F6C2070 726F6365 73730000 53534820
AB0808: 50726F63 65737300 A535348 20257320 2D207665 7273696F 6E202564 2E256400
AB0828: A417574 68656E74 69636174 696F6E20 74696D65 6F75743A 20256420 73656373
AB0848: 3B204175 7468656E 74696361 74696F6E 20726574 72696573 3A202564 0
AB0868: 56657273 696F6E20 63686563 6B656400 53657373 696F6E2D 6B657920 72656365
AB0888: 69766564 0 4B657973 20657863 68616E67 65640000 53657373 696F6E20
AB08A8: 73746172 74656400 5465726D 696E6174 65640000 44697363 6F6E6E65 6374696E
AB08C8: 67000000 44697363 6F6E6E65 63746564 0 53657373 696F6E20 636C6F73
AB08E8: 65640000 A252520 496E7661 6C696420 6C696E65 206E756D 62657220 666F7220
---- block50 ptr=E6B21C is_malloc=1 length=0x100 ----
E6B1DC: E6B1CC BB93A8 EC D0000 1 0 9B41DC 16D758
E6B1FC: B1D128 0 CF126C 0 0 BEEFCAFE 0 FD0110DF
E6B21C: AB1234CD F0000 F 9B41A8 1771AC E6B2E0 E6AF34 8000004A
E6B23C: 1 0 16 CF126C 0 DEADFEED E6B2AC E6B150
E6B25C: E6B1D4 CD7854 E6B254 BB93A8 EB 90000 2 0
E6B27C: A8E9C8 17593C B1D128 0 E6B150 2 C6FA60 0
E6B29C: 0 0 0 0 E6B150 0 E6B29C E6B254
E6B2BC: 0 C189CC 0 0 0 FFFFFFF FFFFFFF 0
E6B2DC: FD0110DF AB1234CD FFFE0000 0 9786A0 7BFD4 E6B32C E6B230
E6B2FC: 8000000E 1 0 1 CF1DE8 48432043 6F756E74 65722054
---- block51 ptr=E6977C is_malloc=1 length=0xA00 ----
E6973C: 0 0 0 0 46ADA0 E69744 0 0
E6975C: 0 0 46AC6C E6975C 0 0 0 FD0110DF
E6977C: AB1234CD F0000 F 9B40CC 1ABFB8 E6AF20 E68F8C 80000BBA
E6979C: 1 0 16 CF126C FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E697BC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E697DC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E697FC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6981C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6983C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6985C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6987C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6989C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E698BC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E698DC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E698FC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6991C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6993C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6995C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6997C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6999C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E699BC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E699DC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E699FC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69A1C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69A3C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69A5C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69A7C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69A9C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69ABC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69ADC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69AFC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69B1C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69B3C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69B5C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69B7C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69B9C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69BBC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69BDC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69BFC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69C1C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69C3C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69C5C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69C7C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69C9C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69CBC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69CDC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69CFC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69D1C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69D3C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69D5C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69D7C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69D9C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69DBC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69DDC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69DFC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69E1C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69E3C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69E5C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69E7C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69E9C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69EBC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69EDC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69EFC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69F1C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69F3C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69F5C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69F7C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69F9C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69FBC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69FDC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E69FFC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6A01C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6A03C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6A05C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6A07C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6A09C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6A0BC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6A0DC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6A0FC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6A11C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6A13C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
E6A15C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
---- block52 ptr=CF126C is_malloc=0 length=0x100 ----
CF122C: CE395C CE3864 CE391C E6D81C CF122C BB93A8 F3 90000
CF124C: 3 0 9B4F70 16D758 B1D128 0 0 CED074
CF126C: 0 1000016 30000 CECE00 0 0 0 FF
CF128C: CEB2D8 0 0 0 0 0 0 CF121C
CF12AC: CF1334 CF126C CECE48 CE3AD0 CE39D8 CE3A90 E6B1D4 CF12B8
CF12CC: BB93A8 ED 90000 3 0 9B4F70 16D758 B1D128
CF12EC: 0 0 CED074 0 1000015 40000 CECE00 0
CF130C: 0 0 FF CEB2EC 0 0 0 0
CF132C: 0 0 CF12A8 CF13C0 CF12F8 CECE48 CE3C44 CE3B4C
CF134C: CE3C04 E68DC0 CF1344 BB93A8 E6 90000 3 0
---- block53 ptr=11E8F30 is_malloc=1 length=0x100 ----
11E8EF0: 0 0 0 0 2AD1 0 0 0
11E8F10: 0 0 0 0 0 0 0 FD0110DF
11E8F30: AB1234CD FFFE0000 0 966878 E77E4 11E8FAC 11E8EC8 80000026
11E8F50: 1 0 1 CF1DE8 0 0 0 0
11E8F70: 0 0 0 1377C2 0 0 0 0
11E8F90: 0 0 0 0 0 0 FD0110DF AB1234CD
11E8FB0: FFFE0000 0 966878 E77E4 11E9028 11E8F44 80000026 1
11E8FD0: 0 1 CF1DE8 0 2 0 0 0
11E8FF0: 0 0 137FB0 0 0 0 0 0
11E9010: 2 0 0 0 0 FD0110DF AB1234CD FFFE0000
---- block54 ptr=966878 is_malloc=0 length=0x100 ----
966838: 204F7065 6E696E67 0 4C435020 4F70656E 0 43435020 4F70656E
966858: 0 49504350 204F7065 6E000000 42435020 4F70656E 0 4C435020
966878: 496E6974 0 4C435020 53746172 74000000 4C435020 53746F70 70656400
966898: 4C435020 436C6F73 696E6700 4C435020 53746F70 70696E67 0 4C435020
9668B8: 52657120 53656E74 0 4C435020 41636B20 52637664 0 4C435020
9668D8: 41636B20 53656E74 0 4950584E 4350204F 70656E00 49505820 4E435020
9668F8: 4F70656E 0 42414350 204F7065 6E696E67 0 42414350 204F7065
966918: 6E000000 43424350 204F7065 6E696E67 0 43424350 204F7065 6E000000
966938: 56313130 20416363 0 56313130 204F7065 6E000000 56313130 20436172
966958: 72696572 0 56313130 20526573 65740000 56313130 20436C6F 73656400
---- block55 ptr=1069A48 is_malloc=1 length=0x1C8 ----
1069A08: E1F37C 0 0 0 0 0 0 0
1069A28: 0 0 0 0 0 0 0 FD0110DF
1069A48: AB1234CD FFFE0000 0 A20FE4 42035C 1069AB4 1068E70 8000001E
