08-28-2019 09:15 AM - edited 07-05-2021 10:55 AM
I have an AP joined to a Cisco WLC 2504 controller. I'm running a few debug commands on the AP directly, but the idle timeout period is way too short. Is there a way to change the SSH idle timeout either temporarily or permanently on the AP?
Solved! Go to Solution.
08-28-2019 11:59 AM
Hi Sam,
Since AP managed by WLC, your configuration done on AP itself will not be saved. So when AP reboots configs you do will be lost.
You can issue "debug capwap console cli" on your AP CLI first & then issue that command
Rasika
*** Pls rate all useful responses ***
08-28-2019 09:41 AM
Session time out.
AP(config)#line vty 0 15
AP(config-line)#session-timeout ?
<0-35791> Session timeout interval in minutes
AP(config-line)#session-timeout 30
Idle time out
AP(config-line)#exec-timeout 30
thanks to @rashika
08-28-2019 10:20 AM
Looks like the "config t" command doesn't work on LWAPPs joined to a Cisco WLC:
AP#config t
% Invalid input detected at '^' marker.
AP#
08-28-2019 11:45 AM
what is the model of WAP ?
08-28-2019 11:59 AM
Hi Sam,
Rasika
