Dell truemobile 1300 and AP1200g cannot get DHCP on workstation
gaban
We have AP1210G on our network and we are testing DEll's 1300 truewireless USB doing leap. We get authentication but cannot get a DHCP address. Have you guys seen this? and know of any fix?
But when I try it on a B AP with the same configuration as the G AP I get a DHCP address.
Not applicable
Which is the firmware version you are using? The firmware version 5.40.10 seems to resolve this issue.
Thanks for the reply. When you say firmware did you mean the AP on the USB g adapter?
thanks,
gilbert
Hi Gilbert,
I'm getting the exactly same situation as you did before. Did you manage to solve the problem? If yes how? Thanks in advance.
Daniel
We were testing dell's smallest form factor and never got it to work. Finally dump the idea and went ahead with the Dell formfactor that would accept the Cisco PCI wireless cards.
There might be a new firmware by this time that would fix the problem.
goodluck.