1069A68: 1 0 1 CF1DE8 0 1 2 0
1069A88: 1 EE14A8 1069B40 1069BB4 0 0 0 0
1069AA8: 0 0 FD0110DF AB1234CD FFFE0000 0 966878 4230F8
1069AC8: 1069B10 1069A5C 80000016 1 0 1 CF1DE8 0
1069AE8: EBA850 0 1069AF4 1 3 446F7431 31526164 696F3000
1069B08: 0 FD0110DF AB1234CD FFFE0000 0 A20FF0 420540 1069B84
1069B28: 1069AC8 80000022 1 0 1 CF1DE8 1069DD0 BE5BD8
1069B48: BE5BD8 BE5BD8 1069DD0 0 1 0 1 0
1069B68: 1 1 0 0 1069A78 0 FD0110DF AB1234CD
1069B88: FFFE0000 0 966878 666708 1069C18 1069B24 80000032 1
1069BA8: 0 1 CF1DE8 1069E44 1069A78 4D2 0 93CA99
1069BC8: 166D3 A2CA 0 BA89C2 0 0 18561 126A9
1069BE8: 0 0 1069C48 0 93CA99 0 BA89C2 0
1069C08: C409 0
---- block56 ptr=1069E14 is_malloc=1 length=0x100 ----
1069DD4: 1069B40 11C4F38 BE5BD8 106A008 1069B40 2 0 5
1069DF4: 0 5 1 0 0 1069D08 0 FD0110DF
1069E14: AB1234CD FFFE0000 0 966878 666708 1069EA8 1069DB4 80000032
1069E34: 1 0 1 CF1DE8 106A07C 1069D08 4D2 0
1069E54: 0 0 0 0 0 0 0 0
1069E74: 0 0 0 1069ED8 0 0 0 0
1069E94: 0 0 0 0 FD0110DF AB1234CD FFFE0000 0
1069EB4: 966878 66673C 1069F0C 1069E28 8000001A 1 0 1
1069ED4: CF1DE8 0 0 0 0 0 0 0
1069EF4: 0 0 0 0 0 FD0110DF AB1234CD FFFE0000
---- block57 ptr=93CA98 is_malloc=0 length=0x100 ----
93CA58: 965970 A0F0B4 E 93C7CC 4200000 657F90 3A791C E
93CA78: 93C804 4210100 657F90 65826C E 93C91C 2210600 657F90
93CA98: 65826C E 93C954 4210700 657F90 65826C E 93C98C
93CAB8: 2210800 657F90 65826C E 93C9C4 4210900 657F90 65826C
93CAD8: E 93C9FC 42200A00 657F90 3A791C 0 98D04C 965958
93CAF8: 965968 96596C A0F0B4 98D04C 9D34F4 9AAE90 965970 A0F0B4
93CB18: 9F45E0 9F45EC A866F8 A86710 A86724 A86740 A86758 A8676C
93CB38: A86784 A8679C 0 0 1 3 6 1
93CB58: 4 1 9 A 38 1 3 6
93CB78: 1 4 1 9 A 38 1 1
---- block58 ptr=BA89C0 is_malloc=0 length=0x100 ----
BA8980: 0 0 0 0 0 0 0 0
BA89A0: 0 0 0 0 0 0 0 0
BA89C0: 0 0 0 0 0 0 0 0
BA89E0: 0 0 0 0 0 0 0 0
BA8A00: 0 0 0 0 0 0 0 0
BA8A20: 0 0 0 0 0 0 0 0
BA8A40: 0 0 0 0 0 0 0 0
BA8A60: 0 0 0 0 0 0 0 0
BA8A80: 0 0 0 0 0 0 0 0
BA8AA0: 0 0 0 0 0 0 0 0
---- block59 ptr=1069F0C is_malloc=1 length=0x100 ----
1069ECC: 0 1 CF1DE8 0 0 0 0 0
1069EEC: 0 0 0 0 0 0 0 FD0110DF
1069F0C: AB1234CD FFFE0000 0 A20FE4 42035C 1069F78 1069EBC 8000001E
1069F2C: 1 0 1 CF1DE8 0 3 4 0
1069F4C: 1 1067440 106A008 106A07C 0 0 0 0
1069F6C: 0 0 FD0110DF AB1234CD FFFE0000 0 966878 4230F8
1069F8C: 1069FD8 1069F20 80000018 1 0 1 CF1DE8 11C4EE0
1069FAC: EBA830 0 1069FB8 3 3 46617374 45746865 726E6574
1069FCC: 30000000 0 FD0110DF AB1234CD FFFE0000 0 A20FF0 420540
1069FEC: 106A04C 1069F8C 80000022 1 0 1 CF1DE8 11C4F38
---- block60 ptr=106A1C8 is_malloc=1 length=0x100 ----
106A188: 0 0 0 0 0 0 0 0
106A1A8: 0 0 0 0 0 0 0 FD0110DF
106A1C8: AB1234CD FFFE0000 0 966878 17C250 106A24C 106A158 8000002A
106A1E8: 1 0 1 CF1DE8 3A194 0 0 44A550
106A208: 34F540 0 0 0 0 0 0 0
106A228: 0 0 0 0 0 0 0 0
106A248: FD0110DF AB1234CD FFFE0000 0 9786A0 7BFD4 106A298 106A1DC
106A268: 8000000E 1 9DEFC 1 CF1DE8 48794272 69646765 20496E70
106A288: 75742050 726F6365 73730000 FD0110DF AB1234CD FFFE0000 0 97FCFC
106A2A8: A4278 106A304 106A260 8000001E 1 0 1 CF1DE8
---- block61 ptr=11E82B8 is_malloc=1 length=0x100 ----
11E8278: 0 0 0 0 0 0 0 0
11E8298: 0 0 0 0 0 0 0 FD0110DF
11E82B8: AB1234CD FFFE0000 0 A20FE4 42035C 11E8324 11E81DC 8000001E
11E82D8: 1 0 1 CF1DE8 0 5 0 0
11E82F8: 1 11E7120 11E83A8 11E841C 0 0 0 0
11E8318: 0 0 FD0110DF AB1234CD FFFE0000 0 966878 4230F8
---- block62 ptr=11E84E4 is_malloc=1 length=0x270 ----
11E84A4: 0 1 CF1DE8 0 0 0 0 0
11E84C4: 0 0 0 0 0 0 0 FD0110DF
11E84E4: AB1234CD FFFE0000 0 966878 666798 11E8540 11E8494 80000016
11E8504: 1 0 1 CF1DE8 0 1069CAC C6FA60 11E8514
11E8524: 0 138B4A 14248 0 1 1388 FD0110DF AB1234CD
11E8544: FFFE0000 0 E12F48 A6C64 11E8754 11E84F8 800000F2 1
11E8564: 1C194C 1 CF1DE8 0 11DA0C4 11E6684 0 E12F0C
11E8584: C D 140018 0 0 0 0 18
11E85A4: 8530000 BCA1E8 43686169 6E204361 63686520 4E6F0000 11E8600 11E8738
11E85C4: 0 0 11E8604 11E861C 11E8634 11E864C 11E8664 11E867C
11E85E4: 11E8694 11E86AC 11E86C4 11E86DC 11E86F4 11E870C 11E8724 11E8570
11E8604: 11DA3CC AFAC8C 13F570 B0D0B0D B0D0B0D 11E8570 11DA45C 0
11E8624: 13F5B8 8E5F7C 0 11E8570 11E861C AFAC8C 13F570 0
11E8644: 0 11E8570 0 0 141140 8E5F48 B2DB30 11E8570
11E8664: 11E864C 0 147848 8E5F50 B2DB44 11E8570 11E8664 0
11E8684: 13F5B8 8E5F64 B2DBC0 11E8570 11E867C 0 13F5B8 8E5F7C
11E86A4: B2DBF4 11E8570 11E8694 0 B76E8 0 B0363C 11E8570
11E86C4: 11E86AC AFAC8C 13F570 0 0 11E8570 0 0
11E86E4: 141140 8E6950 B2EEC0 11E8570 11E86DC 11E86DC 13F78C 8E6958
11E8704: B2EED4 11E8570 11E86F4 0 147848 8E696C B2EF10 11E8570
11E8724: 11E870C 0 147848 8E6998 B2EF24 0 0 0
11E8744: 0 0 0 FD0110DF
---- block63 ptr=E12EDC is_malloc=1 length=0x214 ----
E12E9C: E12D44 EF4321CD 0 0 0 E12D44 EF4321CD 0
E12EBC: 0 0 E12D44 0 0 0 0 FD0110DF
E12EDC: AB1234CD FFFE0000 0 97F2EC 9E020 E130F0 E12D28 800000F2
E12EFC: 1 1C1964 1 CF1DE8 E13120 11D9D74 0 0
E12F1C: 11E4AF8 C D 140018 0 AA F1 4E
E12F3C: 18 8510000 BCA1E8 43686169 6E204361 63686520 4E6F0000 E12F9C
E12F5C: E130D4 0 0 E13060 E13078 E13090 E130A8 E130C0
E12F7C: E12FD0 E12FB8 E13048 E13060 E13078 E13090 E130A8 E130C0
E12F9C: E12F0C 11D9CCC AFAC8C 13F570 B0D0B0D B0D0B0D E12F0C E12FD0
E12FBC: AFAC8C 13F570 B0D0B0D B0D0B0D E12F0C E12FE8 0 149F5C
E12FDC: 8C36D4 AFFFC4 E12F0C E13000 0 149F5C 8C3584 AFFCC4
E12FFC: E12F0C E13018 0 149F5C 8C3214 AFF400 E12F0C E13030
E1301C: 0 149F5C 9156AC B5F6B8 E12F0C E13048 0 143720
E1303C: 9156A4 B5F5E0 E12F0C 11E59AC 0 13F714 915694 B5F5CC
E1305C: E12F0C 11E4C04 0 13F5B8 8C4D10 B03D3C E12F0C E13060
E1307C: AFAC8C 13F570 B0D0B0D B0D0B0D E12F0C 0 0 141140
E1309C: 8C55CC B05624 E12F0C E13090 0 13F78C 8C55E8 B056B4
E130BC: E12F0C E130A8 AFAC8C 13F570 B0D0B0D B0D0B0D 0 0
E130DC: 0 0 0 0 FD0110DF
---- block64 ptr=11E8754 is_malloc=1 length=0x100 ----
11E8714: 147848 8E696C B2EF10 11E8570 11E870C 0 147848 8E6998
11E8734: B2EF24 0 0 0 0 0 0 FD0110DF
11E8754: AB1234CD FFFE0000 0 966878 10B184 11E87A8 11E8554 80000012
11E8774: 1 0 1 CF1DE8 0 9CBA48 3F5 1
11E8794: 0 0 1 80 FD0110DF AB1234CD FFFE0000 0
11E87B4: A07D50 37DA00 11E8854 11E8768 8000003E 1 0 1
11E87D4: CF1DE8 E1E68C 11E7CBC 8FC184 0 0 0 0
11E87F4: 0 0 0 0 11E7CBC 0 0 0
11E8814: 0 0 0 0 0 0 0 0
11E8834: 0 3 0 0 0 0 0 FD0110DF
---- block65 ptr=BB93A8 is_malloc=0 length=0x100 ----
BB9368: 0 0 0 0 0 0 0 0
BB9388: 0 0 0 0 0 0 0 0
BB93A8: C1A860 CE19A0 0 0 0 0 0 90000
BB93C8: 328 0 A6D054 16D758 B1D128 0 BF26B4 8D90DC
BB93E8: 0 17BC58 17BC58 17BC58 21F5 E1D 14A4 1E36
BB9408: 1FC1 2161 E34 185 839 2679 22F8 16F4
BB9428: 1BCE 13FB 763 EB0 9C90F569 270142E2 7369A4C3 C7075793
BB9448: 1CDF9A80 F149B5DB 8989DAFB C05B2CC1 8BF3BB6 49CA2B3D 39 1000
BB9468: 1F000000 3D39DE0C 3B7D43D3 8F9BE62A 76A0268E 7FF4D65E DA22D8B2 2BBEFE85
BB9488: 445CF58D 9C264280 D0CF244B 6F34521E 150621CF 7170CCC1 A33FE8AC 6471A469
---- block66 ptr=A91D24 is_malloc=0 length=0x100 ----
A91CE4: 6B657920 6D797075 626B6579 20727361 202D2D2D 2D2D2D2D 2D2D2D2D 2D2D2D2D
A91D04: 2D2D2D0A 0 44535320 5075626C 6963204B 65792050 61697273 0
A91D24: 44535320 5075626C 6963204B 65792043 6861696E 0 52534120 5075626C
A91D44: 6963204B 65792043 6861696E 0 63727970 746F2070 75626C69 632D6B65
A91D64: 79202573 20253038 78000000 A717569 740A0000 20717569 74000000 4E6F2070
A91D84: 75626C69 63206B65 7920666F 756E6420 6D617463 68696E67 206E616D 65202725
A91DA4: 73270A00 4E6F2070 75626C69 63206B65 7920666F 756E6420 6D617463 68696E67
A91DC4: 20736572 69616C20 6E756D62 65722027 25303878 270A0000 5369676E 696E6720
A91DE4: 0 5369676E 61747572 65204B65 790A0000 456E6372 79707420 0
A91E04: 456E6372 79707469 6F6E204B 65790A00 47656E65 72616C20 0 47656E65
---- block67 ptr=B1D128 is_malloc=0 length=0x100 ----
B1D0E8: 57 0 1 0 1F 3D 5C 7A
B1D108: 99 B8 D6 F5 113 132 151 0
B1D128: 16CA7C 16CBE4 16CCF4 16CE40 16D04C 16D2FC FFF00000 1
B1D148: 0 0 0 0 0 0 0 0
B1D168: 0 0 0 0 0 0 0 0
B1D188: 0 0 0 0 0 0 0 0
B1D1A8: 0 0 0 0 0 0 0 0
B1D1C8: 0 0 0 0 0 0 0 0
B1D1E8: 0 0 0 0 0 0 0 0
B1D208: 0 0 0 0 0 0 0 0
---- block68 ptr=BE5770 is_malloc=0 length=0x100 ----
