Enterprise Agreement and Virtual CMX licensing --- UDI trouble I think :-)
So have anyone tried to License a CMX Virtual Appliance through a EA Agreement ?
And what did they do to get the license ?
The trouble is that it (The EA page) asks for a UDI of the CMX appliance. But all Virtual Appliances have the same UDI: MSE Virtual Appliance
And as you can see from the picture, that "UDI" is already taken.
Any suggestions ? Or should I create a case (*sigh*).
/Thomas
patoberli
I suggest you write an email to licensing[@]cisco.com (remove []).
wackerk24
Level 4
Level 4
Did you ever get an answer to this? I'm running into the same problem.
Yes after a lot of time, where the case went around a lot inside Cisco and some developers I think.
The solution is, basically write anything that is not already used somewhere else.
So you can write : hfjdkhfjdkaslfhgewj and it will be fine.
The license you get out will work on your CMX.
