[ASK] client seems direct connected to WLC
Hi All,
and i'm here by want to ask something about wireless that our team developed currently.
i'm using WLC AIR-CT5508-K9 software version 7.3.101.0, ISE, cisco prime infrastructure 1.2 (1.2.1.012), and using Odyssey access client manager..
all running well but here the problem, when a user connected to our SSID, the status of connection information especially on access point..
there appear that "Access point : WLC2-ISC-JKT-GCC"
that is the WLC not the access point, is there any miss configuration from me..
thanks.
5 Replies 5
Scott Fella
Well that might just be your supplicant. Try to enable or disable Aironet IE on the WLAN advanced tab and see if that changes on your client.
-Scott
previous condition is enable, but when i'm try disabling "Aironet IE" and try to reconnect the status keep authenticating, client can't connect to wifi..
btw, thanks for help
Amjad Abdullah
Is it the same issue if you create an open SSID? or even a PSK SSID?
What about creating an account with different RADIUS other than the ISE, what will appear?
Rating useful replies is more useful than saying "Thank you"
Hi Amjad,
i already create PSK SSID, but the information where client connected is connect to 54-78-1a-33-80-9D, it's information about the Base Radio MAC not the hostname of Access Point..
Well, the questoin I would ask is: how does the supplicant can know the hostname of the AP?
If it was via CCX (Aironet IE) then only CCX capable devices would show the AP name and that is done under any SSID security configuratoin. But in your case with PSK it does not show the name of the AP.
If we can know how the supplicant guesses the AP name that would be our concern. AFAIK the supplicant can not guess the AP hostname and it is only aware about the BSSID (SSID mac address). I would say that the ISE enters the equation and chagnes that part for you. That's why it appears with ISE hostname when ther is dot1x authenticatoin via the ISE while it does not appear when the ISE out of the game.
Amjad