BE5730: 0 0 0 0 0 0 0 0
BE5750: 0 0 0 0 0 0 10864CC 10863F0
BE5770: 118EEB4 BE2F54 BE5768 BB93A8 2EE 50000 3 0
BE5790: AB45D4 16D758 B1D128 0 0 0 118ED08 0
BE57B0: 0 0 4204 0 0 0 BE57A0 0
BE57D0: 0 0 4240 0 0 0 0 0
BE57F0: 0 0 0 0 0 0 0 0
BE5810: 0 0 0 0 0 0 0 0
BE5830: 0 0 0 0 0 0 0 0
BE5850: 0 0 0 0 0 0 0 0
---- block69 ptr=1000000 is_malloc=0 length=0x100 ----
FFFFC0: 0 0 0 0 0 0 0 0
FFFFE0: 0 0 0 0 0 0 0 0
1000000: 0 0 0 0 0 0 0 0
1000020: 0 0 0 0 0 0 0 0
1000040: 0 0 0 0 0 0 0 0
1000060: 0 0 0 0 0 0 0 0
1000080: 0 0 0 0 0 0 0 0
10000A0: 0 0 0 0 0 0 0 0
10000C0: 0 0 0 0 0 0 0 0
10000E0: 0 0 0 0 0 0 0 0
---- block70 ptr=CECE00 is_malloc=0 length=0x100 ----
CECDC0: 0 0 0 0 0 0 0 0
CECDE0: 0 0 0 0 0 0 0 CEBBA4
CECE00: 0 1 1 174BF4 CCF478 CCF450 CECE50 D4759C
CECE20: CECE10 BB93A8 30 D0000 3 0 9B4E8C 16D758
CECE40: B1D128 0 CF1E24 CEEC60 CECE88 CECE18 CECE48 BB93A8
CECE60: 31 90000 5B 0 9B4EA8 16D758 B1D128 0
CECE80: 0 0 CF1E3C CECE50 CECE80 BB93A8 32 D0000
CECEA0: 0 0 9B4EC4 16D758 B1D128 0 1A20000 CEB47C
CECEC0: 0 0 0 0 0 0 0 0
CECEE0: 0 0 0 0 0 0 0 0
---- block71 ptr=CEAED0 is_malloc=1 length=0x610 ----
CEAE90: 60000 0 CF1EC8 45C1893C CEB4A4 30000 0 CF4670
CEAEB0: 5BAF9596 CEB4B8 60000 0 0 0 0 FD0110DF
CEAED0: AB1234CD FFFE0000 0 978284 7B984 CEB4E0 CEA8D4 800002F0
CEAEF0: 1 1C1964 1 CF1DE8 CEB510 110ABF0 0 0
CEAF10: 110ABF0 20 3A 140014 2 5F 63 15
CEAF30: 10 10000 BCA1E8 53747269 6E672D44 42206F77 6E650000 CEB044
CEAF50: CEB4CC 0 0 CEB238 CEB314 CEB314 CEB080 CEB094
CEAF70: CEB0A8 CEB0BC CEB0D0 CEB0E4 CEB0F8 CEB10C CEB120 CEB134
CEAF90: CEB148 CEB15C CEB170 CEB184 CEB198 CEB1AC CEB1C0 CEB1D4
CEAFB0: CEB1E8 CEB1FC CEB210 CEB224 CEB238 CEB24C CEB260 CEB274
CEAFD0: CEB288 CEB29C CEB2B0 CEB2C4 CEB2D8 CEB2EC CEB300 CEB314
CEAFF0: CEB328 CEB33C CEB350 CEB364 CEB378 CEB38C CEB3A0 CEB3B4
CEB010: CEB3C8 CEB3DC CEB3F0 CEB404 CEB418 CEB42C CEB440 CEB454
CEB030: CEB468 CEB47C CEB490 CEB4A4 CEB4B8 0 CEAA34 E6F120
CEB050: 20000 0 0 CEAA48 E6F128 20000 0 0
CEB070: CEAA5C E6F130 20000 0 0 CEAA70 E6F138 20000
CEB090: 0 0 CEAA84 E6F140 20000 0 0 CEAA98
CEB0B0: E6F148 20000 0 0 CEAAAC E6F150 20000 0
CEB0D0: 0 CEAAC0 E6F158 20000 0 0 CEAAD4 E6F160
CEB0F0: 20000 0 0 CEAAE8 E6F168 20000 0 0
CEB110: CEAAFC E6F170 20000 0 0 CEAB10 CEB6A4 20000
CEB130: 0 0 CEAB24 E6F180 20000 0 0 CEAB38
CEB150: E6F188 20000 0 0 CEAB4C E6F190 20000 0
CEB170: 0 CEAB60 E6F198 20000 0 0 CEAB74 E6F1A0
CEB190: 20000 0 0 CEAB88 E6F1A8 20000 0 0
CEB1B0: CEAB9C E6F1B0 20000 0 0 CEABB0 E6F1B8 20000
CEB1D0: 0 0 CEABC4 E6F1C0 20000 0 0 CEABD8
CEB1F0: E6F1C8 20000 0 0 CEABEC E6F1D0 20000 0
CEB210: 0 CEAC00 CEB5EC 20000 0 0 CEAC14 CEB5F4
CEB230: 20000 0 EF4321CD 7C2C4 B0D0B0D B0D0B0D B0D0B0D 0
CEB250: CEAC3C CEB604 20000 0 0 CEAC50 CEB60C 20000
CEB270: 0 0 CEAC64 CEB614 20000 0 0 CEAC78
CEB290: CEB61C 20000 0 0 CEAC8C CEB624 20000 0
CEB2B0: 0 CEACA0 CEB62C 20000 0 0 CEACB4 CEB634
CEB2D0: 20000 0 0 CEACC8 CEB63C 20000 0 0
CEB2F0: CEACDC CEB644 20000 0 0 CEACF0 CEB64C 20000
CEB310: 0 EF4321CD 7C2C4 B0D0B0D B0D0B0D B0D0B0D 0 CEAD18
CEB330: CEB65C 20000 0 0 CEAD2C CEB664 20000 0
CEB350: 0 CEAD40 CEB66C 20000 0 0 CEAD54 CEB674
CEB370: 20000 0 0 CEAD68 CEB67C 20000 0 0
CEB390: CEAD7C CEB684 20000 0 0 CEAD90 CEB68C 20000
CEB3B0: 0 0 CEADA4 CEB694 20000 0 0 CEADB8
CEB3D0: CEB69C 20000 0 0 CEADCC CEB6AC 20000 0
CEB3F0: 0 CEADE0 CEB6B4 20000 0 0 CEADF4 CEB6BC
CEB410: 20000 0 0 CEAE08 CEB6C4 20000 0 0
CEB430: CEAE1C CEB6CC 20000 0 0 CEAE30 CEB6D4 20000
CEB450: 0 0 CEAE44 CEB6DC 20000 0 0 CEAE58
CEB470: CEB6E4 20000 0 0 CEAE6C CECE00 10000 0
CEB490: 0 CEAE80 CE05B8 0 0 0 CEAE94 CE0764
CEB4B0: 0 0 0 CEAEA8 CE0910 0 0 0
CEB4D0: 0 0 0 FD0110DF
---- block72 ptr=CE585C is_malloc=0 length=0x1F8 ----
CE581C: CF1DB0 CE5898 CE5814 BB93A8 36 D0000 0 0
CE583C: 9B4FD8 16D758 B1D128 0 CE56D8 CE37D8 CE57F4 CE05E4
CE585C: 0 CE58D8 CE57F4 CF1E34 CE0B88 CF1DE8 CE0764 0
CE587C: 0 0 0 FF D254E0 0 0 CE581C
CE589C: CE5914 CE5890 BB93A8 35 D0000 0 0 9B4FD8
CE58BC: 16D758 B1D128 0 CE5754 CE375C CE5870 CE0790 CE585C
CE58DC: CE5954 CE5870 CF1E34 CE0B88 CF1DE8 CE0910 0 0
CE58FC: 0 0 FF D155D0 0 0 CE5898 CF1E3C
CE591C: CE590C BB93A8 34 D0000 0 0 9B4FD8 16D758
CE593C: B1D128 0 CE57D0 CE36E0 CE58EC CE093C CE58D8 0
CE595C: CE58EC CF1E34 0 0 0 0 0 0
CE597C: 0 0 0 0 0 0 0 0
CE599C: 0 0 0 FD0110DF AB1234CD FFFE0000 0 9B4C1C
CE59BC: 17FE64 CEA800 CE0B6C 80002712 1 1C1964 1 CF1DE8
CE59DC: CEA8F0 0 0 0 0 64 9B 78007C
CE59FC: 9B 0 0 9B 44 410000 BCA1E8 524D492D
CE5A1C: 524F5F52 47204368 756E0000 CE5CA4 CEA7B8 0 0 CE5CA8
CE5A3C: CE5D24 CE5DA0 CE5E1C CE5E98 CE5F14 CE5F90
---- block73 ptr=9B4F70 is_malloc=0 length=0x100 ----
9B4F30: 65676973 74657220 6661696C 65642021 21000000 A4E616D 65204442 20616464
9B4F50: 6974696F 6E206661 696C6564 20647572 696E6720 52552043 72656174 65202100
9B4F70: 524F5F52 55204C69 73740000 A496E76 616C6964 20525520 73706563 69666965
9B4F90: 6420666F 72205265 67697374 65722021 21000000 A524D49 204D4953 4D415443
9B4FB0: 48494E47 20525554 21210000 A524D49 5F445550 4C494341 54455F55 5345525F
9B4FD0: 4E414D45 21210000 524F5F52 55204E6F 74696679 2044616D 70656E20 4C697374
9B4FF0: 0 A205265 6D6F7465 20757365 72207265 67697374 65722066 61696C65
9B5010: 64202121 0 A726573 6F757263 655F7573 65725F72 65676973 7465723A
9B5030: 0 A726573 6F757263 655F7573 65725F75 6E726567 69737465 723A0000
9B5050: A525520 556E7265 67697374 65722066 61696C65 64202D20 756E6162 6C652074
---- block74 ptr=1C696F8 is_malloc=1 length=0xA00 ----
1C696B8: 0 0 0 0 0 0 0 0
1C696D8: 0 0 0 0 0 0 0 FD0110DF
1C696F8: AB1234CD FFFE0000 0 99A3AC FCD44 1C6A18C 1C68C78 80000532
1C69718: 1 0 1 CF1DE8 AFACEFAD 0 0 0
1C69738: 0 0 0 0 0 0 0 0
1C69758: 0 0 0 0 0 0 FFFF FFFFFFFF
1C69778: 1B7843 6D8C0806 10800 6040001 1B7843 6D8C0A00 1040000 0
1C69798: A000A78 0 0 0 0 6D8C A000104 0
1C697B8: A00 A780000 0 0 0 0 185D01B0 F6830008
1C697D8: 20C1C 1000E 10001 16E9EB69 EC9A7451 94030003 C02EC 9A740000
1C697F8: 0 27 10000E 6D696E69 6E742D37 74703133 31390010 E0000
1C69818: 1370008 4D534654 20352E30 60008 180017 110027 0 0
1C69838: 0 0 0 0 0 0 0 0
1C69858: 0 0 0 0 0 0 0 0
1C69878: 0 0 0 0 0 0 0 0
1C69898: 0 0 0 0 0 0 0 0
1C698B8: 0 0 0 0 0 0 0 0
1C698D8: 0 0 0 0 0 0 0 0
1C698F8: 0 0 0 0 0 0 0 0
1C69918: 0 0 0 0 0 0 0 0
1C69938: 0 0 0 0 0 0 0 0
1C69958: 0 0 0 0 0 0 0 0
1C69978: 0 0 0 0 0 0 0 0
1C69998: 0 0 0 0 0 0 0 0
1C699B8: 0 0 0 0 0 0 0 0
1C699D8: 0 0 0 0 0 0 0 0
1C699F8: 0 0 0 0 0 0 0 0
1C69A18: 0 0 0 0 0 0 0 0
1C69A38: 0 0 0 0 0 0 0 0
1C69A58: 0 0 0 0 0 0 0 0
1C69A78: 0 0 0 0 0 0 0 0
1C69A98: 0 0 0 0 0 0 0 0
1C69AB8: 0 0 0 0 0 0 0 0
1C69AD8: 0 0 0 0 0 0 0 0
1C69AF8: 0 0 0 0 0 0 0 0
1C69B18: 0 0 0 0 0 0 0 0
1C69B38: 0 0 0 0 0 0 0 0
1C69B58: 0 0 0 0 0 0 0 0
1C69B78: 0 0 0 0 0 0 0 0
1C69B98: 0 0 0 0 0 0 0 0
1C69BB8: 0 0 0 0 0 0 0 0
1C69BD8: 0 0 0 0 0 0 0 0
1C69BF8: 0 0 0 0 0 0 0 0
1C69C18: 0 0 0 0 0 0 0 0
1C69C38: 0 0 0 0 0 0 0 0
1C69C58: 0 0 0 0 0 0 0 0
1C69C78: 0 0 0 0 0 0 0 0
1C69C98: 0 0 0 0 0 0 0 0
1C69CB8: 0 0 0 0 0 0 0 0
1C69CD8: 0 0 0 0 0 0 0 0
1C69CF8: 0 0 0 0 0 0 0 0
1C69D18: 0 0 0 0 0 0 0 0
1C69D38: 0 0 0 0 0 0 0 0
1C69D58: 0 0 0 0 0 0 0 0
1C69D78: 0 0 0 0 0 0 0 0
1C69D98: 0 0 0 0 0 0 0 0
1C69DB8: 0 0 0 0 0 0 0 0
1C69DD8: 0 0 0 0 0 0 0 0
1C69DF8: 0 0 0 0 0 0 0 0
1C69E18: 0 0 0 0 0 0 0 0
1C69E38: 0 0 0 0 0 0 0 0
1C69E58: 0 0 0 0 0 0 0 0
1C69E78: 0 0 0 0 0 0 0 0
1C69E98: 0 0 0 0 0 0 0 0
1C69EB8: 0 0 0 0 0 0 0 0
1C69ED8: 0 0 0 0 0 0 0 0
1C69EF8: 0 0 0 0 0 0 0 0
1C69F18: 0 0 0 0 0 0 0 0
1C69F38: 0 0 0 0 0 0 0 0
1C69F58: 0 0 0 0 0 0 0 0
1C69F78: 0 0 0 0 0 0 0 0
1C69F98: 0 0 0 0 0 0 0 0
1C69FB8: 0 0 0 0 0 0 0 0
1C69FD8: 0 0 0 0 0 0 0 0
1C69FF8: 0 0 0 0 0 0 0 0
1C6A018: 0 0 0 0 0 0 0 0
1C6A038: 0 0 0 0 0 0 0 0
1C6A058: 0 0 0 0 0 0 0 0
1C6A078: 0 0 0 0 0 0 0 0
1C6A098: 0 0 0 0 0 0 0 0
1C6A0B8: 0 0 0 0 0 0 0 0
1C6A0D8: 0 0 0 0 0 0 0 0
---- block75 ptr=EEFF14 is_malloc=1 length=0x384 ----
EEFED4: 0 0 0 0 0 0 0 0
EEFEF4: 0 0 0 0 0 0 0 FD0110DF
EEFF14: AB1234CD FFFE0000 0 99A39C FCCF4 EF0298 EEFBA4 800001AA
EEFF34: 1 0 1 CF1DE8 EF3784 0 0 0
EEFF54: 0 0 FFFF0007 10000 19A9578 19A95BE 19A95BE 19A95BE
EEFF74: 19A95CC 19A95CC 0 11E7CBC 1 5C0001 1000E 0
EEFF94: 0 0 0 0 0 0 0 0
EEFFB4: 0 0 0 0 0 0 0 0
EEFFD4: 0 0 0 0 10000 EE274C FD924 0
EEFFF4: 0 0 0 0 EF02C8 EEFBC0 CF077C 2B
EF0014: 0 0 0 0 0 0 0 0
EF0034: 0 0 0 0 0 0 0 0
EF0054: 0 0 0 0 0 0 0 16AC
EF0074: 0 16AC 0 0 0 0 0 0
EF0094: 0 0 0 0 0 0 0 1067FDC
EF00B4: 0 0 0 0 0 0 0 0
EF00D4: 0 0 0 0 0 0 0 0
EF00F4: 0 0 0 0 0 0 0 0
EF0114: 0 0 0 0 0 0 0 0
EF0134: 0 0 0 0 0 0 0 0
EF0154: 0 0 0 0 0 0 0 0
EF0174: 0 0 0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFF
EF0194: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
EF01B4: FFFFFFFF 0 0 0 0 0 0 0
EF01D4: 0 0 0 0 0 0 0 0
EF01F4: 0 0 0 0 0 0 0 0
EF0214: 0 0 0 0 0 0 0 0
EF0234: 0 0 0 0 0 0 0 0
EF0254: 0 0 0 0 0 0 0 0
EF0274: 0 0 0 0 0 0 0 0
EF0294: FD0110DF
---- block76 ptr=F1005C is_malloc=1 length=0x384 ----
F1001C: 0 0 0 0 0 0 0 0
F1003C: 0 0 0 0 0 0 0 FD0110DF
F1005C: AB1234CD FFFE0000 0 99A39C FCCF4 F103E0 F0FCEC 800001AA
F1007C: 1 0 1 CF1DE8 F0F27C 0 0 0
F1009C: 0 0 FFFF0001 10000 1A09DE0 1A09E26 1A09E26 1A09E26
F100BC: 1A09E34 1A09E34 0 11E7CBC 11 3C002D 1000E 0
F100DC: 0 0 0 0 0 0 0 0
F100FC: 0 0 0 0 0 0 0 0
F1011C: 0 0 0 0 10000 EE274C FD924 0
F1013C: 0 0 0 0 F10410 F0FD08 CF1384 14
F1015C: 0 0 0 0 0 0 0 0
F1017C: 0 0 0 0 0 0 0 0
F1019C: 0 0 0 0 0 0 0 16AD
F101BC: 0 16AD 0 0 0 0 0 0
F101DC: 0 0 0 0 0 0 0 1067FDC
F101FC: 0 0 0 0 0 0 0 0
F1021C: 0 0 0 0 0 0 0 0
F1023C: 0 0 0 0 0 0 0 0
F1025C: 0 0 0 0 0 0 0 0
F1027C: 0 0 0 0 0 0 0 0
F1029C: 0 0 0 0 0 0 0 0
F102BC: 0 0 0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFF
F102DC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
F102FC: FFFFFFFF 0 0 0 0 0 0 0
F1031C: 0 0 0 0 0 0 0 0
F1033C: 0 0 0 0 0 0 0 0
F1035C: 0 0 0 0 0 0 0 0
F1037C: 0 0 0 0 0 0 0 0
F1039C: 0 0 0 0 0 0 0 0
F103BC: 0 0 0 0 0 0 0 0
F103DC: FD0110DF
---- block77 ptr=F2FE20 is_malloc=1 length=0x384 ----
F2FDE0: 0 0 0 0 0 0 0 0
F2FE00: 0 0 0 0 0 0 0 FD0110DF
F2FE20: AB1234CD FFFE0000 0 99A39C FCCF4 F301A4 F2FAB0 800001AA
F2FE40: 1 0 1 CF1DE8 F32F88 0 0 0
F2FE60: 0 0 FFFF0007 10000 1A69BB4 1A69BFA 1A69BFA 1A69BFA
F2FE80: 1A69C08 1A69C08 0 11E7CBC 1 1560001 1000E 0
F2FEA0: 0 0 0 0 0 0 0 0
F2FEC0: 0 0 0 0 0 0 0 0
F2FEE0: 0 0 0 0 10000 EE274C FD924 0
F2FF00: 0 0 0 0 F301D4 F2FACC CF077C 2B
F2FF20: 0 0 0 0 0 0 0 0
F2FF40: 0 0 0 0 0 0 0 0
F2FF60: 0 0 0 0 0 0 0 13AC45
F2FF80: 0 16AE 0 0 0 0 0 0
F2FFA0: 0 0 0 0 0 0 0 1067FDC
F2FFC0: 0 0 0 0 0 0 0 0
F2FFE0: 0 0 0 0 0 0 0 0
F30000: 0 0 0 0 0 0 0 0
F30020: 0 0 0 0 0 0 0 0
F30040: 0 0 0 0 0 0 0 0
F30060: 0 0 0 0 0 0 0 0
F30080: 0 0 0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFF
F300A0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
F300C0: FFFFFFFF 0 0 0 0 0 0 0
F300E0: 0 0 0 0 0 0 0 0
F30100: 0 0 0 0 0 0 0 0
F30120: 0 0 0 0 0 0 0 0
F30140: 0 0 0 0 0 0 0 0
F30160: 0 0 0 0 0 0 0 0
F30180: 0 0 0 0 0 0 0 0
F301A0: FD0110DF
---- block78 ptr=F4FF68 is_malloc=1 length=0x384 ----
F4FF28: 0 0 0 0 0 0 0 0
F4FF48: 0 0 0 0 0 0 0 FD0110DF
F4FF68: AB1234CD FFFE0000 0 99A39C FCCF4 F502EC F4FBF8 800001AA
F4FF88: 1 0 1 CF1DE8 F4D568 0 0 0
F4FFA8: 0 0 FFFF0001 10000 1ACA41C 1ACA462 1ACA462 1ACA462
F4FFC8: 1ACA470 1ACA470 0 11E7CBC 11 3C002D 1000E 0
F4FFE8: 0 0 0 0 0 0 0 0
F50008: 0 0 0 0 0 0 0 0
F50028: 0 0 0 0 10000 EE274C FD924 0
F50048: 0 0 0 0 F5031C F4FC14 CF1384 14
F50068: 0 0 0 0 0 0 0 0
F50088: 0 0 0 0 0 0 0 0
F500A8: 0 0 0 0 0 0 0 138E4D
F500C8: 0 16AE 0 0 0 0 0 0
F500E8: 0 0 0 0 0 0 0 1067FDC
F50108: 0 0 0 0 0 0 0 0
F50128: 0 0 0 0 0 0 0 0
F50148: 0 0 0 0 0 0 0 0
F50168: 0 0 0 0 0 0 0 0
F50188: 0 0 0 0 0 0 0 0
F501A8: 0 0 0 0 0 0 0 0
F501C8: 0 0 0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFF
F501E8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
F50208: FFFFFFFF 0 0 0 0 0 0 0
F50228: 0 0 0 0 0 0 0 0
F50248: 0 0 0 0 0 0 0 0
F50268: 0 0 0 0 0 0 0 0
F50288: 0 0 0 0 0 0 0 0
F502A8: 0 0 0 0 0 0 0 0
F502C8: 0 0 0 0 0 0 0 0
F502E8: FD0110DF
---- block79 ptr=CD2588 is_malloc=1 length=0x520 ----
CD2548: 49B808 CD2588 CD24D8 80000010 1 0 35 CF0204
CD2568: 0 14096FF FFFF0000 40000001 0 0 0 FD0110DF
CD2588: AB1234CD FFFE0000 0 966878 7D3680 CD2AA8 CD254C 80000278
CD25A8: 1 0 1 CF1DE8 CD2750 0 0 CD275C
CD25C8: 0 0 CD26D8 0 0 CD2648 0 0
CD25E8: CD2804 0 0 CD272C 0 0 CD2738 0
CD2608: 0 CD2660 0 0 CD26E4 0 0 CD27E0
CD2628: 0 0 CD26A8 0 0 CD25B8 0 0
CD2648: CD269C 0 0 CD2690 0 0 CD27F8 0
CD2668: 0 CD27D4 0 0 CD2654 0 0 CD26F0
CD2688: 0 0 CD25E8 0 0 CD27C8 0 0
CD26A8: CD2798 0 0 CD27A4 0 0 CD281C 0
CD26C8: 0 CD266C 0 0 CD25F4 0 0 CD2720
CD26E8: 0 0 CD27B0 0 0 CD263C 0 0
CD2708: CD26C0 0 0 CD2708 0 0 CD2678 0
CD2728: 0 CD2834 0 0 CD27BC 0 0 CD2810
CD2748: 0 0 CD25C4 0 0 CD278C 0 0
CD2768: CD2744 0 0 CD2828 0 0 CD26FC 0
CD2788: 12DB74C CD2774 0 0 CD26FC 0 0 CD26CC
CD27A8: 0 0 CD25D0 0 0 CD2618 0 0
CD27C8: CD26B4 0 0 CD2600 0 0 CD25DC 0
CD27E8: 0 CD2780 0 D896B4 CD2714 0 0 CD2768
CD2808: 0 0 CD2684 0 0 CD2624 0 0
CD2828: CD260C 0 0 CD2840 0 0 CD284C 0
CD2848: 0 CD2858 0 0 CD2864 0 0 CD2870
CD2868: 0 0 CD287C 0 0 CD2888 0 0
CD2888: CD2894 0 0 CD28A0 0 0 CD28AC 0
CD28A8: 0 CD28B8 0 0 CD28C4 0 0 CD28D0
CD28C8: 0 0 CD28DC 0 0 CD28E8 0 0
CD28E8: CD28F4 0 0 CD2900 0 0 CD290C 0
CD2908: 0 CD2918 0 0 CD2924 0 0 CD2930
CD2928: 0 0 CD293C 0 0 CD2948 0 0
CD2948: CD2954 0 0 CD2960 0 0 CD296C 0
CD2968: 0 CD2978 0 0 CD2984 0 0 CD2990
CD2988: 0 0 CD299C 0 0 CD29A8 0 0
CD29A8: CD29B4 0 0 CD29C0 0 0 CD29CC 0
CD29C8: 0 CD29D8 0 0 CD29E4 0 0 CD29F0
CD29E8: 0 0 CD29FC 0 0 CD2A08 0 0
CD2A08: CD2A14 0 0 CD2A20 0 0 CD2A2C 0
CD2A28: 0 CD2A38 0 0 CD2A44 0 0 CD2A50
CD2A48: 0 0 CD2A5C 0 0 CD2A68 0 0
CD2A68: CD2A74 0 0 CD2A80 0 0 CD2A8C 0
CD2A88: 0 CD2A98 0 0 0 0 0 FD0110DF
---- block80 ptr=1C6AB54 is_malloc=1 length=0x100 ----
1C6AB14: 0 0 0 0 0 0 0 0
1C6AB34: 0 0 0 0 0 0 0 FD0110DF
1C6AB54: AB1234CD FFFE0000 0 966878 7D3188 1C6AC34 1C6AA88 80000058
1C6AB74: 1 0 1 CF1DE8 CD26A8 3A00 2F080000 48B
1C6AB94: 3A001E 8220000 FFFFFFFF FFFF003A 9A1096D0 7E90F C7D840A5 0
1C6ABB4: 1200 AAAA0000 0 0 FFFFFFFF 8417AAAA 38008121 C4A5FA17
1C6ABD4: 13D10 200 7E90F C7D80000 0 0 0 0
1C6ABF4: 0 0 0 0 0 0 0 0
1C6AC14: 0 0 0 0 0 0 0 FD0110DF
1C6AC34: AB1234CD FFFE0000 0 966878 7D3188 1C6AD14 1C6AB68 80000058
---- block81 ptr=99AB9C is_malloc=0 length=0x100 ----
99AB5C: 69627265 20436861 6E6E656C 206F7665 72204950 20696E74 65726661 63652573
99AB7C: A000000 25752053 6174656C 6C697465 20696E74 65726661 63652573 A000000
99AB9C: 2A486172 64776172 65204944 422A0000 2A536F66 74776172 65204944 422A0000
99ABBC: 44454332 31313430 41000000 44454332 31313430 0 416D6446 45000000
99ABDC: 4952422F 43524220 72787479 70657300 48574944 42000000 53574944 42000000
99ABFC: 456C656D 656E7420 496E7365 7274696F 6E000000 25732E25 75000000 456C656D
99AC1C: 656E7420 44656C65 74696F6E 0 25632563 25642573 25640000 25632563
99AC3C: 25640000 5461626C 6520496E 69746961 6C697A61 74696F6E 0 444F4449
99AC5C: 50000000 4150504C 45000000 4E4F5645 4C4C3100 4E4F5645 4C4C3200 5341505F
99AC7C: 49500000 395F554E 55534544 0 54414753 57495443 48000000 5452414E
---- block82 ptr=EE2014 is_malloc=1 length=0x53C ----
EE1FD4: 0 0 0 0 0 0 0 0
EE1FF4: 0 0 0 0 0 0 0 FD0110DF
EE2014: AB1234CD FFFE0000 0 99ABAC 105E18 EE2550 EE148C 80000286
EE2034: 1 0 1 CF1DE8 CD3EE4 11E7CBC 5DC 0
EE2054: 5DC0000 0 0 0 0 11E4600 10A4100 40000001
EE2074: 0 0 1 0 0 0 0 0
EE2094: 0 0 0 EE14A8 0 0 2 0
EE20B4: 1 0 1 2 EE26B4 EE2700 0 0
EE20D4: 0 0 1 EE2044 0 0 4 0
EE20F4: 0 0 0 0 0 E1E76C 1108848 11E4408
EE2114: 0 1145FB8 0 0 0 0 0 0
EE2134: 0 0 0 0 0 0 0 0
EE2154: 0 0 0 0 0 0 0 0
EE2174: 0 0 0 0 1145FB8 0 0 0
EE2194: 0 0 0 6 64 64 D2F0 D2F0
EE21B4: 0 0 0 0 0 DBBA00 0 1000000
EE21D4: 1000000 0 0 0 0 0 0 0
EE21F4: 0 FFFFFFFF 0 0 0 0 0 0
EE2214: 0 0 0 0 0 0 10100 0
EE2234: 0 EE056C 0 0 0 0 0 0
EE2254: 0 0 0 2508 0 0 0 0
EE2274: 0 0 0 0 0 100 1000000 0
EE2294: 202 2808080 0 0 0 0 0 0
EE22B4: 0 0 0 1 0 0 0 0
EE22D4: 0 0 0 0 0 0 0 0
EE22F4: 0 0 0 0 123F16C 123F16C 1 0
EE2314: 0 0 0 0 0 0 0 0
EE2334: 0 0 0 0 0 0 0 0
EE2354: 0 0 0 0 0 0 0 0
EE2374: 0 0 0 0 0 0 0 0
EE2394: 0 0 0 0 0 0 0 0
EE23B4: 0 0 0 0 0 0 0 0
EE23D4: 0 0 0 0 0 0 0 0
EE23F4: 0 0 0 0 0 0 0 0
EE2414: 0 0 0 0 0 0 0 0
EE2434: 0 0 0 0 0 0 0 0
EE2454: 0 0 0 0 0 0 0 0
EE2474: 0 0 0 0 0 0 0 0
EE2494: 0 0 0 0 0 0 0 4
EE24B4: 0 0 0 0 0 0 0 0
EE24D4: 0 0 0 0 0 0 0 0
EE24F4: 0 0 0 0 0 0 0 0
EE2514: 0 0 0 0 0 EE2044 0 0
EE2534: 4B 9E34 0 0 0 0 FD0110DF
---- block83 ptr=9A3AD4 is_malloc=0 length=0x100 ----
9A3A94: 72666163 65000000 49465459 50455F56 46520000 49454545 20383032 2E313120
9A3AB4: 574C414E 0 49465459 50455F44 4F543131 0 56697274 75616C2D
9A3AD4: 446F7431 31526164 696F0000 56697274 75616C20 446F7431 3120496E 74657266
9A3AF4: 61636500 49465459 50455F56 444F5431 31000000 4D465200 4D756C74 696C696E
9A3B14: 6B204672 616D6520 52656C61 79206275 6E646C65 20696E74 65726661 63650000
9A3B34: 49465459 50455F4D 46520000 436F6E74 656E742D 456E6769 6E650000 63697363
9A3B54: 6F20636F 6E74656E 7420656E 67696E65 20736572 76696365 206D6F64 756C6500
9A3B74: 49465459 50455F53 45525649 43455F4D 4F44554C 45000000 53657276 6963652D
9A3B94: 456E6769 6E650000 63697363 6F207365 72766963 6520656E 67696E65 20736572
9A3BB4: 76696365 206D6F64 756C6500 49465459 50455F53 45525649 43455F4D 4F44554C
---- block84 ptr=EE2684 is_malloc=1 length=0x100 ----
EE2644: 0 0 0 0 0 0 0 0
EE2664: 0 0 0 1 0 0 0 FD0110DF
EE2684: AB1234CD FFFE0000 0 966878 107A54 EE26D0 EE2564 8000000E
EE26A4: 1 0 1 CF1DE8 446F7431 31526164 696F3000 0
EE26C4: 0 0 FD0110DF AB1234CD FFFE0000 0 966878 107AD0
EE26E4: EE271C EE2698 8000000E 1 0 1 CF1DE8 446F3000
EE2704: 0 0 0 0 0 FD0110DF AB1234CD FFFE0000
EE2724: 0 8DD928 1C6A44 EE28A0 EE26E4 800000AA 1 0
EE2744: 1 CF1DE8 0 DEADB10B FCCBC FD15C FD25C FD438
EE2764: FD748 FD758 FD768 FD8E4 10279C 0 0 0
---- block85 ptr=C16DC0 is_malloc=0 length=0x100 ----
C16D80: 0 0 0 0 0 0 0 0
C16DA0: 0 0 0 0 0 0 0 0
C16DC0: 0 0 C166D0 0 0 0 420C 0
C16DE0: 0 0 0 0 0 0 0 0
C16E00: 0 0 0 0 0 0 0 0
C16E20: 0 0 0 0 0 0 0 0
C16E40: 0 0 0 0 0 0 0 0
C16E60: 0 0 0 0 0 0 0 0
C16E80: 0 0 0 0 0 0 0 0
C16EA0: 0 0 0 0 0 0 0 0
---- block86 ptr=1009E48 is_malloc=1 length=0xA00 ----
1009E08: 0 0 0 0 0 0 0 0
1009E28: 0 0 0 0 0 0 0 FD0110DF
1009E48: AB1234CD FFFE0000 0 A49888 50F040 1030BDC 10092C0 800136B2
1009E68: 1 0 1 CF1DE8 D15CD15C 400 0 0
1009E88: 0 0 0 0 0 1 0 0
1009EA8: 0 0 0 0 0 0 0 101653C
1009EC8: 0 1009FD8 0 0 0 1 2 0
1009EE8: 0 0 0 0 0 0 0 0
1009F08: 1016550 0 1009EC8 0 0 0 2 3
1009F28: 0 0 0 0 0 0 0 0
1009F48: 0 1016564 0 1009F0C 0 0 0 3
1009F68: 4 0 0 0 0 0 0 0
1009F88: 0 0 1016578 0 1009F50 0 0 0
1009FA8: 4 0 0 0 0 0 0 0
1009FC8: 0 0 0 101E210 0 100A01C 0 0
1009FE8: 0 5 0 0 0 0 0 0
100A008: 0 0 0 0 101653C 0 100A060 0
100A028: 0 0 6 0 0 0 0 0
100A048: 0 0 0 0 0 101E238 0 100A0A4
100A068: 0 0 0 7 0 0 0 0
100A088: 0 0 0 0 0 0 101E24C 0
100A0A8: 100A0E8 0 0 0 8 0 0 0
100A0C8: 0 0 0 0 0 0 0 101E260
100A0E8: 0 100A12C 0 0 0 9 0 0
100A108: 0 0 0 0 0 0 0 0
100A128: 101E274 0 100A170 0 0 0 A 0
100A148: 0 0 0 0 0 0 0 0
100A168: 0 101E288 0 100A1B4 0 0 0 B
100A188: 0 0 0 0 0 0 0 0
100A1A8: 0 0 101E29C 0 100A1F8 0 0 0
100A1C8: C 0 0 0 0 0 0 0
100A1E8: 0 0 0 101E2B0 0 100A23C 0 0
100A208: 0 D 0 0 0 0 0 0
100A228: 0 0 0 0 101E2C4 0 100A280 0
100A248: 0 0 E 0 0 0 0 0
100A268: 0 0 0 0 0 101E2D8 0 100A2C4
100A288: 0 0 0 F 0 0 0 0
100A2A8: 0 0 0 0 0 0 101E2EC 0
100A2C8: 100A308 0 0 0 10 0 0 0
100A2E8: 0 0 0 0 0 0 0 101E300
100A308: 0 100A34C 0 0 0 11 0 0
100A328: 0 0 0 0 0 0 0 0
100A348: 101E314 0 100A390 0 0 0 12 0
100A368: 0 0 0 0 0 0 0 0
100A388: 0 101E328 0 100A3D4 0 0 0 13
100A3A8: 0 0 0 0 0 0 0 0
100A3C8: 0 0 101E33C 0 1009E84 0 0 0
100A3E8: 14 0 0 0 0 0 0 0
100A408: 0 0 0 101E350 0 0 0 0
100A428: 0 0 0 0 0 0 0 0
100A448: 0 0 0 0 0 0 0 0
100A468: 0 0 0 0 0 0 0 0
100A488: 0 0 0 0 0 0 0 0
100A4A8: 0 0 0 0 0 0 3A9A0D DF802000
100A4C8: 0 0 20000 1009FD8 0 0 0 0
100A4E8: 0 0 0 0 0 100A01C 1 0
100A508: 0 0 0 0 0 0 0 100A060
100A528: 2 0 0 0 0 0 0 0
100A548: 0 100A0A4 3 0 0 0 0 0
100A568: 0 0 0 100A0E8 4 0 0 0
100A588: 0 0 0 0 0 100A12C 5 0
100A5A8: 0 0 0 0 0 0 0 100A170
100A5C8: 6 0 0 0 0 0 0 0
100A5E8: 0 100A1B4 7 0 0 0 0 0
100A608: 0 0 0 100A1F8 8 0 0 0
100A628: 0 0 0 0 0 100A23C 9 0
100A648: 0 0 0 0 0 0 0 100A280
100A668: A 0 0 0 0 0 0 0
100A688: 0 100A2C4 B 0 0 0 0 0
100A6A8: 0 0 0 100A308 C 0 0 0
100A6C8: 0 0 0 0 0 100A34C D 0
100A6E8: 0 0 0 0 0 0 0 100A390
100A708: E 0 0 0 0 0 0 0
100A728: 0 100A3D4 F 0 0 0 0 0
100A748: 0 0 0 0 0 0 100A744 100A74A
100A768: 0 8020000 0 0 0 0 0 0
100A788: 0 100A770 100A77C 18000000 8030000 0 0 0
100A7A8: 0 0 0 0 100A7A8 100A7B0 1E000000 0
100A7C8: 0 0 0 0 0 0 0 0
100A7E8: 0 0 0 FF000000 0 0 0 0
100A808: 0 0 0 0 0 0 0 0
100A828: 0 0 0 0 0 0 0 0
---- block87 ptr=1067410 is_malloc=1 length=0xA00 ----
10673D0: 0 0 0 0 10673E4 EE14A8 0 0
10673F0: 96 1689E 0 18732 E3 0 0 FD0110DF
1067410: AB1234CD FFFE0000 0 99AB9C 105DFC 1067FAC 10673A0 800005B6
1067430: 1 0 1 CF1DE8 0 0 0 0
1067450: 0 0 1067FDC 12 0 5C8A70 3 0
1067470: 0 1000000 0 23E184 4 0 0 0
1067490: 1 5F4 E 0 0 0 0 0
10674B0: 0 0 0 5EA 0 0 0 0
10674D0: 3 3 4 0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
10674F0: 0 0 0 0 1067440 BB7DA8 0 0
1067510: 0 0 99A5CC C62ED0 1068868 10688B4 5DC05DC 1
1067530: 5F4 5F0 EE274C 1 0 210040 200010 0
1067550: 0 40000000 4 4 0 5 0 0
1067570: 0 143DB4 0 138022 0 0 0 2D6B
1067590: 0 0 C16DC0 1067440 0 0 1424C 0
10675B0: 7D0 7D0 0 A66D38 106864C 0 1 1
10675D0: 1 68 0 0 FF 20A7BC 1010001 FF000009
10675F0: 0 138BDA 0 0 0 0 0 0
1067610: 0 0 0 0 0 0 0 0
1067630: 0 0 0 0 0 0 0 0
1067650: 0 0 0 28 28 28 28 28
1067670: 28 28 28 28 28 28 28 28
1067690: 28 28 28 28 0 0 0 28
10676B0: 0 0 0 28 0 0 0 28
10676D0: 0 0 0 28 0 0 0 28
10676F0: 0 0 0 28 0 0 0 28
1067710: 0 0 0 28 0 0 0 28
1067730: 0 0 0 28 0 0 0 28
1067750: 0 0 0 28 0 0 0 28
1067770: 0 0 0 28 0 0 0 28
1067790: 0 0 0 28 0 0 0 28
10677B0: 0 1067440 0 0 4 467 467 0
10677D0: 0 0 10559C 1055F4 0 20C234 20B8D0 0
10677F0: 86E18 0 0 5C8000 0 0 104834 1050A4
1067810: 0 126C88 0 20AE30 5C4D50 5C5354 20F1C4 126980
1067830: 20A940 0 20AD84 0 0 0 0 5C4528
1067850: 5C53D8 0 0 5C4D80 0 0 5CC520 20AC78
1067870: 0 0 0 0 0 0 0 0
1067890: 0 0 5CB828 5CB7F8 0 0 0 0
10678B0: 0 0 0 0 0 A4C5 0 5578C4
10678D0: 13 0 6D39A2 1B 0 5B 0 0
10678F0: 0 4C2B AEB6 0 0 0 0 0
1067910: 0 1 0 0 0 0 0 0
1067930: 6CB1 0 0 0 0 1 0 0
1067950: 0 0 0 0 0 0 0 0
1067970: 0 0 0 0 0 0 0 0
1067990: 0 0 DB67 0 0 0 0 0
10679B0: 0 0 0 0 0 0 0 0
10679D0: 0 0 2 0 0 0 0 0
10679F0: 261011 DB66 1A EDAA 24 0 2 0
1067A10: 2D 4697 37 1067ABC 1067B00 0 0 0
1067A30: 0 0 E2D414 0 0 0 0 0
1067A50: 0 E2D458 0 0 E2D38C 0 0 0
1067A70: 0 0 0 0 0 0 0 0
1067A90: 0 0 0 0 0 0 0 E2D1F4
1067AB0: 0 0 0 0 0 0 0 37
1067AD0: 19A1 0 0 0 0 7E 1D88 0
1067AF0: 0 0 0 0 0 0 0 0
1067B10: C DE4 0 0 0 0 37 1261
1067B30: 0 0 0 0 0 0 0 0
1067B50: 0 0 0 138000 0 0 0 0
1067B70: C16980 1067440 0 0 4424C 0 0 0
1067B90: 0 0 0 0 0 0 0 0
1067BB0: 0 0 0 0 0 0 0 0
1067BD0: 0 0 0 0 0 0 0 0
1067BF0: 0 0 0 0 0 0 0 0
1067C10: 0 0 0 0 0 0 0 0
1067C30: 0 0 0 0 0 0 0 0
1067C50: 0 0 0 0 0 0 0 0
1067C70: 0 0 0 0 0 0 0 0
1067C90: 0 0 0 0 0 0 0 0
1067CB0: 1068518 0 1068800 0 0 0 11C46B4 0
1067CD0: 0 0 0 0 0 0 0 0
1067CF0: 0 0 0 0 0 0 0 0
1067D10: 0 0 0 0 0 0 0 0
1067D30: 0 0 0 0 0 0 0 11C46B4
1067D50: 0 0 0 0 0 0 1000000 0
1067D70: 0 0 0 0 0 0 0 0
1067D90: 1000000 0 0 0 0 0 0 0
1067DB0: 0 0 0 0 0 0 0 0
1067DD0: 80000 0 0 0 0 0 0 0
1067DF0: 0 0 0 0 0 0 0 0
---- block88 ptr=CD3EB4 is_malloc=1 length=0x53C ----
CD3E74: 1 CF1DE8 FDB71C EE14A8 8BF0DC 1035AA8 11E6224 3A9A10
CD3E94: 96D00000 3A9A10 96D00000 0 0 0 0 FD0110DF
CD3EB4: AB1234CD FFFE0000 0 99ABAC 105E18 CD43F0 CD3E60 80000286
CD3ED4: 1 0 1 CF1DE8 1067FDC EE2044 5DC 0
CD3EF4: 5DC0000 0 0 0 0 11E5D2C D58E00 40000001
CD3F14: 0 0 1 0 0 0 0 0
CD3F34: 0 0 0 10092DC 0 0 3 0
CD3F54: 1 0 1 2 CD4554 CD45A0 0 0
CD3F74: 0 0 2 CD3EE4 0 0 8 0
CD3F94: 0 0 0 0 0 E1E734 10E767C 11E4A34
CD3FB4: 0 CD24F4 0 0 0 0 0 0
CD3FD4: 0 0 0 0 0 0 0 0
CD3FF4: 0 0 0 0 0 0 0 0
CD4014: 0 0 0 0 CD24F4 0 0 0
CD4034: 0 0 0 6 64 64 D2F0 D2F0
CD4054: 0 0 0 0 0 DBBA00 0 1000000
CD4074: 1000000 0 0 0 0 0 0 0
CD4094: 0 FFFFFFFF 0 0 0 0 0 0
CD40B4: 0 0 0 0 0 0 10100 0
CD40D4: 0 CD2334 0 0 0 0 0 0
CD40F4: 0 0 0 2508 0 0 0 0
CD4114: 0 0 0 0 0 100 1000000 0
CD4134: 202 2808080 0 0 0 0 0 0
CD4154: 0 0 0 1 0 0 0 0
CD4174: 0 0 0 0 0 0 0 0
CD4194: 0 0 0 0 123F190 123F190 1 0
CD41B4: 0 0 0 0 0 0 0 0
CD41D4: 0 0 0 0 0 0 0 0
CD41F4: 0 0 0 0 0 0 0 0
CD4214: 0 0 0 0 0 0 0 0
CD4234: 0 0 0 0 0 0 0 0
CD4254: 0 0 0 0 0 0 0 0
CD4274: 0 0 0 0 0 0 0 0
CD4294: 0 0 0 0 0 0 0 0
CD42B4: 0 0 0 0 0 0 0 0
CD42D4: 0 0 0 0 0 0 0 0
CD42F4: 0 0 0 0 0 0 0 0
CD4314: 0 0 0 0 0 0 0 0
CD4334: 0 0 0 0 0 0 0 4
CD4354: 0 0 0 0 0 0 0 0
CD4374: 0 0 0 0 0 0 0 0
CD4394: 0 0 0 0 0 0 0 0
CD43B4: 0 0 0 0 0 CD3EE4 0 0
CD43D4: 4B 9E34 0 0 0 0 FD0110DF
---- block89 ptr=CD4524 is_malloc=1 length=0x100 ----
CD44E4: 0 0 0 0 0 0 0 0
CD4504: 0 0 0 1 0 0 0 FD0110DF
CD4524: AB1234CD FFFE0000 0 966878 107A54 CD4570 CD4404 8000000E
CD4544: 1 0 1 CF1DE8 446F7431 31526164 696F3100 0
CD4564: 0 0 FD0110DF AB1234CD FFFE0000 0 966878 107AD0
CD4584: CD45BC CD4538 8000000E 1 0 1 CF1DE8 446F3100
CD45A4: 0 0 0 0 0 FD0110DF AB1234CD FFFE0000
CD45C4: 0 966878 4FBD10 CD47D4 CD4584 800000F4 1 7B0E4C
CD45E4: 1 CF1DE8 0 100A4C0 10349B4 3030000 122E4E8 122E0F8
CD4604: 0 0 0 0 0 0 0 0
---- block90 ptr=978C70 is_malloc=0 length=0x100 ----
978C30: 65640000 45736361 70652054 79706564 0 50534920 456E6162 6C656400
978C50: 44535220 5472616E 73697469 6F6E0000 52656164 79000000 48616E67 696E6720
978C70: 75700000 436F6E6E 65637465 64000000 43617272 69657220 44726F70 70656400
978C90: 52637664 20435200 486F6C64 20547970 65640000 57616974 696E6720 666F7220
978CB0: 584F4E00 53656E74 20584F46 46000000 4175746F 62617564 696E6700 4E6F2045
978CD0: 78697420 42616E6E 65720000 52637664 20425245 414B0000 4173796E 6320496E
978CF0: 74657266 61636520 41637469 76650000 53656E64 696E6720 42726561 6B000000
978D10: 52637664 20436F6D 6D616E64 0 53656E64 20584F46 4620536F 6F6E0000
978D30: 43617264 20436F6E 736F6C65 0 496E7075 74205374 6F707065 64000000
978D50: 53656E64 20427265 616B2053 6F6F6E00 436F6E74 726F6C2D 63205479 70656400
---- block91 ptr=A01D78 is_malloc=0 length=0x100 ----
A01D38: 75726174 696F6E00 466F7220 646F776E 6C6F6164 696E6720 636F6E66 69677572
A01D58: 6174696F 6E732066 726F6D20 41414120 73657276 65720000 72657665 7273652D
A01D78: 74656C6E 65740000 466F7220 72657665 72736520 74656C6E 65742063 6F6E6E65
A01D98: 6374696F 6E732C20 6F6C6420 636F6D6D 616E6400 466F7220 72657665 72736520
A01DB8: 61636365 73732063 6F6E6E65 6374696F 6E730000 466F7220 41757468 656E7469
A01DD8: 63617469 6F6E2050 726F7879 20536572 76696365 73000000 466F7220 6E657477
A01DF8: 6F726B20 73657276 69636573 2E202850 50502C20 534C4950 2C204152 41502900
A01E18: 466F7220 4D6F6269 6C652049 50207365 72766963 65732E00 466F7220 65786563
A01E38: 20287368 656C6C29 20636F6D 6D616E64 732E0000 466F7220 73746172 74696E67
A01E58: 20616E20 65786563 20287368 656C6C29 2E000000 456E6162 6C652074 656D706C
---- block92 ptr=9C9540 is_malloc=0 length=0x100 ----
9C9500: 6E206163 63657373 20746F20 706F7274 20256420 64656E69 65640000 A544350
9C9520: 3A20636F 6E6E6563 74696F6E 20617474 656D7074 20746F20 706F7274 20256400
9C9540: 5443502F 49502054 656C6E65 74207072 6F746F63 6F6C0000 A746370 25743A20
9C9560: 636F6E6E 206E6F74 20616C69 76650000 A545459 25743A20 496E6163 74697669
9C9580: 74792074 696D656F 75740000 43617272 69657220 44726F70 0 A544350
9C95A0: 25743A20 54656C6E 65743A20 75726765 6E742072 63766400 436F6E6E 65637469
9C95C0: 6F6E2063 6C6F7365 64000000 A544350 3A204E6F 20667265 65205454 59277300
9C95E0: A544350 3A204163 63657373 2044656E 69656420 0 A544350 3A204176
9C9600: 61696C61 626C6520 7265736F 75726365 7320696E 73756666 69636965 6E740000
9C9620: A544350 3A20556E 6B6E6F77 6E206572 726F7200 25732025 78000000 A252549
---- block93 ptr=C24AC8 is_malloc=0 length=0x100 ----
C24A88: 0 0 0 0 0 0 0 0
C24AA8: CDCAEC 5472616E 73706F72 7420506F 72742041 67656E74 20312E31 0
C24AC8: 0 0 C1CA28 0 0 0 420C 0
C24AE8: 0 0 0 0 0 0 0 0
C24B08: 0 0 C24AC8 0 0 0 4204 0
C24B28: 0 0 0 0 0 0 0 0
C24B48: 0 0 0 0 0 0 C24AC8 0
C24B68: 0 0 4204 0 B9 8B 0 0
C24B88: 0 0 2 0 0 0 0 C24BA0
C24BA8: C1CA28 CAAE38 0 1380EC 420C 0 0 0
---- block94 ptr=966CE8 is_malloc=0 length=0x100 ----
966CA8: 6469616C 2D696E00 6469616C 2D6F7574 0 73733700 726D732D 73746F70
966CC8: 0 726D732D 73746172 74000000 7670646E 0 73737300 61746D00
966CE8: 73736800 69707636 0 6169726F 6E657400 7070706F 65000000 63646D61
966D08: 0 63726200 69676D70 0 77656276 706E0000 4C6F6769 6E000000
966D28: 4672616D 65640000 43616C6C 6261636B 204C6F67 696E0000 43616C6C 6261636B
966D48: 20467261 6D656400 4F757462 6F756E64 0 4E415320 50726F6D 70740000
966D68: 41757468 656E204F 6E6C7900 43616C6C 6261636B 204E4153 2050726F 6D707400
966D88: 43616C6C 20436865 636B0000 43616C6C 6261636B 2041646D 696E0000 566F6963
966DA8: 65000000 46617800 4D6F6465 6D205265 6C617900 4541506F 55445000 70617000
966DC8: 6D732D63 68617000 7368656C 6C000000 736C6970 0 7474792D 6461656D
---- block95 ptr=AB1128 is_malloc=0 length=0x100 ----
AB10E8: 20636F6E 6E656374 696F6E00 44697363 6F6E6E65 63742061 6E206163 74697665
AB1108: 20535348 20636F6E 6E656374 696F6E00 4175746F 53656375 72652053 53480000
AB1128: 5443502F 49502053 53482070 726F746F 636F6C00 A535348 3A496E76 616C6964
AB1148: 2F4E6F20 64617461 20666F6C 6C6F7769 6E672075 73657269 64000000 A535348
AB1168: 3A416363 65737320 746F2070 6F727420 25642066 61696C65 64000000 53534820
AB1188: 6D656D6F 72790000 A535348 3A206F75 74206F66 206D656D 6F72792C 2063616E
AB11A8: 74207265 6E616D65 20525341 206B6579 70616972 206E616D 65000000 A535348
AB11C8: 3A207468 726F7474 6C696E67 20726571 75657374 733A2050 6C656173 65207472
AB11E8: 79206166 74657220 736F6D65 2074696D 65000000 A535348 3A20436F 756C6420
AB1208: 6E6F7420 67657420 61207674 79206C69 6E652066 6F722069 6E636F6D 696E6720
---- block96 ptr=96F254 is_malloc=0 length=0x120 ----
96F214: 5452414E 5341433A 20415554 48206174 74656D70 74696E67 20746F20 64656372
96F234: 656D656E 742C2077 68696368 20697320 616C7265 61647920 7A65726F 0
96F254: 41414120 5075626C 69632053 65727665 72204772 6F757020 77726170 70657200
96F274: 41414120 6E766765 6E642073 6720656C 74000000 41414120 5075626C 69632053
96F294: 65727665 72204772 6F757000 41414120 70756220 53472073 65727665 72730000
96F2B4: 41414120 70756220 53472077 72617020 6E616D65 0 41414120 70756220
96F2D4: 5347206E 616D6500 556E6162 6C652074 6F206164 64207772 61707065 7220746F
96F2F4: 20696E74 65726E61 6C206C69 7374206F 66207075 626C6963 2067726F 75707300
96F314: 41414120 6E6F6E2D 6E766765 6E642053 4720656C 74000000 41414120 6E6F6E2D
96F334: 6E766765 6E642053 47000000 41414120 6E6F6E2D 6E766765 6E642053 47207772
96F354: 61700000 20707269 76617465 5F73672D 25640000 41414120 70767420 53472077
---- block97 ptr=1169560 is_malloc=1 length=0x100 ----
1169520: 0 0 0 0 1 11692E0 0 0
1169540: FFFFFFFF 80 0 0 0 0 0 FD0110DF
1169560: AB1234CD FFFE0000 0 96F254 2E49C 11695B0 11694B4 80000010
1169580: 1 0 1 CF1DE8 F3B2209A 1 1 116962C
11695A0: 11694D0 1 26000001 FD0110DF AB1234CD FFFE0000 0 96F2A0
11695C0: 2E4EC 11695FC 1169574 8000000E 1 0 1 CF1DE8
11695E0: 0 0 0 0 0 0 FD0110DF AB1234CD
1169600: FFFE0000 0 96F2B4 2E568 1169648 11695C4 8000000E 1
1169620: 0 1 CF1DE8 72616469 75730000 0 0 0
1169640: 0 FD0110DF AB1234CD FFFE0000 0 E27930 29370 117167C
---- block98 ptr=97FCFC is_malloc=0 length=0x100 ----
97FCBC: 65747572 6E20636F 64650000 50617273 65722043 4C492044 756D7065 72000000
97FCDC: 50617273 65722056 69657773 0 436F6D6D 616E6420 70617273 65720000
97FCFC: 50617273 6572204D 6F646500 50617273 6572204D 6F646520 51310000 50617273
97FD1C: 6572204D 6F646520 51320000 A416464 696E6720 70617273 6572206D 6F64653A
97FD3C: 20272573 27202030 78257800 A506172 73657220 6D6F6465 733A0000 A4E616D
97FD5C: 65202020 20202020 20202020 20202020 20205072 6F6D7074 20202020 20202020
97FD7C: 20202020 20202054 6F702020 20202020 2020416C 69617320 20202050 72697669
97FD9C: 6C656765 A000000 25323073 20253230 73203078 25387820 25387320 2538730A
97FDBC: 0 A4E6F20 70617273 6572206D 6F646573 0 A4C6F6F 6B207570
97FDDC: 206F6620 70617273 6572206D 6F646520 27257327 20257300 A252520 556E6162
---- block99 ptr=1168F2C is_malloc=1 length=0x100 ----
1168EEC: 0 0 0 0 0 0 0 0
1168F0C: 0 0 0 0 0 0 0 FD0110DF
1168F2C: AB1234CD FFFE0000 0 97FCFC A4278 1168F98 1168EBC 8000001E
1168F4C: 1 0 1 CF1DE8 1169060 8F466C 9F9DF8 9F9E0C
1168F6C: 965C64 3D40 3D54 33E1F0 7 B42818 1168FC8 1169014
1168F8C: 0 0 FD0110DF AB1234CD FFFE0000 0 97FD08 A42E0
1168FAC: 1168FE4 1168F40 8000000E 1 0 1 CF1DE8 0
1168FCC: 0 0 0 0 0 FD0110DF AB1234CD FFFE0000
1168FEC: 0 97FD18 A4304 1169030 1168FAC 8000000E 1 0
116900C: 1 CF1DE8 0 0 0 0 0 0
---- block100 ptr=9E35BC is_malloc=0 length=0x100 ----
9E357C: 73000000 54696D65 2052616E 67652050 726F6365 73730000 A252554 696D6520
9E359C: 52616E67 65207072 6F636573 73206372 65617469 6F6E2066 61696C65 64000000
9E35BC: 7472616E 67650000 45786974 2066726F 6D207469 6D652D72 616E6765 20636F6E
9E35DC: 66696775 72617469 6F6E206D 6F646500 456E6469 6E672074 696D6520 2D207374
9E35FC: 61797320 76616C69 6420756E 74696C20 62656769 6E6E696E 67206F66 206E6578
9E361C: 74206D69 6E757465 0 656E6469 6E672064 61792061 6E642074 696D6500
9E363C: 53746172 74696E67 2074696D 65000000 7765656B 656E6400 53617475 72646179
9E365C: 20616E64 2053756E 64617900 7765656B 64617973 0 4D6F6E64 61792074
9E367C: 68727520 46726964 61790000 6461696C 79000000 45766572 79206461 79206F66
9E369C: 20746865 20776565 6B000000 70657269 6F646963 2074696D 6520616E 64206461
---- block101 ptr=11722CC is_malloc=1 length=0x100 ----
117228C: 0 0 0 0 1 1172040 0 0
11722AC: FFFFFFFF 80 0 0 0 0 0 FD0110DF
11722CC: AB1234CD FFFE0000 0 96F254 2E49C 117231C 1172220 80000010
11722EC: 1 0 1 CF1DE8 F3B2209A 1 1 1172398
117230C: 117223C 1 FC000002 FD0110DF AB1234CD FFFE0000 0 96F2A0
117232C: 2E4EC 1172368 11722E0 8000000E 1 0 1 CF1DE8
117234C: 0 0 0 0 0 0 FD0110DF AB1234CD
117236C: FFFE0000 0 96F2B4 2E568 11723B4 1172330 8000000E 1
117238C: 0 1 CF1DE8 74616361 63732B00 0 0 0
11723AC: 0 FD0110DF AB1234CD FFFE0000 0 96F2CC 2E5AC 1172400
---- block102 ptr=117167C is_malloc=1 length=0x100 ----
117163C: 2A000000 1171648 DC000000 1171650 6B000000 1171658 83000000 1171660
117165C: 9C000000 1171668 C9000000 1171670 7E000000 0 EE000000 FD0110DF
117167C: AB1234CD FFFE0000 0 96F2CC 2E5AC 11716C8 116965C 8000000E
117169C: 1 0 1 CF1DE8 72616469 75730000 0 0
11716BC: 0 0 FD0110DF AB1234CD FFFE0000 0 966878 17C250
11716DC: 117174C 1171690 8000002A 1 0 1 CF1DE8 0
11716FC: 0 0 0 33DF54 0 0 0 0
117171C: 0 0 0 0 0 0 0 0
117173C: 0 0 0 FD0110DF AB1234CD FFFE0000 0 966878
117175C: 17C250 11717D0 11716DC 8000002A 1 0 1 CF1DE8
---- block103 ptr=11692B0 is_malloc=1 length=0x100 ----
1169270: 97F928 A3604 11692B0 116922C 8000000E 1 0 1
1169290: CF1DE8 1169248 BFA8FD B42A74 1 1 0 FD0110DF
11692B0: AB1234CD FFFE0000 0 9656E4 3728 116939C 1169278 8000005E
11692D0: 1 0 1 CF1DE8 1172040 11693CC 1 0
11692F0: 2 1388 3 FFFFFFFF 0 0 0 0
1169310: 0 0 0 0 0 0 0 0
1169330: 0 0 0 1 BA3DD4 33E33C 1 BA3DD4
1169350: 33E3C0 0 0 18 0 0 A0000 0
1169370: 0 0 0 0 0 0 0 0
1169390: 0 26000001 FD0110DF AB1234CD FFFE0000 0 9656F0 3764
---- block104 ptr=E29A58 is_malloc=1 length=0x100 ----
E29A18: E29A08 BB93A8 BB D0000 1 0 9B41DC 16D758
E29A38: B1D128 0 CF1640 0 0 BEEFCAFE 0 FD0110DF
E29A58: AB1234CD 80000 8 9B41A8 1771AC E29B1C E29770 8000004A
E29A78: 1 0 F CF1640 0 DEADFEED E29AE8 E2998C
E29A98: E29A10 C00204 E29A90 BB93A8 BA 90000 2 0
E29AB8: 96F038 17593C B1D128 0 0 0 E27F94 0
E29AD8: 0 0 0 0 E2998C 0 E29AD8 E29A90
E29AF8: 0 C189CC 0 0 0 FFFFFFF FFFFFFF 0
E29B18: FD0110DF AB1234CD FFFE0000 0 966878 7B2CBC E29B7C E29A6C
E29B38: 80000018 1 0 1 CF1DE8 E21D14 0 0
---- block105 ptr=96E578 is_malloc=0 length=0x100 ----
96E538: 6F757073 0 616C6C5F 67726F75 7073556E 61626C65 20746F20 63726561
96E558: 74652070 75626C69 63207365 72766572 2067726F 7570206C 6973742E 0
96E578: 50726976 61746520 41414120 53657276 65722047 726F7570 73000000 616C6C5F
96E598: 67726F75 7073556E 61626C65 20746F20 63726561 74652070 72697661 74652073
96E5B8: 65727665 72206772 6F757020 6C697374 2E000000 41414120 53657276 65722047
96E5D8: 726F7570 0 616C6C5F 67726F75 7073556E 61626C65 20746F20 72656769
96E5F8: 73746572 20747261 6E736163 74696F6E 20646200 556E6162 6C652074 6F206372
96E618: 65617465 20736572 76657220 67726F75 70206861 6E646C65 2E000000 556E6162
96E638: 6C652074 6F207570 64617465 20707265 70617265 20646174 61207374 72756374
96E658: 75726573 20666F72 20757064 6174652E 0 41414120 53472049 44207461
---- block106 ptr=C18E74 is_malloc=0 length=0x100 ----
C18E34: 0 0 CCF428 1086508 CE0798 CE0A78 C18E3C BB93A8
C18E54: 23 50000 5B 0 9BDC48 16D758 B1D128 0
C18E74: EC54EC EAB99C C18EB4 C19074 C18E74 BB93A8 A 90000
C18E94: 6 0 9BDB28 1A27F4 B1D128 0 EB2050 EB2050
C18EB4: C19210 C18E7C C18EAC BB93A8 B 90000 1 0
C18ED4: 9BDB38 1A27F4 B1D128 0 2000 5121 19FAA8 EC5204
C18EF4: 0 0 EC511C 1C 2 2380E 0 BA0000
C18F14: 380E C6FA20 A0000000 0 0 0 0 0
C18F34: 0 1001980 0 0 0 EC5288 0 0
C18F54: 0 100080C 30 0 3 0 19FAA8 21230
---- block107 ptr=CE0764 is_malloc=0 length=0x100 ----
CE0724: CE06E8 CE0718 BB93A8 2D D0000 0 0 9B4E28
CE0744: 16D758 B1D128 0 B1183C 11C3388 0 0 CDF7CC
CE0764: 0 2 1A5FB0 F2610 1A60B8 0 1A60B0 1A596C
CE0784: 1A594C 1A65A8 1A5A94 CE4BB4 CE48CC CE07D0 C18E44 CE0790
CE07A4: BB93A8 24 90000 5B 0 9B4DD4 16D758 B1D128
CE07C4: 0 0 0 CE085C CE0798 CE07C8 BB93A8 25
CE07E4: 90000 0 0 9B4DE8 16D758 B1D128 0 CEB4A4
CE0804: 0 0 0 FF 0 0 C17500 0
CE0824: 0 0 4200 0 0 0 CE0814 CE0764
CE0844: 0 0 14240 0 0 0 CE0894 CE07D0
---- block108 ptr=D155E4 is_malloc=1 length=0x100 ----
D155A4: 15A3C78B 1 1C06FC D055E0 D04B14 0 D04BA0 15A3C78B
D155C4: 1 1C06FC D055E0 D04C2C D040B0 D04CB8 0 FD0110DF
D155E4: AB1234CD FFFE0000 0 9BDC34 1A6608 D25618 D055C4 80008002
D15604: 1 1C1964 1 CF1DE8 D25648 0 0 0
D15624: 0 400 E0 1100120 85 5B 60 85
D15644: 24 210000 BCA1E8 43505520 524F2052 55204368 756E0000 D159F0
D15664: D255F0 0 0 D15A00 D15B20 D15C40 D15D60 D15E80
D15684: D15FA0 D160C0 D161E0 D16300 D16420 D16540 D16660 D16780
D156A4: D168A0 D169C0 D16AE0 D16C00 D16D20 D16E40 D16F60 D17080
D156C4: D171A0 D172C0 D173E0 D17500 D17620 D17740 D17860 D17980
---- block109 ptr=1006F78 is_malloc=0 length=0x108 ----
1006F38: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1006F58: 1006F68 FFFFFFFF 21200 C2A6DC 1006F70 2EC2D0 FFFFFFFF 2E88EC
1006F78: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1006F98: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1006FB8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1006FD8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1006FF8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1007018: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1007038: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1007058: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
1007078: FFFFFFFF FFFFFFFF
---- block110 ptr=BFFD84 is_malloc=0 length=0x100 ----
BFFD44: 2EE0 7 FFFFFFFF 1 BFFD6C 1B3C5C 1EEFDB4 BFFD98
BFFD64: FFFFFFFF 1 BFFD84 1ABFBC 0 1 C800000 1
BFFD84: 0 1ACC10 0 0 0 2EE0 0 0
BFFDA4: 0 0 0 0 0 0 0 0
BFFDC4: 0 0 0 0 0 E36DE0 0 0
BFFDE4: 0 4204 0 0 0 0 0 0
BFFE04: 0 0 11D25F0 0 1C6A6F 4200 0 0
BFFE24: 0 0 0 0 0 0 0 0
BFFE44: 0 0 0 0 0 0 0 0
BFFE64: 0 0 0 0 0 0 0 0
---- block111 ptr=BBB3F0 is_malloc=0 length=0x100 ----
BBB3B0: A550EC 555854 CA4 2B A321CC 49B15C 3 57
BBB3D0: A550EC 555854 CA4 2B A49710 50C81C DEE 1C
BBB3F0: 0 0 0 C99514 0 138029 4204 0
BBB410: 0 0 0 0 0 0 0 0
BBB430: 0 0 0 0 0 0 0 0
BBB450: 0 0 0 0 0 0 0 0
BBB470: 0 0 0 0 0 0 0 0
BBB490: 0 0 0 0 0 0 0 0
BBB4B0: 0 0 0 0 0 0 0 0
BBB4D0: 0 0 0 0 0 0 0 0
---- block112 ptr=8DC868 is_malloc=0 length=0x100 ----
8DC828: 0 1AA83C 1AA864 1AA850 1AA668 1AA878 1AAA00 1AAA14
8DC848: 1AAA28 1AA8CC 1AAA3C 0 0 0 0 0
8DC868: 62616420 656E7175 65756500 656E7175 65756500 64657175 65756500 756E7175
8DC888: 65756500 72657175 65756500 73776170 71756575 65000000 705F756E 71756575
8DC8A8: 656E6578 74000000 72656D71 75657565 0 696E7371 75657565 0
8DC8C8: 76616C69 64717565 75650000 0 A25254E 6F206D65 6D6F7279 20617661
8DC8E8: 696C6162 6C650000 2A496E69 742A0000 2A536368 65642A00 2A446561 642A0000
8DC908: 2A4D616C 6C6F634C 6974652A 0 0 4D656D70 6F6F6C20 636F7272
8DC928: 75707400 4E6F7420 656E6F75 67682066 72656520 6D656D6F 72790000 42616420
8DC948: 73697A65 20726571 75657374 65640000 4D656D6F 72792066 7261676D 656E7461
---- block113 ptr=B223B0 is_malloc=0 length=0x100 ----
B22370: 1E0 22C 5DC 7D0 BB8 1388 2710 4E20
B22390: 8000 10000 20000 40000 12 11C6A74 122DA04 1
B223B0: 8 800 124F210 14 400 122F1A8 2C 400
B223D0: 120721C 44 400 11F4980 60 400 1264C44 80
B223F0: 200 123F1DC 0 28636F72 72656374 65642900 1 1
B22410: 0 8DD55C 8DD560 8DD588 8DD5B0 8DD5D8 8DD82C 8DD860
B22430: 8DD864 8DD888 8DD894 1000000 0 0 EA60 0
B22450: 0 0 C15C0515 C15C0515 1 0 0 8DDFB8
B22470: 1 0 1 1CBC34 60001 97 0 C15C0515
B22490: C15C0515 1 0 0 8DE19C 1 0 1
---- block114 ptr=98EC98 is_malloc=0 length=0x100 ----
98EC58: 20636F6E 66696775 72617469 6F6E206D 6F646500 636F6E66 69672D6D 61702D6C
98EC78: 69737400 4D617020 6C697374 20636F6E 66696775 72617469 6F6E206D 6F646500
98EC98: 2A496E69 742A0000 2A4D616C 6C6F634C 6974652A 0 2A536368 65642A00
98ECB8: 2A446561 642A0000 5425376C 75000000 4D656D6F 72792052 4D490000 436C6561
98ECD8: 72207468 65206D65 6D6F7279 20726563 6F726469 6E672065 76656E74 20627566
98ECF8: 66657200 6C6F772D 77617465 722D6D61 726B0000 52657365 74206D65 6D6F7279
98ED18: 206C6F77 20776174 6572206D 61726B00 4D656D6F 72792063 6F756E74 65727300
98ED38: 74726163 65626163 6B000000 64697370 6C617920 74726163 65626163 6B20696E
98ED58: 666F0000 44756D70 206D656D 6F727920 656E6469 6E672061 74203C61 64647265
98ED78: 73733E00 44756D70 206D656D 6F727920 73746172 74696E67 20617420 3C616464
---- block115 ptr=CD21E4 is_malloc=1 length=0x234 ----
CD21A4: 0 0 0 0 0 0 0 0
CD21C4: 0 0 0 0 0 0 0 FD0110DF
CD21E4: AB1234CD FFFE0000 0 978B14 811DC CD2418 CD19F4 80000102
CD2204: 1 0 1 CF1DE8 2072656D 6F76696E 67207468 6520636C
CD2224: 69656E74 D0A2A4F 63742020 33203137 3A31343A 35312E39 34383A20 25444F54
CD2244: 31312D36 2D444953 4153534F 433A2049 6E746572 66616365 20446F74 31315261
CD2264: 64696F30 2C204465 61757468 656E7469 63617469 6E672053 74617469 6F6E2038
CD2284: 6335382E 37376162 2E323066 34205265 61736F6E 3A205072 6576696F 75732061
CD22A4: 75746865 6E746963 6174696F 6E206E6F 206C6F6E 67657220 76616C69 64206173
CD22C4: 206C6566 74207468 65204253 53200D0A 2A4F6374 20203320 31373A31 343A3530
CD22E4: 2E323734 3A202544 4F543131 2D362D41 53534F43 3A20496E 74657266 61636520
CD2304: 446F7431 31526164 696F302C 20537461 74696F6E 20206534 64352E33 6439392E
CD2324: 36646233 20417373 6F636961 74656420 4B45595F 4D474D54 5B4E4F4E 455D0D0A
CD2344: 2A4F6374 20203320 31373A31 343A3531 2E313332 3A202544 4F543131 2D362D41
CD2364: 53534F43 3A20496E 74657266 61636520 446F7431 31526164 696F302C 20537461
CD2384: 74696F6E 20202038 6335382E 37376162 2E323066 34204173 736F6369 61746564
CD23A4: 204B4559 5F4D474D 545B4E4F 4E455D0D A2A4F63 74202033 2031373A 31343A35
CD23C4: 312E3934 383A2025 444F5431 312D342D 4D415852 45545249 45533A20 5061636B
CD23E4: 65742074 6F20636C 69656E74 20386335 382E3737 61622E32 30663420 72656163
CD2404: 68656420 6D617820 72657472 6965732C FD0110DF
---- block116 ptr=AB7648 is_malloc=0 length=0x100 ----
AB7608: 41424C45 5F53495A 45000000 62616420 6E657720 49442074 61626C65 2073697A
AB7628: 65000000 49445F4D 414E4147 45525F49 4E544552 4E414C5F 4552524F 52000000
AB7648: 48617368 7461626C 65000000 48617368 7461626C 65204275 636B6574 73000000
AB7668: 48617368 7461626C 65204275 636B6574 0 4147454E 545F4333 38303000
AB7688: 6167656E 745F6333 3830305F 72656769 73747279 0 4141415F 53455256
AB76A8: 45520000 6161615F 73657276 65725F72 65676973 74727900 41535345 54415049
AB76C8: 0 61737365 74617069 5F726567 69737472 79000000 61746D5F 72656769
AB76E8: 73747279 0 41544D5F 504C4154 464F524D 0 61746D5F 706C6174
AB7708: 666F726D 5F726567 69737472 79000000 4155544F 53454300 6175746F 7365635F
AB7728: 72656769 73747279 0 6261636B 75705F72 65676973 74727900 43355253
========= Scheduler History Dump ======================
PID Exectime(ms) Caller PC Process Name
28 2740 0x0 Dot11 driver
12 48 0x503C74 Virtual Exec
35 2357 0x242A78 IP Input
28 1783 0x50C81C Dot11 driver
86 14366 0x483A3C HyBridge Input Process
86 14366 0x4853EC HyBridge Input Process
13 7211 0x32C8B4 ARP Input
86 14365 0x483A3C HyBridge Input Process
86 14365 0x4853EC HyBridge Input Process
31 2 0x5BE48C SOAP LED Process
26 1 0x11AD08 Compute load avgs
84 30 0x2A5A70 Syslog
21 58 0x5F7FC Logger
16 0 0xCB590 GraphIt
43 1618 0x555854 Dot11 Mgmt & Assoc Input Process
49 0 0x7DC91C CDP ILP Platform
43 4854 0x555854 Dot11 Mgmt & Assoc Input Process
28 3566 0x50C81C Dot11 driver
43 3236 0x555854 Dot11 Mgmt & Assoc Input Process
87 3 0x49B15C Tbridge Monitor
28 7132 0x7CF0FC Dot11 driver
40 0 0x53CB84 linktest
30 0 0x529E0C Voice Metrics Task
23 28 0x126FF8 Per-Second Jobs
86 14364 0x483A3C HyBridge Input Process
86 14364 0x4853EC HyBridge Input Process
Dumping Managed Timer Operation history [Next Entry(0)]
Index IPL Caller_pc Timer Operation
0 0 0x0 0x00000000 Empty Buffer
1 0 0x0 0x00000000 Empty Buffer
2 0 0x0 0x00000000 Empty Buffer
3 0 0x0 0x00000000 Empty Buffer
4 0 0x0 0x00000000 Empty Buffer
5 0 0x0 0x00000000 Empty Buffer
6 0 0x0 0x00000000 Empty Buffer
7 0 0x0 0x00000000 Empty Buffer
8 0 0x0 0x00000000 Empty Buffer
9 0 0x0 0x00000000 Empty Buffer
10 0 0x0 0x00000000 Empty Buffer
11 0 0x0 0x00000000 Empty Buffer
12 0 0x0 0x00000000 Empty Buffer
13 0 0x0 0x00000000 Empty Buffer
14 0 0x0 0x00000000 Empty Buffer
15 0 0x0 0x00000000 Empty Buffer
16 0 0x0 0x00000000 Empty Buffer
17 0 0x0 0x00000000 Empty Buffer
18 0 0x0 0x00000000 Empty Buffer
19 0 0x0 0x00000000 Empty Buffer
20 0 0x0 0x00000000 Empty Buffer
21 0 0x0 0x00000000 Empty Buffer
22 0 0x0 0x00000000 Empty Buffer
23 0 0x0 0x00000000 Empty Buffer
24 0 0x0 0x00000000 Empty Buffer
========= Data Inconsistency Errors =========
No data inconsistency errors have been recorded.
========= End of Crashinfo Collection =================
06-04-2013 11:23 PM
Crash and traceback caused by CPU hog. Possibly an IOS bug.
06-05-2013 06:23 AM
it will be that we need to upgrade the IOS ?
Thanks Regards
06-05-2013 12:14 PM
It must be Leo's bed time
I must say that upgrading is worth trying. Delete all the crash logs first in case you have filled up the flash.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
06-06-2013 03:13 PM
What we need to upgrade the IOS ?
06-06-2013 05:25 PM
You need to be able to download the image. If you don't have smartnet in which you can download the image, you will not be able to upgrade.
06-07-2013 07:11 AM
Hi ..
thanks for the advice
how can we know wich is the proper vertion that we neet to get upgrade .. here I posted the "sh ver" output
Regards and Thank you ..
AP1242AGNew#sh ver
Cisco IOS Software, C1240 Software (C1240-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 19:06 by prod_rel_team
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE (fc2)
AP1242AGNew uptime is 21 hours, 41 minutes
System image file is "flash:/c1240-k9w7-mx.124-21a.JA1/c1240-k9w7-mx.124-21a.JA1 "
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco AIR-AP1242AG-A-K9 (PowerPCElvis) processor (revision A0) with 24566K/81 92K bytes of memory.
Processor board ID FGL1539U0GM
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 70:81:05:F1:5E:BC
Part Number : 73-9925-07
PCA Assembly Number : 800-26579-06
PCA Revision Number : A0
PCB Serial Number : FOC153665NC
Top Assembly Part Number : 800-29232-02
Top Assembly Serial Number : FGL1539U0GM
Top Revision Number : A0
Product/Model Number : AIR-AP1242AG-A-K9
Configuration register is 0xF
